Members List MTF Gallery Add To Favorites! MyLawnMowerForum.com - Lawnmower Forum FAQ
Register Home MTF Gallery Search Today's Posts Mark Forums Read
Reply
Thread Tools Display Modes
Old 02-09-2010, 02:14 PM   #1
cjofpa
MTF Member
cjofpa's Avatar
MTF Member # 33064
Default X500 44-inch Snow Blower
I have a X500 with a JD plow, angle kit, 4 weights on the back, turf tires great all winter up to 6" snows, then we got a 15" heavy Snow. Started right down the middle of my 175 foot slight down hill gravel drive, when it made a right turn into the snow bank and stuck. I got out my 7HP walk behind snow blower and dug it out.
Mind you this is the 4th worst storm in a 12hr period since 1930's but a 44" snow blower is shore looking good. I just bought in Oct 2009 all new. I could have went with a blower. I figured it was easier to store a blade and I have a walk behind snow blower. Less moving parts also.
Can you have a plow installed, buy a used 44inch snow blower, and just switch them when needed? or is it a whole different sub frame and levers?
I would like both. How much time to switch then out if it is possible?
How much for a used 44" off peak season? I could state looking.
cjofpa is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-09-2010, 02:30 PM   #2
djb25
MTF Junior Poster
MTF Member # 32764
Default Re: X500 44-inch Snow Blower
Quote:
CJ,
That's a good question. I have an x500 (also bought in October '09), but I got the 44" blower.
Even though I love the blower, I have thought about getting a plow as well.
Why don't we take a few pictures of our respective machines and compare the setups?
- Damion
djb25 is offline   Reply With Quote
Old 02-09-2010, 05:07 PM   #3
stladrill
2000 Posts and climbing!!!
stladrill's Avatar
MTF Member # 31914
Images: 12
Well guys I just check and the hitch for both the 44" snowblower and the 48'' blade are the same
Part number AM134974 (#20)
44'' snoblower hitch (#3)
__________________
My Video Here
X300"GT" K66 Upgrade Here
My Homemade Rear Blade V2.0 Here
How could you be told I was french?
stladrill is online now   Reply With Quote
Old 02-09-2010, 05:22 PM   #4
subeluvr
Senior MTF Member
MTF Member # 38223
I knew the rock shaft was the same and thought both mounts were the same. Since that's the case the changeover from blower to blade is pretty simple and quick.
Remember, the cutting height adjustment works on both the blower and blade the same as it does on the mower deck... kinda handy if you have a gravel driveway.
Slick tip for the blade is to add Polaris round skid shoes http://mytractorforum.com/showthread...ght=round+skid
I'm gonna add a pair to my 44" blower. Should work better on a gravel driveway than the factory skid shoes.
subeluvr is offline   Reply With Quote
Old 02-09-2010, 05:37 PM   #5
slkpk
USMC
slkpk's Avatar
MTF Member # 37
Images: 15
COOL and another couple of satisfied cutomers . Who's next? slkpk
__________________
1964 JD RF110 Restored
2004 Cub Cadet 2180
2004 Ingersoll 318LGT
2007 JD 2305
It's too late to worry about it now!
slkpk is online now   Reply With Quote
Old 02-09-2010, 05:57 PM   #6
KATT
KATT's Avatar
MTF Member # 34056
I didn't want to say if I wasn't sure, but I did think I had read they were the same hitch. Nice memory stadrill !!
Like I have said in other posts I can change my #44 blower sitting down on my shop stool in way less than 15 min ( never really timed it, didn't need to) except to lie down on the creeper to release the belt.
KATT is online now   Reply With Quote
Old 02-09-2010, 08:16 PM   #7
cjofpa
MTF Member
cjofpa's Avatar
MTF Member # 33064
Stladrill thanks for the info. Where are you getting the diagrams from?
This forum is great guys thanks.
djb25
Here are some pics to compair.
Old 02-09-2010, 10:04 PM   #8
AVR Mark
MTF Member
AVR Mark's Avatar
MTF Member # 7731
I have both the blower and the blade and they are an easy swap. You might find it easier when swapping to also swap the forward (outside) adjusting rod (part 18 in the diagram) as, at least in my case, the two rods are adjusted a bit differently. I bought the blower first and then bought a used blade so I can do maintenance on my driveway.
Mark
__________________
'08 JD X534, 48" Edge Deck, 44" Snow Blower, 10P Cart, BM23048 48" Blade, 40" Thatcherator with 8" Extension. Bear Cat 70050 chipper/shredder, Stihl FS-106 Brush Cutter, Craftsman 42" HS Lawn Sweeper, Honda HR214PX Mower.
AVR Mark is online now   Reply With Quote
Old 02-09-2010, 10:55 PM   #9
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 12
From John Deere Web site
http://jdpc.deere.com/jdpc/servlet/c...ageServlet_Alt
Just enter the model number and you will find every thing you want, part number diagram etc...
__________________
My Video Here
Old 02-10-2010, 03:19 PM   #10
Sergeant
Sergeant's Avatar
MTF Member # 24
I was looking at the X300 Blade sorry for the wrong information.
__________________
JDX485 w/ 45loader,48inch deck,42inch hydraulic tiller,54inch dozer blade w/quick hitch & Weather Enclosure,JD140H3 w/ Integral hitch,3point hitch & 54inch dozer blade,JD112w/Integral hitch & brinly cultivator,White GT2055 w/kwickway loader,Ingersoll 3016PS,Cub Cadet Original,Cub 70,Cub 106,Cub2206,1970's experimental Cub Cadet Rear engine rider,Simplicity 7016 and a Simplicity wonder boy
Sergeant is offline   Reply With Quote
Old 02-10-2010, 07:42 PM   #11
Yankees251
MTF Member
Yankees251's Avatar
MTF Member # 31939
Images: 3
My two cents: Save your money, keep the blade and your walk behind. A heavy 17 inch snow, which is rare in your parts, is probably not worth the additional blower investment. If you split that once a year storm into two manageable jobs I'm sure your rig with blade would've handled it just fine.
Yankees251 is offline   Reply With Quote
Old 02-10-2010, 07:51 PM   #12
subeluvr
Senior MTF Member
MTF Member # 38223
Quote:
I might agree if there was a larger price difference between the blade and blower.
For an X500 the blade (with pivoting control kit) is right at $1000 and the blower is $1500... for the extra $500 I have to have the blower.
Working snow with the blade is harder on the tractor than using the blower.
I've had both and the blower just works better, faster, and you move the snow ONCE.
Old 02-11-2010, 10:10 AM   #13
cjofpa
MTF Member
cjofpa's Avatar
MTF Member # 33064
I agree with all of the above. I may have a space issue during winter. I have a two stall garage with a 16 foot door. I park the tractor and walk behind on the side my truck parks on.
Can someone tell me the storage dimensions of a 44" blower on an X500 when the snow blower in on the tractor.
And just the blower when it is off.
When it is off, it would need to replace the space I now have the walk behind blower.
Or on the wish list........ build another shed or on the wish list pretty low down...3 car Garage up by the house
Old 02-11-2010, 02:15 PM   #14
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 12
9 feet 1/2 with the weight on the back.
The blower is about 32 inch by 44 when off the tractor.
__________________
My Video Here
Old 02-11-2010, 07:50 PM   #15
mhussey
Senior MTF Member
mhussey's Avatar
MTF Member # 35164
Images: 2
I have a 22x24' garage and only a 12' door. My truck is parked on one side and I can still drive out/back in my machine with the 44" blower. It is 9' long and 44" wide. Next year maybe tricky when I replace the overhead door with a 16' one that way my wife can park in the garage. I dont think I'll be able to fit the 155C, my F150 and the wifes escape all comfortably inside but i'll try!
__________________
2006 John Deere 155C:
44" Blower,48" MMM 56 Hrs.
Husqvarna 50DK pushmower
Husqvarna 125C trimmer
Husqvarna 455 Rancher 20" chainsaw
mhussey is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
