Idler Spring Broke - 20hp 46in Deck - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 11-05-2009, 11:19 PM   post #1 of 7
MikeD94
MTF Junior Poster
MTF Member # 34639
Default Idler Spring Broke - 20hp 46in Deck
Hello all. I have a problem with my MTD riding mower (model no. 13AI608H062). It has a single speed transaxle with variable speed pulley. This problem started after a spring (tying double idler pulley to the transmission idler pulley) broke.
I ordered a correct new MTD spring. Installed it then went cutting but the speed of the mower is much slower than before. There is no slipping (it climbs hills fine). If I really push down on the pedal really hard its speed increases close to normal speed.
Could the belt stretch instantly when the spring broke? I don't think so. But the belt seems to be really loose even when pressing down on the pedal. I have no idea what is normal in regard to how loose the belt should be.
Could the problem be related to the variable pulley? How do I check this
pulley for normal operation?
Okay, I just removed the variable speed pulley and it looks fine. Same for the belts. The pulley slides and rotates smoothly. So that rules out a problem with the variable sp pulley.
I took a pic of the idler pulley arm with a new spring put on. Is there anything missing? Perhaps there should be another spring from the transmission idler pulley to the tab at the rear just under the transmission pulley? My manual is not clear on what springs go where.
Please disregard the belts in the pic. They are off the pulleys.
Any help is appreciated.
MikeD
MikeD94 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-05-2009, 11:43 PM   post #2 of 7
1086
3K Poster!!!!
1086's Avatar
MTF Member # 1086
Images: 11
Default Re: Idler Spring Broke - 20hp 46in Deck
MikeD
Mike,welcome to the forum.
The only MTD I ever worked on had two springs and idlers as I recall. The operator had control of the tension on the one the pedal or lever was hooked to and the other spring was fixed.
If it worked correct before the spring broke it seems like maybe you were either given the wrong spring or possibly it is hooked in the wrong location.
Sorry I can't be more precise with the help. Hopefully someone more familiar with your model or with a manual and diagram will chime in.
1086 is offline   Reply With Quote Quick reply to this message
Old 11-06-2009, 09:09 AM   post #3 of 7
MikeD94
MTF Junior Poster
MTF Member # 34639
Thanks for the welcome!
Anybody else with suggestions?
Old 11-06-2009, 10:52 AM   post #4 of 7
Woofer
Senior MTF Member
Woofer's Avatar
MTF Member # 28015
My deck is much older and setup different than yours so i won't be much help either, other than to say your thought of something missing to that second tab was the first thing i thought of when looking at your pictures. Hopefully by this evening someone will chime in maybe even with a manual and get you pointed in the right direction. Good Luck!
Woofer is offline   Reply With Quote Quick reply to this message
Old 11-06-2009, 09:06 PM   post #5 of 7
MikeD94
MTF Junior Poster
MTF Member # 34639
I think I figured out what's wrong. I hooked up one end of the spring to the wrong part. The spring should mount from the transmission idler pulley to the frame.
The owners manual was no help and neither was the local lawn mower shop when I inquired about where the spring go. The shop looked up on their computer which pulled up the same thing as my manual.
I found it by researching the 'net and came across this:
http://manuals.mtdproducts.com/mtd/D...=769-02100.pdf
It's for a Cub Cadet which has similar drivetrain as the MTD.
Old 11-06-2009, 10:08 PM   post #6 of 7
texas lawn ranger
Senior MTF Member
texas lawn ranger's Avatar
MTF Member # 13221
Images: 7
MikeD94,
Thanks for posting the link to the Cub Cadet service manual. I reviewed it carefully, specially the section of the variable speed pulley and adjustments. This would have helped me weeks ago when I struggled with a neighbor's MTD 607.
texas lawn ranger is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-07-2009, 08:50 AM   post #7 of 7
1086
3K Poster!!!!
1086's Avatar
MTF Member # 1086
Images: 11
Just glad we could be of assistance.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
