Is this snow plow for a narrow frame? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-29-2010, 03:05 PM   post #1 of 22
Squiner
MTF Member
MTF Member # 24286
Default Is this snow plow for a narrow frame?
Check out the craigslist link. I checked the measurements and I think the 10 3/4" will marry up with my narrow frame 126. Wanted to check before I go pick it up. If anyone knows, let me know.
http://baltimore.craigslist.org/grd/1573714867.html
Squiner is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-29-2010, 03:15 PM   post #2 of 22
RBedell
Proud Member of the 1K Club
RBedell's Avatar
MTF Member # 463
Default Re: Is this snow plow for a narrow frame?
As best as I can tell, that is a Sub Frame for a NF Cub.
The actual blade itself, is the same no matter what frame.
BTW, it would be a 42" or a 54" blade. IH never built a 48" model.
__________________
CC models: 100, 105, 129, 1450, & 784
Only Cub Cadets
Buy: Made in the USA
RBedell is offline   Reply With Quote Quick reply to this message
Old 01-29-2010, 05:55 PM   post #3 of 22
Squiner
MTF Member
MTF Member # 24286
Well I went and got the blade. Now that I have it home you can see some better pics. I'm starting to think that the blade is not CC but I really have no idea. It is 48" wide. I hope it can be reassembled without modifications.
Does anyone have a good pic of an assembled plow so i can figure out how it goes together?
Old 01-29-2010, 06:11 PM   post #4 of 22
RBedell
RBedell's Avatar
MTF Member # 463
Looks like a CC blades but for the newer models...
__________________
Only Cub Cadets
Old 01-29-2010, 06:24 PM   post #5 of 22
Squiner
MTF Member
MTF Member # 24286
Quote:
Well I got some together. Now how do I go about getting these two pieces together? Do I need to bend the arms out since the bar is welded?
Also, this blade does not have spots for the springs to attach. Why would that be?
Old 01-29-2010, 06:27 PM   post #6 of 22
Cub Cadet Head
Senior MTF Member
MTF Member # 21798
Glad we got that cleared up... I've got one at my Brothers place that looks exactly the same and I didn't know what it fit for sure either, thanks Roland.
Now I guess the question is; Will that blade mount onto the subframe that he has?
Woops, I pulled the trigger a little late here... Sorry.
Cub Cadet Head is offline   Reply With Quote Quick reply to this message
Old 01-29-2010, 06:35 PM   post #7 of 22
Cub Cadet Head
Senior MTF Member
MTF Member # 21798
As Roland said, that blade is for a different style Cub, not sure that blade even goes with that sub-frame.
You are probably going to have to fabracate something to make it work right, or take it back and get a refund.
Before you get too carried away you should check to see if that sub-frame will mount on your tractor. Then worry about getting the rest of it hooked up.
Old 01-29-2010, 07:09 PM   post #8 of 22
Squiner
MTF Member
MTF Member # 24286
The sub frame mounted up good
Now I still have to get the blade connected to the subframe some how. I see people selling the subframes alone. How do you make that connection, bend the subframe, seems like a bad design if that's the case.
Thanks
Old 01-29-2010, 07:21 PM   post #9 of 22
Cub Cadet Head
Senior MTF Member
MTF Member # 21798
Glad it fit up well.
Yes, spread the sub-frame apart to get it on the pyramid, they really are pretty "springie".
Don't know exactly what to tell you about the springs, but you don't want to hit anything solid that is buried in the snow with the blade in the locked position like it is in the pic..
Old 01-29-2010, 07:29 PM   post #10 of 22
Squiner
MTF Member
MTF Member # 24286
Glad it fit up good.
Now that I have the subframe on the tractor I'm trying to spread it to accept the pyramid. Funny thing I learned. A car jack will not work on it's side but it does a good job pissing the operator off.
Looks like I'll have to pull the subframe so I can use the car jack in the upright position to spread it.
I'll just drill some holes in the blade for the springs. It came with a new set of springs too.
I hope we get some snow in northern maryland from this storm so I can try it out .
I'll get some pics when I'm done.....thanks for the help!
Old 01-29-2010, 07:36 PM   post #11 of 22
Cub Cadet Head
Senior MTF Member
MTF Member # 21798
Good luck.
Old 01-29-2010, 07:42 PM   post #12 of 22
junior1282
Senior MTF Member
junior1282's Avatar
MTF Member # 34616
This should give you an idea of where to put your springs, You will need the pin to adjust it from side to side.
Name:	original 4 000003.JPG
ID:	91130   Click image for larger version
Name:	original 4 000007.JPG
__________________
1986 cub cadet 1210
1984 cub cadet 1282
1981 International cadet 182
1967 Cub Cadet 102x2
1966 Cub Cadet 71 Pull Start
1965 Cub Cadet 100
1965 Cub Cadet 70
1961 Cub Cadet Original #3646
Junior
junior1282 is offline   Reply With Quote Quick reply to this message
Old 01-29-2010, 07:55 PM   post #13 of 22
Squiner
MTF Member
MTF Member # 24286
Quote:
Thanks junior, I'll drill them out tomorrow. I have the pin, just need to install it.
Here it is mounted up. That subframe was pretty springy Cub Cadet Head.
Old 01-29-2010, 08:11 PM   post #14 of 22
junior1282
Senior MTF Member
junior1282's Avatar
MTF Member # 34616
Looks good I wish mine was 48" wide. I also like you skids those look like they will work good. Good luck with your springs tomorrow. Buy the way good looking tractor!!
__________________
1986 cub cadet 1210
1984 cub cadet 1282
1965 Cub Cadet 100
1965 Cub Cadet 70
Junior
Sponsored Links
Advertisement
Old 01-29-2010, 08:52 PM   post #15 of 22
northstar1958
Senior MTF Member
MTF Member # 36917
Nice job Squiner....
Looks like it will push a healthy amount of snow. I'm also curious about what RBedell posted about blades being the same NF/WF....the only difference is the sub frame?
Am i correct to assume the blade will fit both sub frames?
Northstar
northstar1958 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
