| Register | Home | FAQ | Active Topics | Garage | MTF Gallery | Search | Today's Posts | Mark Forums Read | Store | Chat Room |
Thread Tools | Display Modes |
#16 |
Senior MTF Member
If you are mechanically adept you should take the clutch off and reassemble it, taking note the the cam and bearing assemblies have to be put on a certain way when reassembling it. You should study how the adjusting nut and adjusting nut guide work in concert with the nut that compresses the beveled washers. It took me several times to get it put back together the right way, but in doing this i came to understand exactly how it works. I could have never understood this by just looking the parts diagram.
__________________
1979 Case 446 |
| Sponsored Links | |||
Advertisement | |||
#17 |
Proud Member of the 1K Club
MTF Member # 8013
When you torque it that way you're likely turning the large adjusting nut instead of the nut you're trying to torque.
#18 |
MTF Member
MTF Member # 22365
#19 |
MTF Member # 8013
Remove the hose between the air filter housing and the flywheel housing then you can stick a large screwdriver in the ring gear.
#20 | |
MTF Member
MTF Member # 22365
Quote:
#21 |
Banned!
MTF Member # 7029
We are fortunate in having Brian Hildreth here as an MTF member. His screen name is bhildret. Search some of the recent threads and find him. Click on his name and you will find a way to either e-mail or PM him.
Brian is an Ingersoll dealer and a very helpful one at that. You will not find very many parts listed at on-line stores. They only post the ones that are common to a wide number of models and years as well as being fast moving items. Give Brian you model and serial number and he will sell you whatever parts you need. If your plastic bushing (referred to by David) is worn out, then replacing it is a good idea since we are talking low cost. As for your clutch, until you finally realize that a clutch is a high-wear item that does not last forever, you are going to have problems. If you want your clutch to work properly, then you have to replace worn out parts. To figure out which parts should be replaced, a total dismantling of the clutch is required. Until then, you're just spinning your wheels. |
#22 |
MTF Member
MTF Member # 22365
OK! We got over 4 inches again today and I readjusted the clutch again using the recommendations that I have received. I was able to do the whole yard without any issues. I did not change any parts but feel that I definitely should do some maintenance on the clutch.
However, the 2 pulley wheels under the tractor that the belts go on are rubbing together and sparking. I'm not sure how to adjust these...Should I start a new thread. |
#23 |
Banned!
MTF Member # 7029
No.... a new thread isn't necessary.
Remove the belt. Check both idlers for any side play. They should not move even a hair when you try to wiggle them sideways. Look for bent hardware. Do the pulleys run true when you spin them? Do the run nice and free? Are the pulley mounts bent? Are you sure that you are using the correct belt? If the belt is too long, then the pulleys are in the wrong position. How about the tension spring? Is it stretched out or are the coils tight together when it is relaxed? What about the mule drive mount? Any sign of damage? |
#24 | |
MTF Member
MTF Member # 22365
Quote:
Everything works now! Thanks guys! Maybe I will begin restoring it this summer. |
| Sponsored Links | |
Advertisement |
#25 |
MTF Junior Poster
MTF Member # 33966
If you have had the clutch apart, make sure that the two bearing carriers and installed with the center slots offset (one up one down) when you put your operating lever between them. This is what gives you your squeeze when you operate the pto lever. It will work if they are both in the same direction but your adjustment will be extremely critical and won't hold. having adjusted lots of these over many "improvements" made by case I can say easy adjust my #%&*.
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
