DIY Front End Loader - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-09-2010, 10:17 PM   post #1 of 6
Russ.Stevenson
MTF Member
MTF Member # 36503
Default DIY Front End Loader
I bought my first tractor and immediately realized I wanted an FEL. I found a couple of websites and they offer kits with which I can assemble and weld an FEL to fit my AC5030. Does anyone have experience with these kits, and if so, are they viable?
Thanks,
Russell
Russ.Stevenson is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-09-2010, 10:28 PM   post #2 of 6
6279 Lawn Boy
GramPa
6279 Lawn Boy's Avatar
MTF Member # 25099
Default Re: DIY Front End Loader
I don't, but from what I have seen on this forum I would stay away from a kit and start from scratch...if not able to do it yourself maybe you have a friend that is capable. Some FEL built from scratch on here are amazing.
Quote:
Thanks,
Russell
6279 Lawn Boy is offline   Reply With Quote Quick reply to this message
Old 02-09-2010, 11:10 PM   post #3 of 6
TUDOR
9000+ Strong & Climbing
MTF Member # 28463
Go to a tractor dealer with a tape measure and a writing pad, measure everything on a unit that is about the size that will fit your tractor, including the thickness of the steel. Then compare it to the kits. Arms made from 2"x2"x1/8" square tubing won't cut it for your AC5030, as an example.
For a home made FEL, even in kit form, you want it at least as strong, and preferably stronger, than a manufacturers unit. That's structural strength, not hydraulic. That's another issue.
The subframe is critical. If it is stand-alone, it should be strong enough to deal with the FEL forces all by itself. If it is a bolt on, two piece, one for each side rail of the tractor frame, the tractor frame must be strong enough to deal with all that extra load and forces. If the tractor has an integrated power train that is the frame, check with the manufacture for recommended attaching points and load capacities.
Good luck.
Bob
TUDOR is offline   Reply With Quote Quick reply to this message
Old 02-09-2010, 11:13 PM   post #4 of 6
Russ.Stevenson
MTF Member
MTF Member # 36503
Actually, the website is selling the cad drawings for the FEL at a cost $139. I am then supposed to supply my own materials and do the fabicating. The site also says that the FEL will fit my somewhat obsolete Allis Chalmers 5030.
Russell
Old 02-10-2010, 01:01 AM   post #5 of 6
Upper5Percent
5000 Strong & Climbing
Upper5Percent's Avatar
MTF Member # 8602
Russell
Check with these guys http://www.loaders.com/
BEFORE you commit to all that work...
__________________
Paul in VT
The answer is 42
Upper5Percent is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-10-2010, 04:13 AM   post #6 of 6
slkpk
USMC
slkpk's Avatar
MTF Member # 37
Images: 21
I think the first step would be to see if your tractor had a factory option FEL or look for a Hinomoto FEL. Hinomoto made the AC5030 and was the front end of the tractor made heavy enough for FEL work. Good luck, slkpk
__________________
1964 JD RF110 Restored
2004 Ingersoll 318LGT @ the church doing the Lord's work
2007 JD 2305
It's too late to worry about it now!
slkpk is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
