Kubota B7100 4wd Problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-31-2010, 04:46 PM   post #1 of 3
JAN MCPEEK
MTF Junior Poster
MTF Member # 38005
Question Kubota B7100 4wd Problem
Just bought a Kubota B7100 at auction. This has a standard transmission, not hydrostatic. Have never owned a tractor before. Everyrthing seems fine except that it will not go into 4WD. 2 wheel drive is perfect and am able to change gear ranges. I have moved the indicated 4wd lever up and down but can get not get it into 4WD. There were no indications of a problem, such as grinding or difficulty in moving the lever. What could the problem be? Thanks
JAN MCPEEK is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-31-2010, 08:34 PM   post #2 of 3
Volfandt
Machinery enthusiast
Volfandt's Avatar
MTF Member # 164
Images: 1
Default Re: Kubota B7100 4wd Problem
Welcome aboard JAN MCPEEK.
Since it's new to you, I'd recommend to give it a good exterior going over, making sure everything thats supposed to be there, is.
Then if you can either get someone to drive while you observe or visa-versa, look to see if the front drive shaft is spinning. Basically you want to isolate the problem to the tranny or the front differential.
It could be that the shifter isn't engaging, due to it being broke, worn or just popped out. I'm not sure on your model but you may be able to access the tranny from the top plate.
Good luck and let us know.
Dave
__________________
2004 Kubota BX23 w/60" MMM, Thumb, AM/FM/CD.
http://www.mytractorforum.com/showth...highlight=BX23,
1966 Wheel Horse 856, Gear.
1966 Wheel Horse 876, HST.
w/50" sicklebar mower, 36" rotary mower, snow blade, alternator/welder.
http://mytractorforum.com/showthread...hlight=856,876
The USMC, providing the enemies of the USA the opportunity to die for their country since 1775.
Volfandt is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-31-2010, 11:14 PM   post #3 of 3
Bellinghamster
MTF Junior Poster
MTF Member # 35475
How did you determine that 4wd is not working?
Loosen the hose clamp on the rubber boot that seals the front driveshaft tube to the front differential, slide the tube up (away from the differential) and make sure there is actually a driveshaft in there. Jack up one side of the tractor, put it 4wd and neutral, turn one rear wheel by hand. Does the front driveshaft turn? If so (assuming it's there!) then the front differential or U-joint spline is shot. If not, then it could be the rear U-joint or transmission output spline, or the shift fork broken or bent. There is a hole in the bottom of the transmission tunnel you can look up into to see the rear U-joint.
Exploded parts diagrams can be found at www.messics.com, and www.kubotabooks.com
Bellinghamster is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
