GX345 Time Delay Module - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 11-21-2009, 06:23 PM   post #1 of 18
Hammered
MTF Member
MTF Member # 32037
Default GX345 Time Delay Module
Well, thanks to this forum I recently bought a 2005 model GX345 with 54" deck and less than 300 hours for $3,500 It was over my budget, but that seems to be the norm for folks that come here for advice.
I mounted a 48" snow blade today that I found locally and began having problems with the mower starting. I traced it down to an intermittant connection around the starter/ignition module where I had to attach the angling kit bracket. It looks like it's at the time delay module. Does anyone know how to bypass this thing so I can make sure?
Hammered is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-22-2009, 11:34 AM   post #2 of 18
rrmccabe
I color outside the lines
rrmccabe's Avatar
MTF Member # 34789
Default Re: GX345 Time Delay Module
I dont think there is any easy way to bypass that module. They have seat, brake, PTO and reverse tied into that thing.
I think I read its a Kawasaki thing built to JD spec. There are other brand modules on the market that are not as tight on safety that you could swap it with.
But if you are looking for a jump x to y fix, I dont think there is one.
__________________
1967 Original 110 Round Fender with model 80 cart
2010 2305 with 200cx loader
rrmccabe is offline   Reply With Quote Quick reply to this message
Old 11-22-2009, 08:30 PM   post #3 of 18
Hammered
MTF Member
MTF Member # 32037
Thanks, but from what I understand this thing is a timed cutoff switch that drives the spark and fuel pump. There is a black ground, red positive (haven't tested it to see if it's full-time or switched) an unknown orange wire and two yellow wires that appear to be an in and out to drive the coils. The yellow wire is simple to bypass, but I don't know if the orange wire needs to be made to ground or to positive or something else to bypass this thing.
Anyone know where I can get a wiring schematic?
Old 11-22-2009, 09:59 PM   post #4 of 18
jdkubotamurray
Guru on the Mountain
jdkubotamurray's Avatar
MTF Member # 147
$17 at dealer, 5 min to swap.
You might want to keep in the circuit as it works well for shutdown.
I put one on my 2004 GX345 due to intermittant start issues, works like a champ now.
jdkubotamurray is offline   Reply With Quote Quick reply to this message
Old 11-22-2009, 11:23 PM   post #5 of 18
Hammered
MTF Member
MTF Member # 32037
I will replace it if it's bad. I'm just trying to find a way certain to diagnose it because I hate the trial error approach to fixing stuff.
Old 04-02-2011, 10:28 PM   post #6 of 18
QRoo
MTF Junior Poster
MTF Member # 57555
2005 GX345 with a similar issue. No spark, engine cranks, ran fine two weeks ago and all winter blowing snow, tested the seat switch and that is fine although when I tested the seat switch plug I got no continuity. Is this always an open circuit. Where is the time delay switch mounted that I have been reading about. Any pics would be appreaciated.
QRoo is offline   Reply With Quote Quick reply to this message
Old 04-02-2011, 10:47 PM   post #7 of 18
MXZRXP
3K Poster!!!!
MXZRXP's Avatar
MTF Member # 48748
yup, you just want to bypass it to see if that is the problem not remove permanently! that makes sense...
this part of the post stuck out: "...where I had to attach the angling kit bracket..." If I am reading right the problem only started after installing the angling bracket??
If yes, I don't beleive in concidences, I would re-examine the install, did a peice of wire get chaffed or a screw intercept a wiring harbness???
I can provide an electrical schematic for the 345 (20 HP KAW), I believe it is the same.
PM me if you want it...
__________________
STX38 (yellow deck)
345 48C Deck, 42" Blower, Curtis Cab
Propane HEAT (sweet!)
Blower in action here:
http://www.youtube.com/watch?v=8dyoup-StaA
MXZRXP is offline   Reply With Quote Quick reply to this message
Old 05-11-2013, 01:11 PM   post #8 of 18
Interrex
John Deere
Interrex's Avatar
MTF Member # 62450
I thought I had a bad ignition module, all it was was this delay timer. Went to pick it up at the dealer ($23) and they said they have had a bunch of GX 345 with corrosion and delay timers bad. So check your connections also mine was corrosive also..
Interrex is offline   Reply With Quote Quick reply to this message
Old 08-18-2013, 05:22 PM   post #9 of 18
QuantumRift
MTF Member
MTF Member # 99809
I have a JD 345 - it too, has a TDM that is giving me fits. Takes forever to start, then once it does, I can mow for about 12 minutes (timed it), then it coughs and dies. Most times it wont restart unless I take a break and have a bottle of water, etc. Then it starts. I have bypassed the seat switch as my seat is ragged out and pretty much in need of replacement. I will get a TDM for R&R but I'd just like to bypass it as well if possible.
__________________
John Deere 345 Garden Tractor, 54" Deck
Gravely XD3 Self propelled walk behind
JC Penney #1859 Garden Tractor
QuantumRift is online now   Reply With Quote Quick reply to this message
Old 08-18-2013, 07:14 PM   post #10 of 18
man4mopar
Senior MTF Member
man4mopar's Avatar
MTF Member # 119794
Does it look/match this? Have it attached but may be larger/clearer here http://www.tractorbynet.com/forums/a...on_circuit.jpg
I would test voltages key off and key on
If so it should have 12 volts all the time at the red wire. from starter to module.
Green on sheet but labeled yellow from module should have 12 volts when key is on only.
Red labeled yellow/white? going to ignition coils should be 12 volts with key on maybe even with key off. Will need 12 volts to run though.
Orange going to ignition control module I am not sure but assume is 12 volts with key on and the delay module will stop the 12 volts after a given time when no longer getting the 12 volts from the yellow wire(green on diagram)
Name:	time delay module.jpg
man4mopar is offline   Reply With Quote Quick reply to this message
Old 08-19-2013, 06:48 PM   post #11 of 18
QuantumRift
MTF Member
MTF Member # 99809
Well for $20.00 (actual price from John Deere Dealer in Lancaster OH), I picked up a TDM this morning and replaced it and it 100% fixed the problem. NO more cranking and waiting and cranking...no more coughing and dying and waiting to restart. Best $20 I've spent in a long time and worth it.
Also, it's a GOOD idea to thoroughly examine and clean all electrical connectors as well. In working this issue I found the coil wire connections corroded. On the RIGHT coil, when I attempted to remove the wires to clean the spades and connectors, one of the spades on the coil actually broke off at resin level! SO that was a $50 coil to replace. The wire connections on the LEFT coil were also in terrible shape, so just replaced all the connections with new ones, and once I attached them to the coils, I used liquid electrical tape to generously coat the connections to prevent new corrosion.
I found connectors on the ignition board to be cruddy and dirty and they required cleaning with CRC Electrical Contact cleaner. I found the stud, bolt and connections under the starter to be corroded as well and I removed all those and cleaned them when replacing the TDM. Where the TDM grounds to the bolt (one of the two bolts that holds the ignition ignitor) I found another bad ground wire that needed a new connector. I also found a hole about 3/8" in diameter that either had burned or eaten or worn thru the top of the ignition ignitor (near the upper bolt). I was going to replace the ignitor until I found the price was $275 (dealer price). So I figured I'd patch the hole and see if it still worked. It did, so I didn't have to spend the $275 for THAT.
So to sum up, the TDM fixed the issue, but I also found corroded and broken wires which I replaced. I also make it point to keep those battery terminals clean and corrosion free.
__________________
Old 08-19-2013, 07:02 PM   post #12 of 18
PEIDeerefan
Proud Member of the 1K Club
PEIDeerefan's Avatar
MTF Member # 18351
Images: 2
Replaced the TDM on my GX345 this spring after the same issues that you had. Thanks to the great help and past experience on this forum, fixed it myself also at a small price.
__________________
2011 John Deere X530 with 48 inch deck
44 inch snowblower, chains, 4 suitcase weights, JD plastic wheel weights
OTC Cab and winter grill cover
2002 John Deere GX345 with 48 inch deck
48 inch John Deere snow blade, 4 suitcase weights and rear tire chains
Power flow bagger
John Deere #80 cart
40 inch Brinly plug aerator
48 inch Brinly lawn roller
PEIDeerefan is online now   Reply With Quote Quick reply to this message
Old 08-19-2013, 07:06 PM   post #13 of 18
PEIDeerefan
MTF Member # 18351
Images: 2
Seems like a lot of corrision for a low hour 2005 tractor. Was it left outside for a lot of its life by the PO?
__________________
Power flow bagger
John Deere #80 cart
Old 04-19-2014, 03:13 PM   post #14 of 18
Harryc
Diesel Power
Harryc's Avatar
MTF Member # 66572
Garage
On a 345, would the TDM cause a 5 or so second delay after you jump off the seat or turn off the PTO for the engine to stop? Parking brake not applied. Not exactly the symptoms described in this thread ...
Harryc is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-19-2014, 04:05 PM   post #15 of 18
Xcopterdoc
Senior MTF Member
Xcopterdoc's Avatar
MTF Member # 19175
Quote:
Yes it would. In fact thats the purpose behind it. It reduces the annoying shutting off over rough ground where you might be coming off the seat. Works great for those of us that are slight of build.
If one of you guys that had a bad TDM and saved the old one, CAREFULLY cut it open and see whats in there. Then post the pic to let everyone see what 20 bucks buys! LOL!
Xcopterdoc is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
