Ford 1920 with Loader Problems - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-03-2010, 07:59 AM   post #1 of 5
garyabel
MTF Junior Poster
MTF Member # 38092
Default Ford 1920 with Loader Problems
I have a Ford 1920 with a Ford 7108 loader. When the engine is running, the front bucket will roll down on its own very slowly. This occurs when the tractor is running or not. both bucket cylinders are not leaking from the outstide, and I cannot hear fluid seeping by the joystick control valve.
What do I need to check or Replace?
garyabel is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-03-2010, 09:03 AM   post #2 of 5
John@Reliable
Banned!
MTF Member # 37003
Default Re: Ford 1920 with Loader Problems
I would start with the control linkage adjustment, then valve or valve body o rings. I also assume their no puddle on the floor, bad fitting/hose.
Here's a link to part break down and Description, hope this helps John
http://www.tractorbynet.com/forums/p...front-end.html
John@Reliable is offline   Reply With Quote Quick reply to this message
Old 02-03-2010, 09:58 AM   post #3 of 5
mhb@ufe
Senior MTF Member
mhb@ufe's Avatar
MTF Member # 1102
Images: 4
One or both of the bucket cylinders could be leaking by internally. You could check it by removing the hoses and plugging them to seperate them from the valve.
__________________
I used to know everything but I forgot most of it
Mark
Maines Antique Tractor Club:
http://www.maineantiquetractorclub.com/
mhb@ufe is offline   Reply With Quote Quick reply to this message
Old 02-03-2010, 11:55 AM   post #4 of 5
donimbimbo
1981 Ford 1100 4WD
donimbimbo's Avatar
MTF Member # 18958
If it is only bucket curl then I would suspect the cylinders. But if you want to try a quick test, swap the lines on the valve assembly between the lift cylinders and the curl cylinders. If the curl still drifts then it's the cylinders not the valve.
__________________
Ford Mustang 1990
Ford 1100 Tractor 4WD 1981
Ford LGT14H Tractor 1988
Subaru Forester 2014 (Wife's car)
Honda 1100 Shadow Sabre 2000 (being restored)
donimbimbo is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-19-2010, 09:23 PM   post #5 of 5
jameskuykendall
MTF Junior Poster
MTF Member # 46545
Has anyone changed the king pins on a Model 1920 two wheel drive. Is there a complete kit or do I need to buy each part separately? Any hints on how to do it well?
jameskuykendall is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
