Mower deck interchange - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 12-04-2009, 10:58 AM   post #1 of 13
Tencubed
3K Poster!!!!
MTF Member # 31735
Default Mower deck interchange
Will a mower deck off a 1556 fit on a G12?
Been looking for a deck and found a 1556 parts tractor with a deck. Don't want to have to do a lot of fabrication work but do have a shop for some retro fitting if needed.
Thanks
Mike
Tencubed is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-04-2009, 11:23 AM   post #2 of 13
frugal
Senior MTF Member
frugal's Avatar
MTF Member # 21041
Default Re: Mower deck interchange
Thanks
Mike
Probably. I would guess the 1556 has a 18423 42" deck. That should work on the G12. Check the Bolens Attachment Interchangeability Guide for details. Also take a look at Sonny's 18423 Owner's Manual for mounting details.
__________________
Bolens 1253 with dead diesel repower
Bolens attachments: Blade 18532, Tiller 18616, Mower 18421
Bolens accessories: Sleeve hitch, Front & Rear wheel weights, hydraulic lift
Brinly attachments: 10" plow, single gang disk, cultivator
If it sounds like I know what I'm talking about, I haven't written clearly enough.
frugal is offline   Reply With Quote Quick reply to this message
Old 12-04-2009, 11:31 AM   post #3 of 13
*Ryan
Senior MTF Member
MTF Member # 34589
my g12 deck looks nothing like the 1050 deck, the mounting things are differnt, it has a spring setup front to it
ill try to post you up some pics of the g12 deck when i get home tonight of the deck for a visual comparison for you
*Ryan is offline   Reply With Quote Quick reply to this message
Old 12-04-2009, 11:42 AM   post #4 of 13
m.jodrey
5000 posts and climbing
m.jodrey's Avatar
MTF Member # 31184
I believe the 1556 deck will work on a G12.
__________________
Maynard
1963 Bolens 800,1972 Bolens 1256, 1972 Bolens 1886, 1973 Bolens H16, 1978 Massey 1655, 1961 Cub Cadet Original, 1979 Cadet 85, 1980 Cub Cadet 482, 1963 Gravely L, 1993 Ford 6640 4X4,2008 Kubota 2110 diesel,1970 Bolens 1053,2002 John Deere JE63S self propelled lawn mower
m.jodrey is offline   Reply With Quote Quick reply to this message
Old 12-04-2009, 12:39 PM   post #5 of 13
Tencubed
3K Poster!!!!
MTF Member # 31735
Thanks for the quick answers, I'm always amazed at the depth of knowledge on this board.
From the looks of the interchange list there are several possibilities but it seems the odds are there would be an interchange without too much difficulty. As I stated I've got the shop to do the work in I just don't get around that well anymore.
Think I'll see if they will come down on the price a bit and try to get that tractor. He says the engine has a stuck valve or has dropped a valve seat. Apparently it's a Tech OHV. Really rather find a gear drive tractor as I've never had that good of service out of hydro tractors big or small.
Thanks again.
Mike
Old 12-04-2009, 01:59 PM   post #6 of 13
ed-nh
Bolens 1886-01
ed-nh's Avatar
MTF Member # 29037
Also, I have a really nice deck for my G14 if you need any sort of pictures.
__________________
CLICK HERE
Restored:
853, 1556, 1556 Loader, custom 1856, 1669, 1886, HT23
Restored:
tillers, 3pt, sleeve hitch, E-Z Vac, mowers, single & 2 stage blowers, moldboard, front and rear pto chippers/shredders, wheelbarrow attachment, aerator
ed-nh is offline   Reply With Quote Quick reply to this message
Old 12-04-2009, 09:02 PM   post #7 of 13
Tencubed
3K Poster!!!!
MTF Member # 31735
ed-nh:
Pictures would be helpful even if I don't end up with this particular machine. It would be nice to know what to look for and what all parts are needed. I have been able to get a lot from the parts manual pictures but real photos would be better.
Thanks
Mike
Old 12-04-2009, 10:55 PM   post #8 of 13
ed-nh
Bolens 1886-01
ed-nh's Avatar
MTF Member # 29037
Here you go Mike. Some pictures of my G14 mower deck. I have not yet attached it but the previous owner used it many times. I hope this helps.
Ed-
ID:	84543   Click image for larger version
ID:	84544   Click image for larger version
__________________
CLICK HERE
Restored:
Restored:
Old 12-04-2009, 10:55 PM   post #9 of 13
ed-nh
Bolens 1886-01
ed-nh's Avatar
MTF Member # 29037
More pics
ID:	84546   Click image for larger version
ID:	84547   Click image for larger version
ID:	84548   Click image for larger version
__________________
CLICK HERE
Restored:
Restored:
Old 12-04-2009, 10:58 PM   post #10 of 13
ed-nh
Bolens 1886-01
ed-nh's Avatar
MTF Member # 29037
A few more pics including a couple that were posted from the user guide on this forum in another post.
ID:	84550   Click image for larger version
ID:	84551   Click image for larger version
ID:	84552   Click image for larger version
__________________
CLICK HERE
Restored:
Restored:
Old 12-05-2009, 12:10 PM   post #11 of 13
Tencubed
3K Poster!!!!
MTF Member # 31735
Ed:
That helps a lot, thanks for taking the time to post those. I got a line on a couple of possible sources for a deck now.
A 42" deck would work well for my needs, want something to set as high as I can get it to knock the tops off weeds and small brush then the brush hog behind the tractor can do a better job of grinding things up. May even use it to mow the lawn.
Thanks for the help.
Mike
Old 12-05-2009, 02:13 PM   post #12 of 13
nsconductor
jbs1257
nsconductor's Avatar
MTF Member # 1700
Images: 1
There are about 7 different mower decks that will fit on ALL tube frame tractors, You just need the particular mounting hardware for those style decks. Just about any attachment is interchangeable on all of the tube frames with a mounting hardware change. Tube frame tractors have not changed over the years as far as basic design goes.
nsconductor is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-05-2009, 10:29 PM   post #13 of 13
*Ryan
Senior MTF Member
MTF Member # 34589
ahh beat me to it, my g12 deck looks like that
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
