JD 316 (w onan) p218G - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-10-2010, 06:12 PM   post #1 of 16
blkdge996
MTF Junior Poster
MTF Member # 37222
Help JD 316 (w onan) p218G
has anyone swapped a 2 spool hydraulic valve body and handles off from a 318 to a 316? it this possible without troubles? also the dual breaks. i think i can get a good deal on the set. also what model rototiller fits on this tractor? do I need the rear pto gearbox? thanks.
blkdge996 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-10-2010, 07:12 PM   post #2 of 16
ryankrizan
Senior MTF Member
ryankrizan's Avatar
MTF Member # 33584
Default Re: JD 316 (w onan) p218G
Quote:
As I recently found out, no you don't need a rear PTO, you can get a hydraulic tiller for your tractor.
__________________
1992 JD 318 23hp Vanguard v-twin
ryankrizan is offline   Reply With Quote Quick reply to this message
Old 01-10-2010, 08:10 PM   post #3 of 16
blkdge996
MTF Junior Poster
MTF Member # 37222
thanks do you have any info on it?
Old 01-10-2010, 11:44 PM   post #4 of 16
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
It's a 30 inch tiller which mounts with a set of plates under your hitch plate, and onto your rockshaft. You can mount the pump under the tractor to run off the front PTO or on the rear if you have the rear PTO. I believe there was an extension available for it to make it a 42".
There is a gentleman who makes a 3PH adapter to make mounting and unmounting easier.
D-Dogg is offline   Reply With Quote Quick reply to this message
Old 01-11-2010, 12:25 AM   post #5 of 16
blkdge996
MTF Junior Poster
MTF Member # 37222
really....... How do i talk to that gentleman? these tillers seem hard to find? do any of the 200 series use this tiller? thankyou
__________________
Adam
78 JD 316 (Kohler)
mower deck,snowblower
84 JD 316 (Onan)
mower deck ,smowbloer, AG tires
91 polaris trailboss two stroke
Old 01-11-2010, 03:10 AM   post #6 of 16
Sergeant
Tech Exchange Moderator
Sergeant's Avatar
MTF Member # 24
No none of the 200 series use the Hydraulic tiller.
__________________
John Deere Models:X748,140H3,112,Sabre 1542
Cub Cadet Models:0riginal,70,106,2206 & Experimental Non Production Rear engine rider
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
"The only thing necessary for the triumph of evil is for good men to do nothing." Edmund Burke
Sergeant is offline   Reply With Quote Quick reply to this message
Old 01-11-2010, 04:09 AM   post #7 of 16
ryankrizan
Senior MTF Member
ryankrizan's Avatar
MTF Member # 33584
http://seattle.craigslist.org/skc/grd/1535880957.html
Not sure if it's correct, but according to that post, he says it will fit some of the 200 series.
Here's the ad:
this is the hard to find in good working order jd hydraulic tiller that fits the legendery 318 lawn and garden tractor it was just serviced new hydraulic oil, oil filter bearing and bushing tills like a dream get ready for spring now this will also fit john deer 316 onan 322 330 332 420 430 and also the 208 210 212 214 and 216 give me a call 206-498-2269
__________________
Old 01-11-2010, 10:19 AM   post #8 of 16
Chadsden
MTF Member
MTF Member # 31877
Heres the 30" hydraulic tiller with a 12" extension on it. The brackets for the tractor are shown in the last picture. The top part is a rod to stabilize the pump, the 2 triangular castings mount on the rockshaft and the bottom 2 mount on the rear axles. No rear pto and no 3 pt hitch required. Really nice attachment!
Chadsden is offline   Reply With Quote Quick reply to this message
Old 01-11-2010, 02:04 PM   post #9 of 16
blkdge996
MTF Junior Poster
MTF Member # 37222
Those tillers look great. I'd like to get my hands on one some
how. how dose it raise and lower?
__________________
Adam
78 JD 316 (Kohler)
84 JD 316 (Onan)
Old 01-11-2010, 02:16 PM   post #10 of 16
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Via the rockshaft.
I could not find the post of the 3PH tiller adapter, but it was on weekendfreedomachines.com
My neighbor has this tiller, and told me it is about a 20-30 minute one man job.
Old 01-11-2010, 02:53 PM   post #11 of 16
ryankrizan
Senior MTF Member
ryankrizan's Avatar
MTF Member # 33584
Quote:
Originally Posted by D-Dogg View Post
Via the rockshaft.
Do all 318s have rockshafts on them? Was it an option?
__________________
Old 01-11-2010, 03:33 PM   post #12 of 16
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Yes, a rockshaft is standard on the 318.
If you get a hydraulic tiller, you want to print the IPL from the John Deere part site and make sure you get all the mounting hardware.
Old 01-11-2010, 04:06 PM   post #13 of 16
Sergeant
Sergeant's Avatar
MTF Member # 24
The above tiller will fit al the tractors listed as far as the 316 onan, thru 430 will run off either front or Rear PTO's on the 300 series and Rear PTO only on 420 and 430. But looking at that one above I think it only set up right now to work off the 316onan thru 332 front PTO. The 200 series he is listing have a diffrent PTO setup where this tiller would not work not to metion the weight of the tiller when it has Hydraulic fluid in it.
__________________
White Model: GT2055
Old 01-12-2010, 02:49 PM   post #14 of 16
sts25straight
Proud Member of the 1K Club
sts25straight's Avatar
MTF Member # 22258
Images: 17
There is an adapter kit for the 200 series tractors.
John
sts25straight is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-05-2010, 12:35 PM   post #15 of 16
specie
MTF Junior Poster
MTF Member # 11761
hi, new here i just got a 42" hydraulic tiller that came off a 445. i want to mount it on my 318. my problem is i need a pump bracket AM100388 i can't get one. can you give the specs on the bracket so i can make one. how do i add a picture.
specie is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
