Best way to put on tire chains - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-03-2010, 02:00 PM   post #1 of 8
StWeiler
Buy High, Sell Low
StWeiler's Avatar
MTF Member # 13372
Default Best way to put on tire chains
Never used tire chains before, but I recently got a steal on a set so thought I would try them.
What is the best way to put them on? Pull the tires or leave them on the tractor? I was told to deflate the tires, put the chains on as tight as possible and then inflate the tires...is that true (my local dealer told me this)?
TIA
__________________
1988 Wheel Horse 518H
48" Dozer Blade
48" SD Deck x2
StWeiler is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-03-2010, 02:46 PM   post #2 of 8
1086
3K Poster!!!!
1086's Avatar
MTF Member # 1086
Images: 11
Default Re: Best way to put on tire chains
http://www.mytractorforum.com/showthread.php?t=107512
This information was submitted by a branded site supporter.
__________________
1086 is offline   Reply With Quote Quick reply to this message
Old 01-03-2010, 03:00 PM   post #3 of 8
Everlandfarm
everlandfarm
Everlandfarm's Avatar
MTF Member # 13530
I just put a roll around jack under the hitch and raise the rear of the tractor. With the trans in neutral (pull the pin if you've got a hydro?) you can then drape, adjust, and spin the tires.
What your dealer told you is intriguing, however if you've got Ag tires or other "aggessive" tread design I think you'd still end up jacking up the tractor.
Ev
Everlandfarm is offline   Reply With Quote Quick reply to this message
Old 01-03-2010, 03:13 PM   post #4 of 8
HUSKY_PAL23
Senior MTF Member
HUSKY_PAL23's Avatar
MTF Member # 27424
Lay them out nice and straight on the lawn and back on to roughly the center of the chains. Then deflate half way wrap and hook chains. Then inflate and adj. Should be good to go!
__________________
Case; 2- 444s
Bolens; 1050, 2-1054s, H-16, 1886
Sears; ST/12, ST/16, 19/9
Looking for large frame Bolens attachments, any condition.
HUSKY_PAL23 is offline   Reply With Quote Quick reply to this message
Old 01-03-2010, 07:38 PM   post #5 of 8
engine2quarters
5000 Strong & Climbing
MTF Member # 24003
No. 1 suggestion: NOT to put the chains on the tractor, the night the big storm is supposed to hit. They might not be for your sized tires, OR, you may have ended up with only 1/2 pair (only enough for 1 wheel), thanks to the previous owner.
I put mine on, back in October.
The second set went on, the weekend later.
The third set didn't make it to the wheels. They're about 6 inches short in length and 2 inches in width. Supposed to have been sized for the tires that I had. Well, that tractor now sits under a tarp covered with 8 inches of snow, with a brand new plow on it, and chainless. It's not there only because of the chains, we gotz an engine problem, too.
Luckily, I've got 2 other tractors, plus a few walk behind blowers, and long handled shovels to work with.
engine2quarters is offline   Reply With Quote Quick reply to this message
Old 01-03-2010, 08:19 PM   post #6 of 8
Hugh-SS/16
Onan Lover
Hugh-SS/16's Avatar
MTF Member # 31282
Images: 15
Garage
i jack up the rear. hang the chains. turn the wheel. tighten the chains.
__________________
GT_80 Fan Club Member: #0001
Need Tires?Click Here!
Tractors: '68 Custom 8XL, '73 SS/16, '73 SS/16, '78 GT/18H, '78 GT/19.9
Attachments: Kwik-Way Loader, 48" Haban Sickle Bar, 42" Mid-Mount Grader, 42" 3pt Grader, 46" Snow Blade, 42" Mower, 4000w PTO Generator, 3pt 10" Moldboard, 3pt Cultivator, 42" Haban Snowblower, 46" Dozer Blade
John Deere, Mahindra CUT, Gravely, Stihl
Ellington Agway Power Equipment
74 West Rd (Rt 83)
Ellington, CT
860-875-0690
The above opinions are solely mine and do not reflect that of my employer
Hugh-SS/16 is offline   Reply With Quote Quick reply to this message
Old 01-04-2010, 12:16 PM   post #7 of 8
wahoowad
Senior MTF Member
MTF Member # 32045
Put my first set ever of tire chains on my Sears yard tractor yesterday. I was able to do it without any special effort. I laid the chains over the top of the tire and was able to reach around the tire to connect the back link first, then the front link.
wahoowad is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-04-2010, 01:21 PM   post #8 of 8
Small Fry
Small Fry's Avatar
MTF Member # 8155
I just lay the chains down, back on them, rap around and hook up. Not so easy to deflate the tire if they are loaded.
Small Fry is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
