| Home | MTF Gallery | Add To Favorites! | Set MTF As Your Homepage | FAQ | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Thread Tools | Display Modes |
#1 |
me
MTF Member # 5386
So I am considering offering on a 2 story home, with no existing garage. The land is sloped down the side of the house so that the one end is exposed down to the first story floor, and the other levels out at the 2nd story floor. It looks like a garage could be added by digging out the dirt, pouring footers, concrete floor.
Are permits needed to do this kind of work? What if I don't physically connect the garage with the existing house foundation? Never had to do this kind of thing before so any pointers or tips are appreciated. ![]() |
#2 |
Blabbermouth
![]() Join Date: Nov 2008
MTF Member # 20164
Start with your county building office. they can give you quite an education.
#3 |
Senior MTF Member
MTF Member # 9590
Permits will definitely be needed. How else would the assessor know to raise your property taxes?
Also there will/may be zoning restrictions. In our township there are restictions on the size and height of accessory buildings. These zoning restrictions definitely affected my pole building height which was just completed: Pole building construction |
#4 | |
Senior MTF Member
MTF Member # 30999
Quote:
I'm in the process of getting a garage built. Why don't I do it myself...not worth it, for about roughly $1500 more than buying the material I can get it done. For me it was a 6 month PIA process, long story short: Bought house and property, lot wasn't big enough for garage so I bought the adjoining lot, can't put garage on separate lot so I had to join it to the first lot, had to get it surveyed and septic tested which cost me over $5K for basically nuttin as my first lot was origonally cut from the lot I bought. Typical government crap hurry up and wait and getting different answers to the same question as no one could tell me the exact steps and in what order they were required. To that end get everything in writing that anyone tells you. I lucked out in that the surveyor I hired was a smart guy and knew the process better that the municipality. A garage around here that's over 600sf has to be on an engineered slab and there's numerous other stipulations as to setbacks from the front, it can't be closer to the road than the front of the house. No floor drain, minimum slab thickness yadda, yadda, rant off <G>....Mike |
#5 |
Senior MTF Member
MTF Member # 29420
I would start by asking a contractor to look @ it, location is everything, and on a hill you must keep the footing/ foundation stepped, if you cheat, could the garage push into the house, or slide away from the house. Soil has a lot to do with this. Just my thoughts.
Mouse
__________________
1962 Cub Cadet Orginal 1963 Cub Cadet 70 1966 Cub Cadet 122 1969 Cub Cadet 125 2009 Cub Cadet LTX1046VT 1937 Chevy Truck |
#6 |
me
MTF Member # 5386
Well the more I think about it, putting the garage right next to the house is less appealing.
What would something like this cost to put up? I'm probably forgetting something in the materials... Shed size: 18' x 24' x 10' w/ 4" concrete slab and low-slope gable roof * 6 cu. yd. poured concrete (4" depth + footers) * 896 concrete blocks 8" x 8" x 16" (776 sq. ft. of wall) * 68 cu. ft. mortar * roll-up door 8 x 8, -64 sq. ft. * steel door 80" x 32" and frame * no windows * GFI drops every 6' * low-slope gable roof w/ 20 yr. shingles |
#7 |
Senior MTF Member
MTF Member # 30999
Can't comment on the cost of yours but for comparison when someone does <G>
22' x 26' x8' wood frame, 4" slab, 5/12 storage trusses, vinyl sided, man door, 7' x 9' garage door, no electrical nor interior work CAN.$15K, US$14,200.....Mike |
#8 |
Rara Avis
![]() Join Date: Dec 2007
MTF Member # 8602
These guys do work up and down the east coast...they may be able to help you...
![]() http://www.horizonstructures.com/garage_landing.asp
__________________
Paul in VT The information is provided without warranty of any kind. I give no warranties either expressed or implied, including warranties of merchantability and fitness for a particular purpose. In no event shall I be liable for any damages whatsoever including direct, indirect, incidental, consequential, loss of business profits or special damages, even if I have been advised of the possibility of such damages. |
#9 |
Citizen of Earth
![]() Join Date: Mar 2005
MTF Member # 51
My very first step would be scouting ou tthe local Better Business Bureau for good local contractors, then get one on site to give you info on what he would recommend, what kind of permits needed, and a rough idea of costs, before you even contact your local municipality.
__________________
If it's FREE, it's for ME! ALWAYS remember to remove the spark plug wire from the plug before sticking your hand in the machine!!!! The fingers you save could be your own. |
#10 | |
Proud Member of the 1K Club
MTF Member # 8013
Quote:
I've built a number of structures on my property without permits and figure it's saved me enough that if I have to hire a lawyer to deal with the gestapo I'll still be ahead. Best to talk to people in the area and get a feel for how stringent the local authorities might be. |
#11 | |
Senior MTF Member
MTF Member # 9590
Quote:
If the local authorities have a building code and permit system they can chose to enforce it. It usually is someone's job to do so, so I suspect that this person wants to look busy. Are the locals who you ask about enforcement, going to bail you out if their free advice is wrong? Regarding the cost of fighting city hall.. The local county fair in my county built a building without a permit. The logic they put forth at trial was that the building was agricultural and didn't require a permit and they were the county fair and didn't need to get a permit anyway. At trial, they lost, had to buy the permit, pay the penalties, pay their attorney (I presume) and were required to make substantial changes to the building after the fact. These changes were extremely costly so they determined it was best to tear it down, and comply with the law. By the way, they had to pay for permits the second time also. |
#12 |
The Left Coast Mod
![]() ![]() Join Date: Mar 2005
MTF Member # 21
My post building that I had built by a reliable contractor was 38 X 36 and had a raised center portion to house a 5th wheel trailer was $35,000.00, the contractor did all the work on getting the permits, getting a excavator in to level the area and construct the building. This included a 60" sidewalk around one side and the back and a 20' approach in front.
Everything went smooth and start to finish after the permit was granted was 8 weeks. You can see more by my thread that I posted at this link, sure there was a giltch in the plan but it turned out to be a minor setback and only took 4 hours to correct. http://www.mytractorforum.com/showth...highlight=shoe I did tackle the painting and the electrical work
__________________
1979 Kubota L1801 with a 49" FEL FOR SALE 1989 Kubota T1400 2003 John Deere L120 2009 John Deere 2305 with a 53" Fel, 62" MMM and the 260 BackHoe 1994 Plymouth Acclaim V6 1994 Chrysler LeBaron 4 door V6 1996 Dodge Ram V 10 1999 Dodge Ram Diesel 1995 Alpenlite 28' 5th Wheel Toys I got em |
#13 |
MTF Member
MTF Member # 31137
I agree, I would find a reputable contractor & meet with him to discuss what you are wanting to do & see if its feasible first. Then proceed with getting floor plans, secure financing, then do the permits.
__________________
2009 - X520 Deere , 26 HP Kawi with 54" Deck, 4' Steel Roller, 4' JD Aerator, Seed Spreader, |
#14 |
2000 Posts and climbing!!!
MTF Member # 8155
Don't cut cost with 20yr roofing. You don't save much and in the long run it will cost more.
__________________
73 - SS/16, ST/16 & ST/12, 68 - SS12, 3ph's with tiller, 8" & 10" plows, Disc, Cultivator, Leveler Blade, 46" Dozer Blade's, Couple mowing decks, 67 Custom 6 with mowing deck, 59 David Bradley, The frist Suburban, 04 GT5000 48" deck, 48" dozer blade |
#15 |
3K Poster!!!!
MTF Member # 8867
Here,if you built a garage attached to the house,it would have to be sheetrocked on all walls and ceiling, with fire resistant sheet rock AND plastered over it,making it "airtight"..(thats how it was in '77 when our house was built anyway..)..plus your house insurance costs will go up,due to the added risk of a fire from a vehicle or equipment stored in it..
If you built one free standing,there are laws about setback from the house and other properties that must be followed..a building permit is required for any structure over 100 sq.feet ,or one with a permanent foundation.. They frown upon "tent" garages and truck bodies used as sheds,but so far haven't banned them--many towns close by have already though..those steel "carports" are gaining popularity over the "fabric" garages.. There WAS a really nice factory built steel building about a 1/4 mile up the road from our house,about 100 x 100 feet and 20' high..very nice looking building..but the contractor who erected it on the property he owned it sat on,figured he didn't "need" a building permit,guess he was friends with the inspector and thought he could get away with it..well,a neighbor across the street protested,said it was an eyesore and detracted from his property value,and the contractor was running his bussiness "illegally" in a residential zoned location --it ended up in court.. --after several years of feuding,the court decided in the neighbors favor,the building HAD to be taken down,and all the construction equipment the contractor parked outside in retaliation was ordered removed from the property as well,plus he was fined several tousands of dollars..(He had parked a junk Euclid and several dozers,etc in front of the building,declaring "if that "neighbor" wants an "eyesore",hows THIS?!)...the neighbor put his home on the market, and moved away only months after the building dissapeared !.. So,I wouldn't build anything here without following the codes and restrictions,especially now that the town is looking for ANY way to make money on these hard times..lately they have been cracking down on properties with a lot of clutter or unregistered vehicles,etc.. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
