old wizard tiller with 5hp b/s. rebuild or repower? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 01-21-2010, 12:55 AM   post #1 of 40
tpolley
Senior MTF Member
tpolley's Avatar
MTF Member # 32442
Default old wizard tiller with 5hp b/s. rebuild or repower?
dad gave me the old wizard tiller today. it currently has a briggs 5hp horizontal shaft. the tiller is 30-40 years old. the engine was swapped in '96 or '97 with some junk that was behind my buddys dads shop. it hasn't ran since. i don't know the history or condition of the internals of the engine. i spent the evening tinkering with it. it had no spark so i took the flywheel off and the wire from the magneto to the point is bare in spots. i figure i can buy the parts for $30 to $40 and fix the spark. i still dont know the condition of the rest of the engine. for all i know it may not have any rings left. we just moved, i don't want to get off to a bad start with the neighbors by fumigating the neighborhood when i till the garden.
what would y'all do? how much trouble/money could it be to rebuild the engine vs buying a new used engine off craigslist?
should i just bite the bullet and buy the parts to fix the points, a carb kit, and a set of rings and rebuild the engine? i don't know the first thing about small engines, i found instructions on youtube on how to remove/install the points. i'm sure i can stumble my way thru a rebuild. plus i have a few mechanic friends that may help.
say i do buy a newer engine, do they all have the same bolt pattern and shaft diameter and key? do i have to stick with a briggs or can i get a kohler ot tecumseh?
ID:	90246   Click image for larger version
ID:	90247   Click image for larger version
ID:	90248   Click image for larger version
__________________
there are no junk lawn mowers. just mowers that haven't met the right owners yet.
tpolley is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-21-2010, 06:47 AM   post #2 of 40
Brad
MTF--A Step Above!
Brad's Avatar
MTF Member # 4571
Images: 28
Default Re: old wizard tiller with 5hp b/s. rebuild or repower?
I'd pull the engine off and keep it together, just in case. In the meantime, try to come up with a replacement engine. You've got 2-3 mos. before you will be tilling, so time is on your side. Even if you go new engine, you can get a clone from Harbor Freight for $99, only twice what the replacement parts for your engine would cost.
__________________
MTF--Getting better, one new member after another!
It's a great place to spend some time every day!
Brad
Brad is online now   Reply With Quote Quick reply to this message
Old 01-21-2010, 11:11 AM   post #3 of 40
Stan the Air Man
Senior MTF Member
Stan the Air Man's Avatar
MTF Member # 8600
Gilson, my favorite tiller, makes the tiller I believe. I have owned one for almost 40 years, mine is Sears branded but it is a Gilson.
You could possibly get this going for a little money or it could drain the bank and either way you may end up needing a part that is no longer available. There are a few Gilson tiller parts available as aftermarket, very few.
Look closely for a tiller model number it may begin with GIL. If you need help with the engine post the model, type and code numbers.
A leakdown test will tell you the engines combustion condition prior to disassembly. Sitting as it has it may have fuel varnished stuck valves. Check the fuel tank for rust. Not all carburetor pick-up tubes are available but you would need engine numbers to learn this.
If you learn, it is a Gilson tiller I have five different Gilson manuals I will share free.
I doubt you will find another brand engine that will replace the Briggs. If you do it will be a Tecumseh but that is a whole different set of problems.
Leakdown test:
http://www.supramania.com/forums/showthread.php?t=2229
http://www.kartingtechinfo.com/tech/leakd.htm
They do not get any cheaper than this:
http://www.harborfreight.com/cpi/cta...emnumber=94190
Stan the Air Man is offline   Reply With Quote Quick reply to this message
Old 01-21-2010, 11:28 AM   post #4 of 40
tpolley
Senior MTF Member
tpolley's Avatar
MTF Member # 32442
the model number is GIS 6798A76. it's hard to read but thats pretty close.
i saw those harbor freight engines on their web site last night. they're probably much cheaper than a used briggs. i may go that route. i need to take some measurements and see if it'll fit.
__________________
Old 01-21-2010, 11:33 AM   post #5 of 40
Wizard99
Proud Member of the 1K Club
Wizard99's Avatar
MTF Member # 13982
Images: 12
That one looks just like mine, mine was completely redone and I gave it to my brother. I got the tractor mounted cub tiller. does yours have the cam pulley on engine for reverse, (much harder to find) or does it use the reverse belt tension arrangement?
__________________
remember kids, just say no to scrappin tractors
Wizard99 is offline   Reply With Quote Quick reply to this message
Old 01-21-2010, 11:44 AM   post #6 of 40
tpolley
Senior MTF Member
tpolley's Avatar
MTF Member # 32442
Quote:
i can't figure out how it works to be honest. i grew up watching my dad use it but i've never used it myself. it's supposed to be a 2 speed with "power" reverse but the only lever only has two positions: forward (go) and reverse (stop). the lever moves a belt tensioner. i don't see how to put it in reverse or how to change speeds. i will take some pictures of it tonight and post them. maybe you can tell me if something is missing. if it is it may not be worth fixing up if i can't get the parts.
__________________
Old 01-21-2010, 12:48 PM   post #7 of 40
Wizard99
Wizard99's Avatar
MTF Member # 13982
Images: 12
yep, sounds just like mine, my bolens had a cam pulley but my extreme heavy duty wizard had a weird belt tensioner pulley arrangement for reverse. It was my brother that actually figured it out after I gave it to him. I will ask him.
__________________
Old 01-21-2010, 01:00 PM   post #8 of 40
Tractor-Holic
10,000 +posts!
Tractor-Holic's Avatar
MTF Member # 8867
I'd just file the points and tape the bare wire up,see if it has spark,and RUN it till it blows..I have 4 of those old Briggs 5 HP engines and they are pretty tough ,they do smoke some ,but not so bad they'll fog the yard up..these engines are still pretty common and you can probably find parts in a mower shops "boneyard" or other places,or new,as a last resort..all that goes wrong with these is the points corroding,or the carb diaphram goes bad from sitting and the carbs need cleaning..as long as the valves seat ,arent stuck,and it has some compession,I bet it'll run once you get spark back in it..
If yours has the "double crankshafts" your pretty much stuck using that engine,or a Tecumseh with the same setup..otherwise you'll lose reverse,and I'm not so sure a honda clone will have the same size crank or the bolt holes needed to mount the belt idlers,etc either..be a lot easier to fix whats there,in my opinion..I doubt a "crappy" engine was swapped onto it,who'd bother wasting their time doing that??..
Tractor-Holic is online now   Reply With Quote Quick reply to this message
Old 01-21-2010, 02:52 PM   post #9 of 40
Muzzlemike
Senior MTF Member
Muzzlemike's Avatar
MTF Member # 29178
I agree with Tractor-Holic My MTD tiller looks alot like your wizard and it has a 5 hp Brigs on it . It smoke some and I do put a condenser in it once a year ( It has been like that with the condenser since it was new 30 years ago .) but it works hard with little head aces . It is a good work horse but it is like a bucking bronco the way it throws me around . I figger a condenser is little to pay for all of the work it gives back .
__________________
I bleed Red . Just like my tractor .
1997 MTD Yardman 16/46 lawn tractor
1998 MTD Yardman Snow blower
1982 MTD Front tine Tiller with a 5 hp Brigs.
I even have a Honda push mower that I got in 2006 and it was even made by MTD .
Muzzlemike is offline   Reply With Quote Quick reply to this message
Old 03-28-2010, 03:44 PM   post #10 of 40
JohnFS
MTF Junior Poster
MTF Member # 40589
Your tiller looks almost exactly like mine that I acquired from a friend about 10 years ago, it sat in his back yard for years with out being used and he was hauling it off to the junkyard, fortunately I showed up before he left with it, I took it home clean the gas tank and carb, changed the oil and gear oil and put a new spark plug in it and believe it or not it started on the first pull; it has been a good strong tiller for me ever since, it smokes a little but does the job well. It is the power reverse model with both forward and reverse operating on pulley tensioners with the drive pulleys fitted directly on crank shaft. I have never had the reverse belt on it but it looks like it would need to be mounted in a figure eight to function properly. I would love to find a user/parts manual for it.
I can take pics and post them if you like.
Here is the info on the tiller.
STOCK CODE: 4XC 6790
MODEL NUMBER: GIS-6790A76
SERIAL: 757183
JohnFS is offline   Reply With Quote Quick reply to this message
Old 03-29-2010, 12:03 AM   post #11 of 40
DaddyJohn
Senior MTF Member
DaddyJohn's Avatar
MTF Member # 35650
If you don't want to get too deep into your current engine, I'd agree with this strategy. However, there isn't much to be lost by trying to file the points, insulate any bare wires, see if you have spark, and checking compression & leakdown.
The other strategy is to keep watching craiglist or the classifieds. I picked this beauty up for $50 the other day. She's a little small, but works beautifully!
__________________
'76 Sears 16/6, TORO 460LX, Craftsman LT1000(x2), Huskee 12.5-40, MTD RER & 12.5-38, John Deere STX38, '78 Sears LT10/36 610
DaddyJohn is offline   Reply With Quote Quick reply to this message
Old 03-29-2010, 11:52 AM   post #12 of 40
wildncrazyguy
MTF Member
MTF Member # 37312
SERIAL: 757183
I've got an old Wizard Tiller as well. Looks very much like the poster's pics, except mine looks in a little better shape. I'll try to take some pics and post as well later this week. Yes the power reverse belt is supposed to be a figure 8, but I don't think mine is on. (I just till going one way.) I have the manual for mine also. It doesn't get much use, so it should look better than the poster's tiller.
wildncrazyguy is offline   Reply With Quote Quick reply to this message
Old 03-29-2010, 12:16 PM   post #13 of 40
DarkWolf
Ford LGT 100
DarkWolf's Avatar
MTF Member # 16423
Reminds me of the one I got from the inlaws.. I ended up using a solid state ignition system in it.. Works like a champ.. Especially after I drained the milky white oil out of it.
__________________
Ford LGT 100: 53205 18035
Troy-Bilt: 19HP V-Twin Hydrostatic
Craftsman LT4000: RIP - Dead
My LGT 100 Worklog!
DarkWolf is offline   Reply With Quote Quick reply to this message
Old 03-29-2010, 02:46 PM   post #14 of 40
PaulsSmallEngineRepair
Senior MTF Member
PaulsSmallEngineRepair's Avatar
MTF Member # 23655
Stan the Air Man:
Thanks for the Leak-Down Links...
__________________
Paul's Small Engine Repair
Raleigh, NC
PaulsSmallEngineRepair is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-29-2010, 03:29 PM   post #15 of 40
tpolley
Senior MTF Member
tpolley's Avatar
MTF Member # 32442
wildncrazyguy, pictures would be appreciated for a possible restore. i gave up on the engine. i probably could get it going. i'm trying to convince the wife it would be cheaper and easier to replace it with a horrible freight subaru ohv engine. she wants to buy a new used tiller. the only new used tiller we can afford will be a cheap pos. i'd rather repower and repaint the old wizard. anyone know if all briggs and stratton 5hp horizontal shaft engines have the same shaft diameter or if they vary? what is the diameter. 3/4?
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
