John Deere 317 wiring? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-15-2010, 06:57 PM   #1
bvp2000
Senior MTF Member
bvp2000's Avatar
MTF Member # 28946
Default John Deere 317 wiring?
Hi, I just came across this 317. It runs great and the deck is in excellent shape. It apears to be sound overall except for a wiring problem and the brake petals don't return when released. Everything works except the PTO, however there is not a seat switch on the unit and the actual wires are missing. I think if I can get the wiring straight for the switch that the PTO may actually be ok. (at least I hope so!) I bought it from the original owners son (he inherited it) If anyone has a wiring diagram for the 317 I would appreciate a copy!
__________________
bvp2000
JD 455/40 Loader
JD 755, JD 425, and JD 7 Cart
JD's not hidden from the wife well enough!
JD 425, JD 425AWS, JD 322, JD 318, JD 317, JD 425
JD G100, JD 318, JD 445, JD 445, JD 265, JD 455, JD 332, JD 455, JD 430, JD 318, JD 777 and JD X495
bvp2000 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-15-2010, 09:05 PM   #2
PA318Guy
Badge Crew Member
PA318Guy's Avatar
MTF Member # 31960
Garage
Default Re: John Deere 317 wiring?
Can't help you on the 317 wiring but the seat safety switch wiring is just two wires. You might want to remove the seat pan and see if they are under it, you can (for test purposes only!) run a wire from one side to the other to complete the circuit to see if the PTO works! You can still get seat switches from JD (I believe) for them. If not you see them on ebay occassionally!
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is offline   Reply With Quote
Old 01-15-2010, 09:22 PM   #3
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
The blade type seat switch is readily available from JD. I'd be willing to bet the wiring is under the fender pan as well.
The wiring diagram is included in the service manual, and they run about $45 on CD from JD.
D-Dogg is offline   Reply With Quote
Old 01-17-2010, 02:58 PM   #4
bvp2000
Senior MTF Member
bvp2000's Avatar
MTF Member # 28946
Thanks, I was hoping to not have to buy a manual as I will not be keeping this one. I just wanted to get the PTO working and some 317 decals before I put it on ebay.
__________________
bvp2000
JD 455/40 Loader
Old 01-17-2010, 04:26 PM   #5
walter g
Proud Member of the 1K Club
walter g's Avatar
MTF Member # 9285
This is a pdf link to a 317 wiring diagram.
http://www.weekendfreedommachines.co...cal-126851.pdf
walter g is offline   Reply With Quote
Old 01-17-2010, 08:11 PM   #6
bvp2000
Senior MTF Member
bvp2000's Avatar
MTF Member # 28946
Thanks Walter...that is exactly what I needed!
__________________
bvp2000
JD 455/40 Loader
Old 04-11-2011, 08:21 PM   #7
TimB09
MTF Junior Poster
MTF Member # 55325
Send a message via Yahoo to TimB09
ok Yaw ive just purchased a J-D 317 with no engine it came out with a 17HP Kohler what I want to know is if a 1973 single cylinder 14 HP will be enough to pull it I know the older single Kohlers had a longer stroke What yaw think
TimB09 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-11-2011, 09:54 PM   #8
PA318Guy
Badge Crew Member
PA318Guy's Avatar
MTF Member # 31960
Garage
Quote:
TimB09, you should start your own thread for that question. I'm not sure which model Kohler JD has in the 314 (someone should help with that) but it would have no problem running the tractor once connected up to the hydrostatic pump properly.
__________________
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
