How to convert a points and condenser system to electronic ignition on a small engine - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Register Home FAQ Garage MTF Gallery Search Today's Posts Mark Forums Read Store Chat Room [1]
Walk Behind Mowers We all use them from time to time... no seats on them.. but they get the job done!!!
Reply
Thread Tools Display Modes
Old 02-25-2010, 12:25 AM   #1
Austen
Senior MTF Pollster
Austen's Avatar
MTF Member # 1682
Images: 12
Default How to convert a points and condenser system to electronic ignition on a small engine
Lately I've been recieving a lot of questions about how I converted my '49 Jacobsen two stroke reel mower to electronic ignition. I figured I'd make a thread on the parts that I bought and also an explanation about how it works so that it will hopefully answer some of the questions for anyone who might be considering doing the conversion to their small engine.
The kit that I bought is called the 'Nova II Electronic Tranistorized Solid State Ignition Module'. You also buy a coil that works inconjuction with that kit as it connects up to it. Here is the link to where you can buy the kit and the coil, both parts are listed about a quarter of the way down the page: http://images.google.com/imgres?imgu...%3D2%26hl%3Den
Here is the link to the instruction page for the kit: http://gardentractorpullingtips.com/images/novainst.gif
Basically this kit eliminates the original coil, condenser and points altogether. The kit includes a module, a ground wire, a wire that connects to the new coil, and a wire that you splice into the kill wire. The module itself I mounted to the engine mounting plate as seen in the picture below and the ground wire I have connected up to the lower right screw for the carburetor mounting. Depending on your application, you might have to find a different place to mount the module and ground wire. By viewing the diagram in the instructions it helps give you a visual of how the system is set up. The new coil should fit right over your exisiting coil laminate like factory, atleaste it did on my application.
Other than that, the install is pretty straight forward and would do it again in a heartbeat. No more points to clean, condensers to go out or timing to set. I feel that it is a quality kit and depending on how and where you mount the module and wiring, it can even be hidden out of sight and look stock. In my personal opinion, the conversion makes the engine more reliable and maintenance/trouble free in the long run, and would highly suggest it to anyone considering doing it as an upgrade or simply a replacement to a tired ignition system that no longer works.
What the new spark plug wire will look like from the new coil.
Austen is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-25-2010, 01:29 AM   #2
2008 Impala
Senior MTF Member
2008 Impala's Avatar
MTF Member # 23056
Default Re: How to convert a points and condenser system to electronic ignition on a small en
I have given thought as to what would happen if something did happen with the Jacobson as far as ignotion goes. This sounds like something to think about.
__________________
1986 John Deere 165 Lawn Tractor.
2007 Sears Craftsman LT1000 Lawn Tractor.
Late 1950's Jacobson 2 1/4 horse 2-cycle.
1988 Lawnboy 8480. 4.5 horse F engine
1996 White 3.75 horse Briggs
2008 Impala is offline   Reply With Quote
Old 02-25-2010, 05:48 AM   #3
Brad
MTF--A Step Above!
Brad's Avatar
MTF Member # 4571
Images: 28
Very nice post. Thanks for sharing that. Good picture to show finished results as well. Thank-you!
__________________
MTF--Getting better, one new member after another!
It's a great place to spend some time every day!
Brad
Brad is offline   Reply With Quote
Old 02-25-2010, 07:10 AM   #4
FordTech
The Sea of Green Machines
FordTech's Avatar
MTF Member # 1170
Images: 1
Great! Thanks for the details. I have wondered how to fix some stuff you cant even get a new ignition module for. This may raise some old stuff from the dead.
__________________
My Missing Michelle
Peace,Love, and understanding to all.... but dont step on my God given or citizen rights or my country or Ill be tuning up my 22261 on your head!
LBAD member 1170 30 miles north of Texas Red River State Line
Glad to help but my advice is just advice, Its free! "If that dont fix it, Something else will!"
FordTech is online now   Reply With Quote
Old 02-25-2010, 10:41 PM   #5
2cycled fruitcake
Proud Member of the 1K Club
2cycled fruitcake's Avatar
MTF Member # 34915
Send a message via Yahoo to 2cycled fruitcake
nice re-do, i saw same app described in a textbook i read for repairs..
__________________
__________
Pete
1980 R7070
1996 10227
2001 10323
19.?? mtd wb
1978..ish snapper v21
2000 craftsman sp
RKBA
SEMPER FI
OORAH
2cycled fruitcake is offline   Reply With Quote
Old 02-25-2010, 11:35 PM   #6
2 cycle freak
OMC & Ariens lover!
2 cycle freak's Avatar
MTF Member # 33900
wow i seen threads on other sites but no pics of how it was done what was the overall cost,time and labor?
__________________
My "kids"
Large units-
1997 Dixon 1001ztr Walk behind zero turn
50" deck with gators,15 hp Kohler
2006 craftsman rider
42"deck with gators,14.5 Briggs OHV
1998 Ariens RM1232e
32" deck,bagger,thatcher,12 hp Briggs
Snow throwers-
1974 White snow boss
24",two stage,5 hp Tecumseh
1986 Toro S620
20",2.5 hp Tecumseh
1992 Toro CCR2000
21",4.5 hp Suzuki
Trimmers-
2002 echo SRM230
2006 cub cadet 4 cycle
2 cycle freak is offline   Reply With Quote
Old 02-26-2010, 12:15 AM   #7
eric67m
Senior MTF Member
eric67m's Avatar
MTF Member # 13240
Thank you oldgardentractornut. I hope to do this conversion to my Jacobsen Manor 21 in the future. Also some of my Briggs might go this way also (briggs makes a conversion but I'm not sure of the price difference.
__________________
I laughed when my high school counselors test said I should work on small engines and equipment......
Now that is what I do for a "hobby".
eric67m is offline   Reply With Quote
Old 02-26-2010, 12:54 AM   #8
Austen
Senior MTF Pollster
Austen's Avatar
MTF Member # 1682
Images: 12
Yesterday 10:41 PM
The kit and the coil were about $40 total. You should be able to install it within and hour, there really isn't much to it. The longest part is just pulling the starter assembly, engine cover and flywheel off.
No problem, keep us updated and ask any questions along the way if you get stumped!
Old 02-26-2010, 01:15 AM   #9
Austen
Senior MTF Pollster
Austen's Avatar
MTF Member # 1682
Images: 12
Here is another site that the kit can be purchased from, http://images.google.com/imgres?imgu...26tbs%3Disch:1
Old 02-26-2010, 06:37 AM   #10
eric67m
Senior MTF Member
eric67m's Avatar
MTF Member # 13240
It sounds like you replaced the coil also? Is that always necessary? Did you just get a new replacement for your jacobsen because your old one had issues?
__________________
Old 02-26-2010, 08:59 PM   #11
bwdbrn1
bwdbrn1's Avatar
MTF Member # 18767
Images: 5
I'm one of those guys that got in touch with Oldgardentractornut about his conversion. I'd seen his thread about his '49 Lawn Queen, and thought it was a pretty sweet mower. I had one offered to me, and because of his posts, I knew a little bit about these mowers, so I took it. It turned out to be a '52, and Oldtractornut has been a wealth of knowledge about these engines.
These old Jacobsen engines had Wico ignition components in them. In answer to eric67m, the coil in mine was bad and had to be replaced.
http://www.mytractorforum.com/showthread.php?t=112957
bwdbrn1 is offline   Reply With Quote
Old 02-28-2010, 01:56 PM   #12
Austen
Senior MTF Pollster
Austen's Avatar
MTF Member # 1682
Images: 12
Quote:
Eric,
I apologize for the delayed response.
I did replace the original coil with the one shown in the first link above in the first post as I bascially wanted everything in the ignition system to be new.
Yes, you could use the stock Wico coil with the Nova kit. You will need to cut off the round connector (the one that would normally connect up to the condenser) and that's what you would splice into the wire leading from the Nova kit up to the coil.
Old 03-01-2010, 10:11 PM   #13
FergusonTO35
Junk collector
FergusonTO35's Avatar
MTF Member # 27883
Images: 2
This needs to be stickied.
__________________
1955 Harry Ferguson TO35
1990 Murray 12HP/38"
1996 Murray 8HP/30"
Lots of weedeaters, chainsaws, blowers
FergusonTO35 is offline   Reply With Quote
Old 06-15-2010, 07:36 AM   #14
eric67m
Senior MTF Member
eric67m's Avatar
MTF Member # 13240
I recently picked up an oregon universal points eliminator kit. It appears to be very much like the nova 2 that you put on your mower. It came with no instructions so I am trying to use the nova's wiring diagram and also the atom's (both are simular). It seems like every wire is bolted to one common stud on the original configuration of the points. The bolt that holds the spring for the points has connectors for...
coil wires, three total on two terminals (blue insulated, silver stranded, and bare copper)
The kill switch wire.(black)
The condenser (red)
I tried to gut the points, remove the condenser. Connected all of these wires and the one to the ignition module together (taped off to prevent grounding. It will not work this way.
The pictures that I included are ....
flywheel and magnets (I think the kit will only work with one magnet.)
coil
Wiring (blue=coil, silver/copper=coil, black unterminated=new to oregon module, black connector=kill switch)
Oregon module, mounted up to the frame (wiring long and loose trying to figure everything out.
Am I missing something or will this kit not work for this engine? Looking for any suggestions. I have been trying and am using a bulb style spark tester to see if it will light up with no results.
Help?
ID:	109044   Click image for larger version
ID:	109045   Click image for larger version
ID:	109046   Click image for larger version
__________________
Sponsored Links
Advertisement
Old 06-16-2010, 10:40 AM   #15
Austen
Senior MTF Pollster
Austen's Avatar
MTF Member # 1682
Images: 12
I would try splicing together the coil primary, the kill switch wire and also the long wire comming from the module. There should be a shorter wire comming from the module and that is your ground wire. At least that is how the Nova kit is set up.
The copper wire on the Wico is a ground wire. I'm not sure exactly though if you would use the silver stranded wire or the blue insulated wire to splice into the other two wires mentioned above unfortunately.
I gotta head out for work now, but I will do a little research and see if I can come up with some more info.
Keep us updated.
Sponsored Links
Advertisement
Reply
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
