Hydrostatic Drive Fluid Question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 12-07-2009, 11:31 PM   post #1 of 6
snowbandit
MTF Junior Poster
snowbandit's Avatar
MTF Member # 35287
Default Hydrostatic Drive Fluid Question
What type of fluid needs to go in the Hydro drive units on Cub Cadet? The owner's manual for my 3185 just says, "see your Cub Cadet dealer". Well I did that and the dealer told me not to buy it from him because it was too expensive and he doesn't keep it around anyway because you never have to change it unless it gets hot.
That story didn't make much sense so I just figured I would get some next time I was at Home Depot. After all HD carries CC so they should have the drive fluid, right? Wrong! They don't carry it either. So I have to ask, what do the experts here say?
snowbandit is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-07-2009, 11:47 PM   post #2 of 6
Mouse
Proud Member of the 1K Club
Mouse's Avatar
MTF Member # 29420
Default Re: Hydrostatic Drive Fluid Question
I only have a 125, I used Hytran, got it from a Case dealer. You better wait for a expert to answer. Good luck.
Mouse
__________________
1962 Cub Cadet Orginal
1963 Cub Cadet 100
1969 Cub Cadet 125
2009 Cub Cadet LTX1046VT
2011 Cub Cadet LTX 1040
1997 John Deere LX 178
Mouse is offline   Reply With Quote Quick reply to this message
Old 12-08-2009, 10:17 AM   post #3 of 6
Gary in NJ
Gary in NJ's Avatar
MTF Member # 3765
Images: 10
You can purchase two types of fluid from the Cub Cadet dealer, "Hydraulic Transmission Fluid" and "Drive System Fluid Plus, Synthetic Blend".
Does your model require synthetic fluid? I have a 2000 3206 and the fluid that was designed for it isn't even available anymore, "Cub Cadet Drive System Fluid".
I have been running Shell Rotella-T 15w40. No problems with running a bucket and blade with this fluid.
__________________
Gary
Kioti CS2410 with FEL, BH, 60" MMM, Snow Blower
Gary in NJ is offline   Reply With Quote Quick reply to this message
Old 12-08-2009, 02:10 PM   post #4 of 6
magicalj
Senior MTF Member
magicalj's Avatar
MTF Member # 2362
I believe the proper fluid for it now is the "Drive System Fluid Plus" and it's about $13 a quart. Don't use "Hydraulic Transmission Fluid" in you tractor. It's not compatible with your transmission. I don't know what it would do to it, but I would suspect that it would eat the seals. With the DSFP they say you never have to change you fluid. I don't think I would go that far, but I would expect the life of it to be at least 300-500 hours.
AJ
__________________
1980 482
1981 582
1979 682
1980 782
1983 982
magicalj is offline   Reply With Quote Quick reply to this message
Old 12-08-2009, 06:09 PM   post #5 of 6
snowbandit
MTF Junior Poster
snowbandit's Avatar
MTF Member # 35287
I finally got a hold of my dealer, the one I trust that's about 60 miles away. He tells me the CC oil is a 20W50 synthetic. A good 10W40 would probably be okay in the Winter however.
Apparently there has been a problem in the past with these machines not stopping when you raise your foot off the petal because the oil was too thick. That's why CC developed the new "plus" oil which, he claims, solved that. Prices through him are $10.77 a quart and $39.51 a gallon.
Sponsored Links
Advertisement
Old 12-08-2009, 08:12 PM   post #6 of 6
patthesoundguy
Senior MTF Member
patthesoundguy's Avatar
MTF Member # 29595
I'm using "universal tractor fluid" from wal mart in my 149, It says it's compatible with hydrostatic drives and said somthing about moisture resistance I think it was which is what I've read the hy-tran fluid is suposed to have and it's $7 a gallon canadian. so far so good.
patthesoundguy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
