Is this the proper place? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
ATV's, RTV's, UTV's, and Snow Mobiles For fun or work or play
Old 02-19-2012, 02:36 PM   post #1 of 10
BillTheTractorMan
Tractor addict
BillTheTractorMan's Avatar
MTF Member # 30045
Images: 6
Default Is this the proper place?
I just bought an '83 Honda 200E ATC and I'm looking for some help.
It runs ok, idles a bit high as the clutch is always engaged it seems like. It's been sitting a while but started right up on the old gas and ran... so-so... Now it will run fine though with new gas.
I don't know how to work these carbs. How do I lower the idle speed?
Also it wants choke---full choke to run. I'm guessing it's running lean. Where's the mixture screws to adjust the mixture?
I cleaned the carb this morning and it made a difference, but still having the above issues.
I will get a video of it in the next hour or so, got some other things to do first.
Sears GT group (suburbans/customs/etc)
http://www.facebook.com/groups/101589189889692/
Growing website for user based uploads about Sears tractors. (file sharing, forums for posting and reading guides, etc)
http://www.mysearstractor.com/
BillTheTractorMan is online now   Reply With Quote Quick reply to this message
Old 02-19-2012, 02:51 PM   post #2 of 10
Ken in NJ
Ken in NJ's Avatar
MTF Member # 284
Default Re: Is this the proper place?
This is the proper place, so yes
Thats all I can answer.
Ken in NJ is offline   Reply With Quote Quick reply to this message
Old 02-19-2012, 02:55 PM   post #3 of 10
davidg
The Travelin' Mod
davidg's Avatar
MTF Member # 807
Images: 2
http://5ne245.1fichier.com/en/ is the manual, it covers everything.
the mix screw is on the bottom of the carb and takes a SHORT screwdriver to reach. the idle screw is on the right side as you sit, about at the point where the tank and fender overlap.
if the carb is hosed, buy one on Ebay for about 25.00. that's what i just did on my 185 and it runs fine now.
also check out http://www.3wheelerworld.com/showthr...0-Service-Data
Check out our new HOMEPAGE
davidg is offline   Reply With Quote Quick reply to this message
Old 02-19-2012, 05:11 PM   post #4 of 10
BillTheTractorMan
Tractor addict
MTF Member # 30045
Images: 6
I'll try those screws.
The throttle bobbing in the beginning is me trying to keep it going as it's rather cold blooded. Here's the video though.
http://www.youtube.com/watch?v=6Y4Nm8q-1zo
Old 02-19-2012, 05:38 PM   post #5 of 10
Robert Webb
Robert Webb's Avatar
MTF Member # 53133
Images: 4
First thing you need to do is get it up to temperature before you try to adjust the carb..........
John Deere 430
John Deere 425 with 54" Deck and Power Flow and MC 519 Cart
John Deere 400 with 60" Deck and Power Flow
John Deere 112 H with 38" deck
John Deere 30 Hydraulic Tiller w/ 12" extension and 3 Pt setup
John Deere 21 Cart
John Deere 80 Cart (refurbished to be used)
John Deere 22 Cart (Greens mower trailer)
54" 4 way plow
Brinly 10" Sleeve hitch plow
Brinly 12" 3pt Plow X2
Brinly 4 gang Disc
Brinly Cultivator
5 JD 400 parts machines (2 are destined to be rebuilt)
Craftsman Lawn Cart (orphaned)
Its amazing how fast the collection grows when you aren't even trying....
Robert Webb is offline   Reply With Quote Quick reply to this message
Old 02-19-2012, 06:06 PM   post #6 of 10
davidg
The Travelin' Mod
davidg's Avatar
MTF Member # 807
Images: 2
yeah, either let it idle for 10-15 minutes or drive it around for a good 10 minutes. the manual i linked above actually says to perform stop and go riding for 10 minutes before doing ANY adjustments on the carb.
Old 02-19-2012, 06:28 PM   post #7 of 10
Brad
MTF--A Step Above!
Brad's Avatar
MTF Member # 4571
Images: 28
I would say a dose of SeaFoam would not hurt anything. Might clean up a few years worth of varnish and sediment.
MTF--Getting better, one new member after another!
It's a great place to spend some time every day!
Brad
Brad is online now   Reply With Quote Quick reply to this message
Old 02-19-2012, 07:52 PM   post #8 of 10
BillTheTractorMan
Tractor addict
MTF Member # 30045
Images: 6
Tomorrow I will try to adjust it some more. So far all I've achieved is got it running long enough to warm up, and a little better idle. It runs ok at higher throttle positions. I can zip around the backyard and get going pretty darn fast. Well... At least my mum thought it was fast and yelled at me to slow down or go buy a helmet. It still wants choke. I'm thinking it has to do with the other screw on the underside of the carb. I can't find any of my small screw drivers.
Before I do any driving with it I'm going to need to adjust the brakes. Right now I only have front brakes, and those barely hold it from rolling.
Old 02-20-2012, 07:07 PM   post #9 of 10
BillTheTractorMan
Tractor addict
MTF Member # 30045
Images: 6
Ok... Here's where I'm at.
This morning: wouldn't run with anything less than half choke and had to be warmed up to run on anything less than full choke. I cleaned it again, moved the carb settings to specs, and tried to start it. Got nothing more than a pop here and there pulling it over. So I take it all back apart, cleaned it again and went through every passage in it. I unscrewed the underside screw a half turn and it started. How ever it wouldn't run to save it's self from the scrap yard. I let it sit.
Came back to it, took it all apart and cleaned it again and tried spec settings It ran ok, with full choke. I let it warm up and slowly lowered it from full choke to half choke before it died. So I got it started again and let it run for 10 minutes while I checked the radar to see where our snow is. came outside, and was surprised it wasn't stolen. It was still running. Started playing with it and tried some different things, still runs rough. Now it will idle with only a hair of choke. I played with it a little more and now it idles well enough that a screw driver wont fall of the seat with in a second.
I'm going to order a new one of those parts that go up and down inside the carb, it's a little chewed up where the adjusting screw touches it. I'm also going to look for a new muffler. I all game for a tractor muffler, but not on the three wheeler.
Old 03-02-2012, 08:47 PM   post #10 of 10
Grand Sierra
Grand Sierra's Avatar
MTF Member # 26788
I learned on atv,dirt bike, there's also an throttle adjustment on handle bar and somtimes above carb. Adjusted cable on carb off intake barrel should be all the way down inside carb, at full throttle the barrel that needle is in should be all the way up not 5/8, 3/4 or 7/8 for top performance you should see just a needle no barrel. At that point its dialed 100 percent full throttle.
Grand Sierra is online now   Reply With Quote Quick reply to this message
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
