Home made leaf vacuum....need ideas - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Home Made Tractors, Implements and Accessories For you guys handy with a blow torch, welder or a wrench.. show us what you can do....
Reply
Thread Tools Display Modes
Old 12-21-2009, 03:34 PM   post #1 of 7
poncho62
National Mower Guy
poncho62's Avatar
MTF Member # 19374
Images: 7
Default Home made leaf vacuum....need ideas
I want to build a leaf vacuum for next year. Want to mount it on a trailer to tow behind a lawn tractor. I have the trailer, a 6 hp engine, but am wondering what to do for a blower. I did a search of the forums and saw that some are using old chipper/shredders. I have an old Mighty Mac, but it is pretty big.....and I don't see how one of these is going to get the suction.
I am wondering if there is a type of industrial blower that I could use? I will have a hose from my mower deck to this blower and then up to a bin in the trailer..........Any ideas out there. Looking to build something like this......
__________________
That National Mower guy
National Reel Mower
Ford LGT100
Ford LGT125
M-F 10
John Deere STX38
Ontario Rodders
poncho62 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-21-2009, 04:39 PM   post #2 of 7
Bart
Proud Member of the 1K Club
MTF Member # 8013
Default Re: Home made leaf vacuum....need ideas
Quote:
I have built several leaf vacs and suggest you look for a trak vac unit and use that as a pattern to build yourself the housing then you can purchase an impeller as a replacement part from trak vac. The impellers, while simple to make, are tough to balance properly without proper equipment so I would just buy one.
Most of the commercial units mount the impeller on the engine crankshaft though I dislike this approach because it will eventually damage the crank when the impeller gets out of balance from sucking up sticks and stones. I use a separate shaft and pillow blocks to mount the impeller and drive it with a v belt to the engine. This provides some protection to the engine if you jam the impeller and allows you to increase the rpm on the impeller which will increase the suction.
Bart is offline   Reply With Quote Quick reply to this message
Old 12-21-2009, 06:23 PM   post #3 of 7
poncho62
National Mower Guy
poncho62's Avatar
MTF Member # 19374
Images: 7
Was thinking along that line too.........but, where can I get the impeller unit? Any ideas what will work?
__________________
National Reel Mower
Ford LGT100
Ford LGT125
M-F 10
John Deere STX38
Ontario Rodders
Old 12-21-2009, 11:40 PM   post #4 of 7
Boyd
5000 Strong & Climbing
Boyd's Avatar
MTF Member # 19439
Images: 10
Look for a large 2 stage snowblower and use the 2nd stage. I have one from Canado made in the 70s I think, that was 2 stage but had a 90 degree gearbox that ran to the first stage. It doesn't have a shaft going foreward from the 2nd stage.
__________________
http://www.youtube.com/watch?v=mHVFE02NTgU For sale: Toro 268-H "electric/hydraulic pump, hoses & cylinder". Wards gas power sweeper. Agri-Fab 42" sweeper. Peco & Wheel Horse vacuums & hoses. WH C-175: bad trans, 42" RD deck & misc. Sears 20/46 Hydro parts. Lots more going up for sale.
Boyd is offline   Reply With Quote Quick reply to this message
Old 12-21-2009, 11:47 PM   post #5 of 7
Bart
MTF Member # 8013
Here's the link to the manufacturer's site http://www.trac-vac.com/
You can read through and see which models might be most appropriate for what you want to do. Download their manuals for part details. You can get the parts through any dealer--I got mine through a JD dealer.
This is a pretty popular brand so you shouldn't have much trouble finding ones to look at or maybe even pickup a used unit with a trashed engine. You might also inquire of dealers to see if any have used parts/damaged units they would sell cheap.
Old 12-22-2009, 12:12 AM   post #6 of 7
walter g
2000 Posts and climbing!!!
walter g's Avatar
MTF Member # 9285
If you can form and roll sheet metal you can build some of the parts you need. If not you'd do better looking for a trac-vac with a bad motor.
I thought about building one myself but it would cost to much. If you do build one there is a guy on Ebay selling the two hoses for 120 bucks brand new.
There is a company that sells the deck adapter boot for any tracvac style unit.
Adapter is here. http://www.trac-vac.com/
Hoses are here. http://cgi.ebay.com/DIXIE-CHOPPER-EX...item35a5996201
I believe the adapter boot is around 200. But you'd have to check.
It adds up real quick. If you can think of a cheap way to do it let me know.
Walter
walter g is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-22-2009, 12:40 AM   post #7 of 7
Bart
MTF Member # 8013
Here is a good source for hoses http://www.wynnenv.com/flexible_hose_Lawn.htm
If you want something that will last for a long time get the urethane hose--pvc will self destruct quickly.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
