| Members List | MTF Gallery | Add To Favorites! | MyLawnMowerForum.com - Lawnmower Forum | FAQ | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| John Deere Forum John Deere Garden Tractor talk |
Thread Tools | Display Modes |
#1 |
Senior MTF Member
MTF Member # 28799
Does anyone know if JD still stocks the plastic, filled wheel weights for the 318?
I'm assuming they do since they still use the same tire size. Any idea what a set might run me?
__________________
1987 John Deere 318 50" Deck 54" 4-way Snow Blade Cat-0 Ruegg 3 PT Rebuilt Onan and Fresh Paint |
| Sponsored Links | |
Advertisement |
#2 |
3K Poster!!!!
![]() ![]() Join Date: Nov 2008
MTF Member # 20164
You can still get either plastic covered concrete or cast-iron rear weights for the 318.
JD also offers front weights, but I am not sure if they are plastic covered concrete or cast-iron |
#3 |
Senior MTF Member
MTF Member # 20758
The ones they sell for current X500 tractors will fit the 318. I bought a pair a little over a year ago for my X540 and they cost me $110.
#4 |
3K Poster!!!!
![]() Join Date: Sep 2009
MTF Member # 31960
Yes, my Wife and Son bought me a set at Christmas (Plastic).
__________________
#5 |
Senior MTF Member
MTF Member # 35996
i go to a junk yard and try to find a lawn tractor with the cast iron wheeel weights than buying plastic.
__________________
theres one saying to live by. NEVER ARGUE WITH AN IDIOT, YOU WILL JUST LOWER YOUR SELF TO THERE LEVEL AND THEY WILL BEAT YOU WITH EXPERIENCE EVERY TIME. |
#6 |
Senior MTF Member
MTF Member # 28799
Picked up a cement pair, $110 isn't bad.
Now the tractor isn't charging, so the implement is picking up this afternoon to look at it. IN the middle of a snow storm, just my luck.
__________________
#7 | |
3K Poster!!!!
MTF Member # 20164
Quote:
I'm happy with my plastic weights, especially considering the price (the gas to go pick them up). |
#8 |
Senior MTF Member
MTF Member # 28799
they just picked it up, hopefully i can get it back within the next couple days. I'll get the wheel weights on it and a 3 pt from Ruegg (if the repair bill isn't too high). My FIL is a good welder, I'll have him make me a ballast box and start lookin at the or-bilt a little harder.
__________________
#9 |
Senior MTF Member
MTF Member # 28799
Now that I have some down time until my machine comes home, can someone show a diagram of installing the plastic weights? There is some threaded rods, lock nuts, and flange nuts included as mounting hardware.
__________________
#10 |
Internet Swimming Lessons
MTF Member # 34573
Threaded rod through 2 of the holes on your wheel, slide the weights over the rods, and bolt on. I prefer using 8" carriage bolts, as the square heads fit rit into the square openings in the wheels. Simple, but can be a pain. The 8" bolts are nice for the plastic 70lb weights.
__________________
#11 |
3K Poster!!!!
MTF Member # 20164
Glockem used a long piece of all-thread supported by a jack stand on the outside to slide the weights into place and hold them there while he fastened his carriage bolts.
#12 |
3K Poster!!!!
MTF Member # 31960
The plastic ones weren't hard to put on had my BIL help and only took a few minutes! Hardest thing was getting the rod in and sized right to leave just enough space to thread the outside nut and bolt!
__________________
#13 |
Senior MTF Member
MTF Member # 28799
I got them on last night. They weren't all that bad to put on. I noticed they help dramatically on slippage when backing up a hill or pushing a big snow pile with the blade. Next, is the 3 pt.
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
