| Home | MTF Gallery | Add To Favorites! | Set MTF As Your Homepage | FAQ | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Thread Tools | Display Modes |
#1 |
MTF Junior Poster
MTF Member # 30557
Hi,
I just purchased a new bolens. It it called a bolens eliminator. It is a model 2000. I was wondering what I should be using in the transmission. I am new to these and I have no idea what I should do since I did not get a manual with the tractor. thanks, Jason |
#2 |
Senior MTF Member
MTF Member # 28340
welcome to the forum
parts & full service manuals are available, free download, at the below link http://www.sonnysbolens.com/diagrams.htm as to fluid, your hydro and rear axle use the same fluid, - eaton recommends "premium hydraulic fluid" (avaliable at NAPA), or Type "F" ATF fluid, or automotive engine oil, in that order your trans holds 8 qts of oil - the napa oil is available by the gallon, $11/gal, or the 5 gallon bucket for $44 - those were prices here in richmond i'll post a part number for the Napa fluid in a bit, there's also a spin oil filter, and again NAPA has em here's the info - had this on a different computer - got the oil info either off one of the bolens parts sales website or the eaton web Manufacturer Oil TYPE or Part # ALLIS CHALMERS -- HPF821 AMOCO -- 1000 ATLANTIC RICHFIELD -- ARCO TRACTOR FLUID J.I. CASE -- TFD FLUID CHEVERON -- TRACTOR HYDRAULIC FLUID CONOCO -- POWER-TRAN II FLUID JOHN DEERE -- TYPE 303 EXXON -- TORQUE FLUID 56 FORD -- 134 TRACTOR HYDRAULIC FLUID GARDENWAY/ BOLENS -- 1738157 GALLON INTERNATIONAL -- HY-TRANS FLUID KENDALL -- HYKEN 052 LION -- HT FLUID MASSEY FERGUSON - M-1127 PERMA-TRANS FLUID MOBIL -- MOBIL FLUID 424 NAPA - 85-401 GALLON UNIVERSAL HYDR FLUID OLIVER -- OLIVER 55 FLUID PENZOIL -- HYDRA-TRANZ & WET BRAKE FLUID PHILLIPS -- HG FLUID QUAKER TRACTOR HYDRAULIC / TRANS FLUID SHELL -- DONAX T-4 TEXACO -- TDH OIL UNION -- HYDRAULIC TRANS FLUID VALVOLINE -- UNITRAC WHITE -- Q- Bolen hydraulic oil filter WIX #51410 Wix also sold by napa as napa 1410 filter) Sourced from yourautosupply.com for $6.54 per filter http://www.yourautosupply.com/produc...ers.asp?cID=24 Part Number: 51410 UPC Number: 765809514102 Principal Application: Ariens, Bolen, IHC, John Deere, Kohler, Toro All Applications Style: Spin-On Hydraulic Filter Service: Hydraulic Type: Full Flow Media: Paper Height: 3.790 Outer Diameter Top: 3.660 Outer Diameter Bottom: Closed Thread Size: 3/4-16 By-Pass Valve Setting-PSI: None Beta Ratio: 2/20=17/41 Burst Pressure-PSI: 325 Max Flow Rate: 7-9 GPM Nominal Micron Rating: 21 Gasket Diameters Number O.D. I.D. Thk. Attached 2.729 2.415 0.200 Last edited by larryccf : 11-21-2009 at 08:23 PM. |
#3 |
MTF Junior Poster
MTF Member # 24201
napa hydraulic fluid is 85-101 gal
85-105 5 gal or transmission hydraulic fluid (hytran) 85-401 gal 85-405 5 gal ![]() |
#4 |
jbs1257
MTF Member # 1700
You might want to double check the atf type "f" . The Bolens service manual says hydraulic oil which is 20w oil, not atf. Most eaton 11's use hydraulic oil where as the eaton 10's use type f atf.
#5 |
Senior MTF Member
MTF Member # 28340
at the bottom of the below chart taken from sonny bolens web, is the recommendation for ATF "F" - i don't know where sonny got that chart, but as it's listing oil recommendations by eaton model numbers, i assume he got it from eaton, seems most recommendations for ATF "F" are for the earlier models, but dependent on temperature environment, it appears to be recommended for most models. But given it's difficult to find, i didn't bother looking for it.
![]() and he also has this chart on his web (link to the above image is on this linked page http://www.sonnysbolens.com/identifythis.htm when i spoke with LJ Hydraulics, the eaton 11 rebuild specialists that Ray Duff recommended, he simply indicated 20 wgt hydraulic oil below is the last page in the eaton svc manual for the model 11, listing the recommended fluids ![]() the recommendations for viscosity are in Cst - i've got some silicone oil in the shop, 200 Cst is approximate 25-30 wgt motor oil (this is a visual assessment from pouring it, not anything measured scientifically - someone might want to pull up a conversion chart on the web) and i just looked at my 5 gal bucket of NAPA hyd fluid - label sez "Heavy Duty Tractor & Hydraulic Fluid", and lists the mfgr's specs it meets - only one i retained (my mental ram is limited) is "JD120C", but it also listed Case 7& Massey Ferguson specs. while it's not 30 wgt motor oil viscosity, from just pouring some, it looks like what i assume to be 20 wgt viscosity someone might want to research it on the web Last edited by larryccf : 11-23-2009 at 10:29 AM. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
