Kohler 27 hp head gasket - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-03-2010, 04:43 PM   post #1 of 4
madmantrapper
All Fired Up
MTF Member # 26869
Default Kohler 27 hp head gasket
Does anyone think retorqueing the head before the gasket blows would be worth it? Has anyone tryed this? I'm thinking about it.
madmantrapper is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-03-2010, 10:07 PM   post #2 of 4
Alan Lloys
TECH Exchange Contributor!
Alan Lloys's Avatar
MTF Member # 32845
Default Re: Kohler 27 hp head gasket
I am not sure about this as a preventive measure, but I have seen in some service notes that they recommend it after a few hours if the head gasket has been replaced.
Remember that if you simply put the torque wrench on and turn it till it clicks, you will likely not accomplish anything.
The trick I have seen written but not tried myself is as follows:
  • Back all 4 headbolts out a little to loosen them
  • Take one headbolt completely out and dip the threads in a little oil
  • Re-insert bolt and snug it down (don't tighten it yet)
  • Repeat for the remaining 3 bolts
  • Torque down all 4 bolts per the repair manual instructions
As I said I have not tried this but it does seem to make sense. Basically you are taking the bolts out all the way and then re-inserting them again however without disturbing any of the gaskets.
Use at your own risk
Alan Lloys is offline   Reply With Quote Quick reply to this message
Old 03-04-2010, 02:53 PM   post #3 of 4
madmantrapper
All Fired Up
MTF Member # 26869
I don't see where that is any different then using a used head gasket over. Year ago when we retorgued heads after it heated up, we sure didn't loosen them first, this was on automobile engines.
Sponsored Links
Advertisement
Old 03-04-2010, 03:18 PM   post #4 of 4
Chuck_050382
Senior MTF Member
Chuck_050382's Avatar
MTF Member # 19593
Images: 4
You aren't supposed to reuse the head bolts so to me removing them and re-torquing them wouldn't be right.
The information says you check the them after a few hours after you replace the gasket, but I dint want want to take everything back off the motor.
__________________
Ford LGT 145, 2003 Craftsman GT 5000, 1977 MTD 990, 1983 Ford LGT 165, 1988 Cub Cadet 1210
Chuck_050382 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
