Mower Deck lift knob question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 11-23-2009, 09:00 AM   post #1 of 11
rrmccabe
I color outside the lines
rrmccabe's Avatar
MTF Member # 34789
Default Mower Deck lift knob question
Is it normal for the adjusting knob for the mower deck to spin around when the deck is in the raised position? I would not think this is normal.
If set my deck height and then raise it for whatever reason it will vibrate around to another height.
I am guessing this is going to happen with the snowblower as well. since it vibrates up (higher) the snowlblower will be a big issue as its going to get raised and lowered often.
Seems there should be some type of friction device in there to keep it from turning.
__________________
1967 Original 110 Round Fender with model 80 cart
2010 2305 with 200cx loader
rrmccabe is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-23-2009, 10:34 AM   post #2 of 11
Kansas John Deere
Proud Member of the 1K Club
Kansas John Deere's Avatar
MTF Member # 32517
Images: 1
Default Re: Mower Deck lift knob question
I am not sure on a 345 but on my 300 there is a "jam" nut under the knob to lock it down so it doesnt move. Could you take a pic and post exactly what yours looks like perhaps?
Kansas John Deere is offline   Reply With Quote Quick reply to this message
Old 11-23-2009, 10:39 AM   post #3 of 11
rrmccabe
rrmccabe's Avatar
MTF Member # 34789
I pulled the knob off and all I could see was a snap ring.
Looking at the parts break down the shaft comes up through a bushing and the snap ring goes on. Then the knob just slides onto the shaft.
I dont see any way to kep it from vibrating around.
__________________
Old 11-23-2009, 10:48 AM   post #4 of 11
x595
JD RULES
x595's Avatar
MTF Member # 23848
Images: 3
rrmccabe , #6 is a spring clip that locks the knob at each setting , I believe it's either unhooked or missing ...
Later,x595
__________________
2005 JD X595 w/ HDAP Tires
54c MMM --- (SOLD)
62c MMM
54" Quick Hitch Front Blade
4x8 Utility Trailer - 1500# Axle
North Star 15,000 Watt Generator
Troy - Bilt Super Bronco Rear Tine Tiller
Troy - Bilt 2500 PSI Pressure Washer
22" Yard Machine Push Mower
SpeeCo SplitMaster 28 Ton - Horizontal/Vertical Log Splitter
STIHL 025 - 18" Bar
STIHL 025 - (Spare Parts Saw)
STIHL MS 290 FARM BOSS - 20" Bar
STIHL FS 45 Trimmer
x595 is offline   Reply With Quote Quick reply to this message
Old 11-23-2009, 10:51 AM   post #5 of 11
rrmccabe
rrmccabe's Avatar
MTF Member # 34789
Ahh, that makes sense. The bend in the spring clip must ride against #3.
I wil have to get under there and look and see if its there
Thanks
__________________
Old 11-23-2009, 07:27 PM   post #6 of 11
farmer69
MTF Member # 27775
My knob on my GX345 is pretty loose when you have the deck raised. Spins real easy, I thought the same thing but someone else on here said its normal.
farmer69 is offline   Reply With Quote Quick reply to this message
Old 11-23-2009, 07:45 PM   post #7 of 11
rrmccabe
rrmccabe's Avatar
MTF Member # 34789
I think yours is broke too Farmer.
Apparantly its a common issue. My cousin has a 325 and 720. He says his 325 spun freely when he got it used from JD dealer. He asked them about it and the dealer put a new spring clip in it and its been fine since.
__________________
Old 11-23-2009, 08:07 PM   post #8 of 11
GR8racingfool
JD Green all the way~!
GR8racingfool's Avatar
MTF Member # 22107
On my 300 it does not spin, but it does get loose when the deck is raised and it kinda vibrates around while the engine is running. Lower the deck back down, good to go.
~F~
GR8racingfool is offline   Reply With Quote Quick reply to this message
Old 12-01-2009, 02:56 PM   post #9 of 11
boricat
MTF Junior Poster
boricat's Avatar
MTF Member # 6437
Images: 2
I can confirm that you need to install a new #6.
__________________
1999 JD 445 48" deck 47" snowblower 3 Pt. hitch PTO
Superior Scoop Wanting cab for winter!
boricat is offline   Reply With Quote Quick reply to this message
Old 12-01-2009, 02:57 PM   post #10 of 11
rrmccabe
rrmccabe's Avatar
MTF Member # 34789
I ordered one last week. Not here yet
Be installing that and the Halogen upgrade kit at the same time.
__________________
Sponsored Links
Advertisement
Old 12-03-2009, 08:34 PM   post #11 of 11
rrmccabe
rrmccabe's Avatar
MTF Member # 34789
Fixed.
For those with same issue you need to remove the rear fenders/seat and running board section to get at it. Not a big deal.
Sorry for the crappy cellphone picture but the spring clip goes from the slot at top of picture to the bolt on lower left. The bump/bend on the spring rides against indentations and keeps the knob from spinning.
Replacement part is under $2.00.
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
