how to check oil properly on 11hp B&S motor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 10-24-2009, 02:04 AM   post #1 of 4
lobsterbox
Slowly turning green...
lobsterbox's Avatar
MTF Member # 32341
Images: 3
Default how to check oil properly on 11hp B&S motor
hi i have an 11 horsepower Briggs&Stratton flathead motor with a dipstick for checking the oil. I believe i have overfilled the oil in this motor, but it doesn't seem to smoke or knock during normal operation and i am not sure how to properly check the oil on one of those motors. are you supposed to thread the dipstick all the way in? or just hold the cap on the end of the tube for a few seconds and then look. if you are supposed to thread it all the way in, then i believe i have overfilled it alot, and oil is leaking out around the dipstick seal. the engine is on an older mower which I purchased this season and changed the oil when I got it, only mowed with it twice and cut about an acre of yard in total. It preformed very well and only smoked when it was very warm and had just come of of mowing.
so these are my questions: **READ ABOVE FIRST**
how do you check the oil on a flathead Briggs&Stratton motor with a dipstick?
are there any negative consequences with overfilling the oil?
under light use have i done any irreparable damage to the engine?
if i know how to check the oil properly, I can fix things up, so please respond to this post and give me some help!!
thanks, lobsterbox
__________________
My Youtube Channel: lobsterbox20
2000 John Deere 425 w/ 54" Deck, 46" Snowblower
1992 John Deere 322 w/ 50" Deck, 46" Snowblower, 42" Tiller, Powerflow
1978 Sears GT/19.9 "Lundbreck" Twin ~300hrs (Mower)
1973 Sears SS/16 V-Twin (Loader)
1975 Roper RT/16 (3 Point Hitch)
lobsterbox is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-24-2009, 02:57 AM   post #2 of 4
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
Default Re: how to check oil properly on 11hp B&S motor
In my opinion, the slight difference in oil level (between screwing the cap in or not) doesn't matter. For the record, my two B&S engines (one Vanguard, one 8 HP flathead) want the cap screwed in for checking the oil level. I usually don't screw the cap in, and allow for the slight difference when I read the stick.
__________________
Remember, I'm pullin' for ya! We're all in this together!
(Red Green)
Living in The Land Of The Free - because of The Brave!
Fcubman is online now   Reply With Quote Quick reply to this message
Old 10-24-2009, 09:44 AM   post #3 of 4
Walt 2002
Senior MTF Poster
MTF Member # 1229
" are you supposed to thread the dipstick all the way in?"
As far as I know, ALL B&S engines stipulate screwing the dipstick in.
"and oil is leaking out around the dipstick seal. "
This is an indication that the rubber seal is "dead" and needs to be replaced, has nothing to do with oil level.
Walt Conner
Walt 2002 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-26-2009, 09:08 PM   post #4 of 4
bser
MTF Member
MTF Member # 7211
The general rule is screw in dipstick unless there is a sticker on the side of engine near the dipstick that says differently.
bser is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
