Another Tecumseh POS. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 02-06-2010, 05:17 PM   post #1 of 18
hivolt07
Mr. Haney
hivolt07's Avatar
MTF Member # 18533
Images: 3
Default Another Tecumseh POS.
Ok, well I've had much luck with all my older Tec engines, but I have 2 newer ones that give me nothing but trouble. One's on my tiller and the other is on my dad's snow thrower.
I wanna ask you guys about the one on the snow thrower. It's an 8hp. My problem is that when you put a load on the motor, it throttles itself way back and almost dies. You have to play with the throttle lever to keep it from dying. It has to be run in first gear to blow 2inches of snow. Anything more than 4inches...forget it. Is this a govenor issue or could there be something else wrong?
__________________
Craig
'87 Craftsman II 18 hp
2 other Craftsman IIs 18 hp
'65 Sears Craftsman 7hp
'98 Murray Select 16 hp
'61-'62 Economy Jim Dandy
"68 IH Cub Cadet 105
hivolt07 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-06-2010, 05:27 PM   post #2 of 18
BillTheTractorMan
Tractor addict
BillTheTractorMan's Avatar
MTF Member # 30045
Images: 6
Garage
Default Re: Another Tecumseh POS.
I don't know exactly what the answer is, but I would asume the same, as or tecumseh's I think anything you get now is a chinese one, the chinese also baught out another small engines company aswell just can't remember the name.
__________________
Sears GT group (suburbans/customs/etc)
http://www.facebook.com/groups/101589189889692/
Growing website for user based uploads about Sears tractors. (file sharing, forums for posting and reading guides, etc)
http://www.mysearstractor.com/
BillTheTractorMan is online now   Reply With Quote Quick reply to this message
Old 02-06-2010, 05:56 PM   post #3 of 18
hivolt07
Mr. Haney
hivolt07's Avatar
MTF Member # 18533
Images: 3
Quote:
They don't make Tecumseh anymore and as far as I know they were always american made. Probably because the chinese don't know how to say Tecumseh.
This one is from the mid 90s.
__________________
Craig
Old 02-06-2010, 06:08 PM   post #4 of 18
johnboggs21
The Link King
johnboggs21's Avatar
MTF Member # 9494
sounds like it could be a governor issue. What kinda governor is on there?
Probly wouldnt hurt to run a lil carb cleaner through it
__________________
I'm gonna sign my name in that diesel smoke and let the ones that come along behind me choke!
1993 Ford F-250HD 7.3L IDI 370,000 miles
Just follow the diesel fumes and the banjo music
http://murray.forumotion.com
johnboggs21 is offline   Reply With Quote Quick reply to this message
Old 02-06-2010, 06:18 PM   post #5 of 18
freebird
Camaniac
MTF Member # 63
Also to check that governor linkage. Might be sticking/binding on something.
__________________
1956 Cub Lo-Boy
JD LA175
JD LT133
JD RX73
Sears 16/6
If you can't fix it with a hammer, it must be an electrical problem!
freebird is offline   Reply With Quote Quick reply to this message
Old 02-06-2010, 06:30 PM   post #6 of 18
BillTheTractorMan
Tractor addict
MTF Member # 30045
Images: 6
Garage
From what I read was tecumseh was competing with a chinese company, I have never seen this companys engines but tecumseh ended up dropping their small engine line. I don't know if the chinese are popping tecumseh engines out, just heard they could be.
Sorry, I'm not try to hijack the thread, just had to drop that in.
__________________
Old 02-09-2010, 02:08 AM   post #7 of 18
Rescuemo
Senior MTF Member
Rescuemo's Avatar
MTF Member # 28881
Sounds also like a carb issue to me. My Toro mower was going way down when I engaged the blades, RPMs dropped by almost half. Double checked my carb settings and the main metering jet was out too far. Screwed it all the way in and back out 1.5 turns, ran perfect. Holds speed perfectly well now. You could very well have some dirt/grime in the carb. Those Tecumseh carbs of that era weren't very good.
__________________
Morris H.
Wendell, NC
1967 Toro Whirlwind Grassking (2), 1949 Simplicity Walk-Behind tractor (2), 1985 Snapper 25" Hi-Vac RER, Sears Craftsman Snapper Hi-Vac, Lotsa piles of junk and parts and motors and...
http://budgethomerepair.wordpress.com
https://www.facebook.com/profile.php?id=668086588
Rescuemo is offline   Reply With Quote Quick reply to this message
Old 02-09-2010, 02:57 AM   post #8 of 18
johndeere
3K Poster!!!!
johndeere's Avatar
MTF Member # 207
Images: 7
I here Techumseh is no good often.I have a 11hp OHV Techumseh Snowking on my Simplicity 11-32 Comercial snowblower.I think its the last year Simplicity used that engine before switching to Briggs when they bought them out a few years back.It about 4 years old.It knock on wood has been a excellent engine.Starts on the first pull and has more then plenty power.Actually runs better under heavy loads then ideling.
When I was a kid I had a minibike with a Techumseh 3.5 hp I think it was and it was abused terribly by my self and brothers and neighbor kids.Until one day the rod went thru the block.We were kids I never checked the oil We also had a Massey Ferguson #7 lawn tractor with a Techumseh it also had a rod go thru the side of the block.But after many hours and several years of use.Several neighbors and realatives also had the same Massey and had all kinds on trouble with there engines.But much earlier then ours.We also had a John Deere garden tiller with a 6hp Techumseh that was worthless.It did basically the same thing you mentioned just was a dud.Dad sold the tiller and swore he would never own another Techumseh.
Seems many of them were a real POS but I know of a few that have done OK also.
johndeere is online now   Reply With Quote Quick reply to this message
Old 02-09-2010, 06:44 AM   post #9 of 18
Ingersoll444
ex spelling bee champ
Ingersoll444's Avatar
MTF Member # 16
Images: 14
Whenever I have a running issue with these I assume carb. To put it blunty the carbs they have used for at leat the last 20 years are JUNK! They take NO abuse at all, and 1/2 the time you cant clean them right. I would pull the bowl, and look for that jelled mess in there. Make sure ALL the little holes are clean in the carb nut that holds it on.
__________________
Paul B
Visit The Case Ingersoll Colt Forum.
SUPER Of The Month 10/2011
Ingersoll444 is offline   Reply With Quote Quick reply to this message
Old 02-09-2010, 10:09 AM   post #10 of 18
ETpilot
Senior MTF Member
MTF Member # 37138
The last Tecumseh I had, the carb gave me fits. I overhauled it once and then cleaned it out a couple of time. I finally replaced the engine with a B&S. Check the enginge linkage and make sure it is clean and well lubricated. If not the governor, it could be carb.
ETpilot is offline   Reply With Quote Quick reply to this message
Old 02-09-2010, 10:10 AM   post #11 of 18
BushBoneYard
5000 Strong & Climbing
BushBoneYard's Avatar
MTF Member # 31379
Images: 12
Garage
I can't help ya, but the 5hp Snow King on my snowblower is indeed a genuine, bonafide no holds barred POS! I guess that's why they are $129.00 new. When I am shoveling tomorrow the whole time I will be muttering "Tecumseh POS".
__________________
1977 Murray Built Sears ST 10 Yard and Garden Tractor
1984 Murray 39004 Garden Tractor
1999 Murray 46500 Lawn Tractor
2007 Husqvarna Built Craftsman YS4500
MurrayOwnersWorld.com
M.O.W. Facebook
Contact: bushboneyard[at]gmail.com
BushBoneYard is offline   Reply With Quote Quick reply to this message
Old 02-09-2010, 10:34 AM   post #12 of 18
johndeere
3K Poster!!!!
johndeere's Avatar
MTF Member # 207
Images: 7
Quote:
That would make you mutter ''Techumseh POS''
Old 02-09-2010, 10:46 AM   post #13 of 18
Ingersoll444
MTF Member # 16
Images: 14
I just kick mine every time I walk by.
__________________
Paul B
Old 02-09-2010, 10:47 AM   post #14 of 18
BushBoneYard
MTF Member # 31379
Images: 12
Garage
Quote:
Yes, because it does not run and when it does it runs poorly regardless of proper maintnance and repair. At $129.00 they {Small Engine Warehouse} still can't get rid of 'em. A Chinese knock off from HF the last time I checked was more expensive and probably more dependable. So, yes, I will be muttering "Tecumseh POS" as I walk by it snow shovel in hand, meanwhile my neighbors Briggs will be purring like a kitten. It might just be me, but I have yet to read on any forum "My Snowking is awesome". I'm not brand bashing, I have read nothing but bad things about these engines and my personal experience has been aggrevating at best........mine will shortly be on the scrapyards scale.
__________________
M.O.W. Facebook
Sponsored Links
Advertisement
Old 02-09-2010, 01:22 PM   post #15 of 18
hivolt07
Mr. Haney
hivolt07's Avatar
MTF Member # 18533
Images: 3
Quote:
You too.
__________________
Craig
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
