Liquid Tire Ballast - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Miller Tire Co. : On our website you will find the largest selection of antique farm tractor tires and wheels available anywhere... plus much more
Reply
Thread Tools Display Modes
Old 02-05-2010, 03:43 PM   post #1 of 14
millertire
Senior MTF Member
millertire's Avatar
MTF Member # 35950
Default Liquid Tire Ballast
Miller Tire has discontinued using Rim Guard (beet juice). While it is non-corrosive, it has its disadvantages.
• Harder to pump in cold conditions
• Solids tend to settle over time and can’t be pumped out of the storage tank
• Cannot mix Rim Guard with other liquid ballast or it may foam
• All hoses and couplers must be air tight or foaming will result
• If you use too much air pressure during installation, it will foam.
• If it foams, you need to wait for foam to settle before finishing filling tire.
• It smells.
Miller Tire now uses “windshield washer/antifreeze fluid” even though at 8.3 lb/gal it is lighter than chloride & Rim Guard at 10.7 lb/gal
When filling tires, only fill to the top of rim. You need to leave an air cushion in the tire. You can put washer fluid in tubeless tires without tubes.
Miller Tire sells the air/water adapter tool for filling tires.
www.millertire.com
millertire is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-05-2010, 09:42 PM   post #2 of 14
DJ in WV
I Love All Color Tractors
DJ in WV's Avatar
MTF Member # 10462
Images: 6
Garage
Default Re: Liquid Tire Ballast
Sounds as though it is being discontinued due to it being a pain for the dealer and not due to shortcomings or adverse effects to the consumer, and of course cutting into your profit margins due to lost time.
__________________
MyTractorForum.com House Rules
Looking for a Technical Exchange Article? Here's an Index!
My YouTube Page
My Equipment:
1970 Gravely C10A
1972 Gravely 816
1973 Gravely Model C8
Eight other Gravely C's, L's, and LI's
1978 Massey Ferguson 1655
1981 Troy Bilt Horse, 7HP Kohler
1982 Gravely 8123
1983 Troy Bilt Junior
1988 JD 950, 75 Loader, 8A Backhoe
DJ in WV is online now   Reply With Quote Quick reply to this message
Old 02-20-2010, 05:19 PM   post #3 of 14
ralphtt
MTF Member
ralphtt's Avatar
MTF Member # 28167
So, Rim Guard is 29% heavier than windshield washer antifreeze (10.7 vs 8.3 lb/gallon).
For the consumer, that is a significant advantage in favor of Rim Guard.
__________________
Ralph
Benefactor Member NRA
2012 2520 w/loaded rear tires
CX200 FEL w/Markham Toothbar
62D MMM
iMatch Quick Hitch
Heavy Hitch w/eight JD suitcase weights
Herd 96 Spreader
Artillian Forks
ralphtt is offline   Reply With Quote Quick reply to this message
Old 03-01-2010, 12:11 AM   post #4 of 14
crazyfarmer
MTF Junior Poster
MTF Member # 29593
I have Rim Guard and love it its in 16.9x24 tires. woke up my tractor.
crazyfarmer is offline   Reply With Quote Quick reply to this message
Old 12-14-2010, 09:04 PM   post #5 of 14
rfowler
Senior MTF Member
rfowler's Avatar
MTF Member # 46333
Images: 1
Garage
Quote:
DJinWV, I'm with you.
__________________
2010 X728
Mulch kit
Rear Quick hitch
Rear weight bracket
10P cart
rfowler is offline   Reply With Quote Quick reply to this message
Old 12-14-2010, 09:13 PM   post #6 of 14
rfowler
Senior MTF Member
rfowler's Avatar
MTF Member # 46333
Images: 1
Garage
Quote:
Gotta go with ralphtt and crazyfarmer too. Thanks for all the input guys!
__________________
2010 X728
Mulch kit
Rear Quick hitch
Rear weight bracket
10P cart
Old 12-14-2010, 09:18 PM   post #7 of 14
rfowler
Senior MTF Member
rfowler's Avatar
MTF Member # 46333
Images: 1
Garage
Wish I had known about this before I bought the suitcase weights (less stress on the axles). I guess the more weight the better (to a point). I only hope I have not exceeded that point!
__________________
2010 X728
Mulch kit
Rear Quick hitch
Rear weight bracket
10P cart
Old 12-15-2010, 12:07 PM   post #8 of 14
X485SENoob
Another Day in Paradis...
X485SENoob's Avatar
MTF Member # 52400
Garage
I called a local tire dealer to get a price on loading my tires. This is a pretty big regional dealer with a couple dozen locations in this area. He told me loading the tires doesn't do much for small tires, only for the bigger tractor tires. He seemed to know what he was talking about, and had the perfect opportunity to sell me this service - but he talked me out of it. This flies in the face of everything I've heard on this site. Any thoughts?
X485SENoob is online now   Reply With Quote Quick reply to this message
Old 12-15-2010, 01:21 PM   post #9 of 14
mhussey
Senior MTF Member
mhussey's Avatar
MTF Member # 35164
Images: 1
Yup, I had the max 2 suitcase weights (and chains) on my 155C...I did not like how it struggled for traction at times and I could easily spin the tire if I was not careful. I then would make sure I had a full tank of gas to take advantage of the weight and added a 35# dumbell ontop of my 84#'s of rear suitcase weights. It was better but still not quite right. I then asked about having the dealer load my tires. He pretty much talked me out of it as well. So, I went ahead and filled my own with winshield washer fluid (wwf). It was cheap (especially since I had 4 gallons in stock) and added close to 50# per tire if I recall correctly (if interested I have pics somewhere while the tire is filled on a scale). The difference was noticeable and definately worth it. It was worth it in the summer as well because the tire would not spin on wet grass or steep inclines.
For my X540 and the 47 blower combo, the rear weights is not enough with out chains. I just bought wheel weights (easier to install the liquid ballast and definately more convenient to remove). I will lower the PSI to 4 as recommended by other users and Im sure this will be the right combo.
__________________
2010 John Deere X540:
54" MMM,47" Blower,44" Blade,56" Front Dethatcherator,
10P cart, and 42" Lawn Sweeper
Traded: 2006 John Deere 155C: 44" Blower-48" MMM
mhussey is offline   Reply With Quote Quick reply to this message
Old 12-19-2010, 03:24 PM   post #10 of 14
username
Senior MTF Member
MTF Member # 39306
Quote:
With some exceptions,tire size is generally relative to tractor size so I fail to understand how it could make little difference traction wise with small tires and make big differences with big tires.
50 lb of weight added to a 500 lb mower I would think would add the same increase in traction as 500 lb added to a 5000 lb tractor.OK,I didn't check my math to see if the percentages work out but I think you can see the point I am trying to make.I am not stating this as a fact,this is just how I understand it.
username is offline   Reply With Quote Quick reply to this message
Old 12-19-2010, 06:37 PM   post #11 of 14
Cat385B
MTF Member # 22567
Images: 4
Garage
Liquid ballast is the most effective weight you can add to the tractor. It's the only way to add weight exactly where you need it, where the rubber meets the road. Wheel weights transfer part of their weight to the axle. While that is still exerting down pressure on the tires, its doing so by putting weight on components other than the tires. Most GT's can handle that just fine, but these machines aren't getting any newer nor is the metal getting thicker. Suitcase weights, ballast boxes, and a rich protein, dairy, and barley diet coupled with a lack of exercise all add weight to tires, but at the expense of more weight on the frame.
I have 23x10.5x12's on my snow blowing tractor. I used 7.5 gallons per tire when loaded earlier this winter. That gets me 62 pounds right on the contact patch, without loading anything else up. I was still going to keep my eye out for the wheel weights, but now only if I get a smoking deal on a set. I have so much traction I worry that the chains are going to get ground into the rubber.
Cat385B is online now   Reply With Quote Quick reply to this message
Old 02-09-2011, 10:14 PM   post #12 of 14
locopny
MTF Member
MTF Member # 55179
so you leave this in all year? sounds like a perfect solution for my traction issues.
__________________
8? JD 400- Cozy cab, JD 60" deck, 54"blade, 3point, rear pto, tiller, model 50 blower, Gannon Earthcuvator 42", Ag and Turf tires.
2011 JD D140 48" deck and warranty-30 hrs.
92 JD 2955-148 loader/grapple,cab,heat,air,3PT
67 JD 4020-running again after 7 yrs..needs fine tuning
71 MF 7 awaiting rebuild.
Estate rake
locopny is offline   Reply With Quote Quick reply to this message
Old 01-26-2012, 05:45 PM   post #13 of 14
GT_80
Cranky Motorsports
GT_80's Avatar
MTF Member # 35886
Images: 32
Garage
I run Washer Fluid in my tires- My supermarket sells it for $1.50 a gallon, it's easy to load (if you break the bead on the tire) or if you use the air water separator, it's slow, but still loads well. The nice thing is, if you spill some, it will clean the tire up when wiped with a rag, and being as it is alcohol based will all evaporate if the tire blows. Adding 7 gallons to each rear tire on my garden tractor made a huge difference in traction! Like adding 2 sets of wheel weights to each tire!
__________________
MTF Addict #35886
Hugh-SS/16 fan #0001
Tractors:
1968 Super12 "Miss Emma Lee"
1967 Suburban 12 "The 679"
1973 SS16/ 18/6 hybrid "Mighty Mongrel"
1976 SS18 "Trusty"
1978 GT18 with Hard cab - home again!
Attachments:As many as I can get
My YouTubeMy Ebay
Sears Manuals
GT_80 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-02-2012, 12:19 PM   post #14 of 14
Pokey
Senior MTF Member
MTF Member # 55012
I gotta chime in with a thumbs up for Rim Guard. Each rear tire/wheel combo on my Cub 1862 weighs 112 lb when filled with Rim Guard. I can completely understand Miller Tire's choice to discontinue the use of Rim Guard from an installers stand point, however.
Pokey is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
