6 lug Toyota fit 6 lug Chevy? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Trucks 2 Wheel Drive , 4 Wheel Drive, Big or Small
Reply
Thread Tools Display Modes
Old 12-30-2009, 10:57 PM   post #1 of 22
littletoes
Father of 7!!LordHelpMe!
MTF Member # 6328
Default 6 lug Toyota fit 6 lug Chevy?
Anyone know if the six lug wheels off of an older Toyota will fit a six lug full size Chevy Blazer?
littletoes is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-31-2009, 02:34 AM   post #2 of 22
Boyd
5000 Strong & Climbing
Boyd's Avatar
MTF Member # 19439
Images: 10
Default Re: 6 lug Toyota fit 6 lug Chevy?
I think the bolt spacing is the same but the stud size may be different. Are the center holes of the wheels the same? What kind of lug nuts will you use? Part of what makes a wheel "safely" bolted to the axle or hub is it being centered whether it be with lug nuts that have an acorn shape. Other wheels are centered via the hub on the end of the axle or front hub.
__________________
http://www.youtube.com/watch?v=mHVFE02NTgU For sale: Toro 268-H "electric/hydraulic pump, hoses & cylinder". Wards gas power sweeper. Agri-Fab 42" sweeper. Peco & Wheel Horse vacuums & hoses. WH C-175: bad trans, 42" RD deck & misc. Sears 20/46 Hydro parts. Lots more going up for sale.
Boyd is online now   Reply With Quote Quick reply to this message
Old 12-31-2009, 03:08 AM   post #3 of 22
AcreFarm
Master Dismantler
AcreFarm's Avatar
MTF Member # 4194
Images: 7
I swapped wheels between a '91 Toyota and an '85 Chevy without any issues, both sets used acorn lug nuts. The Chevy had American Racing wheels, not the originals. Toyota wheels can be run on a GM, but stock steel GM wheels won't work with a Toyota, the center hole is smaller.
__________________
GTTalk
AcreFarm is offline   Reply With Quote Quick reply to this message
Old 12-31-2009, 07:12 AM   post #4 of 22
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
I though toyota and Ford was the same....
__________________
Kbeitz is online now   Reply With Quote Quick reply to this message
Old 12-31-2009, 07:27 AM   post #5 of 22
junk_jivin38
Senior MTF Member
junk_jivin38's Avatar
MTF Member # 12935
yes,i have swapped them on several different trucks...as others have said,use the acorn style lug nuts to keep the wheel centered and tighten them evenly a little at a time....the torque sequence (as i learned it) is to torque every other nut,clockwise ,going around twice...
also,the bolt pattern is the same on the 15 and 16-inch wheels
Kbietz...i think its ford and dodge are interchangable
BTW...i have a set of 15" turbine style wheels i need to get rid of...1 is broken at the flange from an overly-agressive tire-changer...cheap!
junk_jivin38 is offline   Reply With Quote Quick reply to this message
Old 12-31-2009, 08:55 AM   post #6 of 22
m.jodrey
5000 posts and climbing
m.jodrey's Avatar
MTF Member # 31184
Yes they are the same.
__________________
Maynard
1963 Bolens 800,1972 Bolens 1256, 1972 Bolens 1886, 1973 Bolens H16, 1978 Massey 1655, 1961 Cub Cadet Original, 1979 Cadet 85, 1980 Cub Cadet 482, 1963 Gravely L, 1993 Ford 6640 4X4,2008 Kubota 2110 diesel,1970 Bolens 1053,2002 John Deere JE63S self propelled lawn mower
m.jodrey is offline   Reply With Quote Quick reply to this message
Old 12-31-2009, 09:39 AM   post #7 of 22
bb609
MTF Member
bb609's Avatar
MTF Member # 35494
Same bolt patterns but different sized centering hubs, Chevy being the smaller of the two.
bb609 is offline   Reply With Quote Quick reply to this message
Old 12-31-2009, 11:29 AM   post #8 of 22
tractorkid94
Junk Collector
tractorkid94's Avatar
MTF Member # 10554
Yes, the pattern is the same. I have had 6 lug wagon wheels off of a Toyota pickup fit a fullsize Chevy Blazer.
__________________
199? Craftsman II 18hp 44"
2001 Poulan Pro 18.5hp 42"
Bolens 800 project
tractorkid94 is offline   Reply With Quote Quick reply to this message
Old 12-31-2009, 11:57 AM   post #9 of 22
littletoes
MTF Member # 6328
Thanks guys, ya'll always have quick answers for me!
I may have to just buy some lug nuts now.
My old blazer has the older style aluminum rims that take the lug nuts that have the long thin shanks that go inside of the rim. I don't think they even make them anymore.
I have the opportunity to get some studded snow tires at a great price on Toyota rims.
Anyone know the thread pitch of the studs on a Blazer now??? Full of questions, ain't I?
Thanks again guys, you're a big help.
Old 12-31-2009, 12:07 PM   post #10 of 22
bb609
MTF Member
bb609's Avatar
MTF Member # 35494
You may find that you need centering rings for them given the lugs are not centering lugs but I'm guessing.
Old 12-31-2009, 11:01 PM   post #11 of 22
amf1414
certified tractor nut
amf1414's Avatar
MTF Member # 26032
what year blazer if it is a later model they will be a metric thread if older it may be a 1/2-20 thread
__________________
01 craftsman lt1000 15.5 b&s
amf 1414 gt k341 kohler
49' ferguson to-20
49 farmall H restoring it now and i'm not going to have it done for awhile i want it to be perfect
R.I.P socks 07/08/96 - 07/22/2010
http://www.powerequipmentforum.com/ come check us out
amf1414 is offline   Reply With Quote Quick reply to this message
Old 12-31-2009, 11:43 PM   post #12 of 22
littletoes
MTF Member # 6328
'87 , Thanks!
Old 01-01-2010, 02:07 AM   post #13 of 22
amf1414
amf1414's Avatar
MTF Member # 26032
i'm pretty sure that an 87 would be metric so it is going to be either a 12 x1.5 or a 14 x 1.5
__________________
49' ferguson to-20
Old 01-01-2010, 03:07 AM   post #14 of 22
Tractor-Holic
10,000 +posts!
Tractor-Holic's Avatar
MTF Member # 8867
Older 6 Lug GM's had 7/16 x 20 thread lugs..newer metric ones have 12mm x 1.5 pitch ones...Toyota's 6 lugs had the same bolt pattern but the centers dont always fit ,on OEM steel rims anyway..
Tractor-Holic is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-01-2010, 11:56 AM   post #15 of 22
Don B.
MTF Member # 29108
Quote:
if it is a full size Blazer (not an S 10 version) they had standard thread all the way til that body style stopped in 91;
chevy pickups changed body styles in 88 for 1/2 and 3/4 ton weights; 89 and some '90 1 tonners were still 73-87 body; Blazers and Suburbans didn't change body styles til '92! depending on what rim design you want look at Dakotas newer than 91, /Durango's and (I think) even Vipers as well! these were also 6 lug; and I know for sure taht at least til 96 a Dakota had a 1/2-20 stud; NOT metric.
Don B. is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
