garden tractors with cat-0 3 point hitches - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-02-2010, 09:37 PM   post #1 of 16
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Default garden tractors with cat-0 3 point hitches
This topic came up not too long ago, and I can't find the thread. No one could name a modern implementation of the category 0 3 point hitch.
It looks like the Kubota G series has one as an option, along with a rear PTO. Also a shaft drive 3PH mounted tiller.
Can any of you Kubota gurus tell me if the rear PTO on the G series is 540 RPM or 2,000 RPM? I could not find that level of detail on their website.
Thanks,
D-Dogg is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-02-2010, 09:47 PM   post #2 of 16
david doyle
MTF Member # 8803
Default Re: garden tractors with cat-0 3 point hitches
INGERSOLL
david doyle is offline   Reply With Quote Quick reply to this message
Old 01-03-2010, 11:54 AM   post #3 of 16
APinNY
I didn't do it!
APinNY's Avatar
MTF Member # 22011
Images: 5
Thanks,
I'm no guru but perhaps I can help. I also went through their site and couldn't find any info about a rear PTO for that model. They do mention that the mid-PTO spins at 2576 RPM's, which is fine for mowers and blowers but the rear mounted implements have to spin much slower. The BX mid-PTO runs up to 2500 but the rear only goes to 540. I would imagine the G series is similar.
__________________
Al
Kubota BX1860, 48" fine cut mulching MMM, FEL, snow thrower, cab, Heavy Hitch
TroyBilt LTX 15.5, snow thrower, cab (sold)
TroyBilt LTX 13, (given away)
Craftsman DYT 4000 Special Edition, 21 HP Briggs Twin (sold)
DR Lawn Vacuum. Review here
1978 Craftsman 7 1/2 HP snow blower (backup machine-never use it)
"You will find out what that extra part is for as soon as you throw it away"
APinNY is offline   Reply With Quote Quick reply to this message
Old 01-04-2010, 12:32 AM   post #4 of 16
Sergeant
Tech Exchange Moderator
Sergeant's Avatar
MTF Member # 24
You can still get Cat o implements thru Tractor dealer's Brinly is still manufactring them to be sold thru dealers only right now.
Manufacturers that still have Cat 0 3point hitch
Cub Cadet 3000 series has a Cat 0
Ingersoll as mentioned above
Kubota
John Deere a Cat 0 3point is still avaliable for the X465 thru X749 Though most people do buy it with the Limited Cat 1 3point hitch. The Kubota G series has a 540rpm Rear PTO for the tiller.
I'm guessing you looking for a 2000RPM tiller for your 318. If that the case the Best tiller to look for for your 318 is a Used Hydraulic tiller for it Because it could use either the Front or Rear PTO. That would be a 30inch Hydraulic tiller. I know from time to time guy advertise them for sale over hear http://www.weekendfreedommachines.co...cus/discus.cgi
__________________
John Deere Models:X748,140H3,112,Sabre 1542
Cub Cadet Models:0riginal,70,106,2206 & Experimental Non Production Rear engine rider
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
"The only thing necessary for the triumph of evil is for good men to do nothing." Edmund Burke
Sergeant is offline   Reply With Quote Quick reply to this message
Old 01-05-2010, 07:51 PM   post #5 of 16
BP Fick
Senior MTF Member
BP Fick's Avatar
MTF Member # 35421
Kubota no longer makes the G model. Since it was so close in price to the small BX, the 1860, its demise is understandable.
No ground engaging capability on the GR models. It isn't strong enough in key ways for that, although it remains a flagship lawnmower.
BP Fick is offline   Reply With Quote Quick reply to this message
Old 01-05-2010, 07:55 PM   post #6 of 16
Upper5Percent
5000 Strong & Climbing
Upper5Percent's Avatar
MTF Member # 8602
http://www.tuff-bilt.com/tractor.html
Hitches: Two three-point Category "0" with individual
Hydraulic lifts- 700 lbs lift capacity
__________________
Paul in VT
The answer is 42
Upper5Percent is online now   Reply With Quote Quick reply to this message
Old 01-05-2010, 10:43 PM   post #7 of 16
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Kubota
Thanks,
I picked up a 2000 RPM Befco tiller for the 318. Had no idea Befco made one.
The question actually arose from a couple of conversations. Someone was asking the practicality of dropping the money on a cat 0, then another question regarding the 2000 RPM PTO.
It seems to me that the limited cat 1 and cat 1 have more or less taken the place of the cat 0. Ingersoll's attachments are all pretty much Ingy specific being hydraulic, but I would suspect Kubota will continue to carry their cat 0 implements for at least a couple of years.
I know plenty of folks make non-driven cat 0 attachments yet. I wonder if Frontier offers anything for the cat-0 still?
That Tuff-bilt is an interesting rig, but at the price, I think the JD x700 and Ingersoll are not exactly worried.
Old 02-21-2012, 09:44 PM   post #8 of 16
redneckdzl
MTF Member
MTF Member # 68755
Doing a bit of research it looks like the g series tractors have a 2000 rpm rear pto, it looks like they use the front shaft to run a pulley system to run the rear pto
redneckdzl is offline   Reply With Quote Quick reply to this message
Old 02-21-2012, 09:49 PM   post #9 of 16
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Quote:
Wow, Thanks for that answer. I'd written it off as a no on the PTO.
__________________
Old 02-21-2012, 10:02 PM   post #10 of 16
redneckdzl
MTF Member
MTF Member # 68755
It was a add on option, and judging by how hard it is to find a tiller which was the only option that kubota offered I figure its even rarer to find a tractor that actually has the rear pto setup
I'm torn between trying to find a 3 pt hitch and making a sleeve hitch for my tractor
Just realized this thread was over 2 years old, glad you got an answer
Old 02-21-2012, 10:41 PM   post #11 of 16
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Thanks,
Yes and the guy who sold you the Befco is still waiting to hear that it's working !!!!!!!!!!!!!!!!!!!!!
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Old 02-22-2012, 09:00 AM   post #12 of 16
gburnett
3K Poster!!!!
MTF Member # 9399
Its working used it last year on an Ariens GT to cultivate between rows."How tiller will Travel".And I'm running it on a 3250 PTO but throttle back and only running it about 2" deep to cultivate and its offset so it gets right up against the rows once I make a pass with the disc hiller.
gburnett is offline   Reply With Quote Quick reply to this message
Old 02-22-2012, 09:03 AM   post #13 of 16
gburnett
3K Poster!!!!
MTF Member # 9399
The Tuff-Bilt tractor is built to cultivate one row at a time and really has no equal now as its built for excellent vision and clearance of the crop being cultivated which no garden tractor can come to matching.I have a Hines thats very similar and they're pretty decent mowing tractors also.
Old 03-03-2012, 07:27 PM   post #14 of 16
ShredSled
MTF Member
MTF Member # 69803
what might some good brands be that make a decent budget box scraper for a cat 0 3pt on a cub cadet?
I think the brinly/crafstman (sleeve hitch) box blade I was looking at might be a bit “lightweight“ for the use I was hoping to put one through...
__________________
Cub Cadet HDS 3185 - For Sale (pm me if interested)
ShredSled is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-10-2012, 02:44 PM   post #15 of 16
gtstang88
MTF Junior Poster
MTF Member # 5627
I'm also looking for a decent cat. 0 boxblade for my 318
__________________
318- 46" deck,54 blade, 3pt hitch, 3pt carry-all/sprayer, 3pt cultivator, 12" brinly plow, 4ft 3pt brinly disc, Al Z's 3pt forks
345- 54" deck-sold
Hustler fastrak superduty 25/54
gtstang88 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
