This is a repost of something I submitted a while ago, but which keeps coming up, and for whatever reason, the search engine finds hard to find.
So, I have a JD 2210 tractor. A friend of mine who builds race cars made this cab. It is entirely made of aluminum and held together by 1/4 turn Dzus fasteners. It comes on and off so easy, I'll bet some of you can't remove your MMM as quick.
needs one of those yellow blinking lites on top and make it look official. Job well sone looks great. now you need a small AC unit for the summer months and maybe a TV so you can watch the ball games
Great work! Hands down, the best homemade cab I've seen. Great craftsmanship, simple, clean lines, functional and stylish.
:congrats:
I posted a thread in the snow removal section to see if any of the Sears SS guys had built a cab since I've been throwing around the idea of maybe building a cab for one of mine. I'm good with wood, but unfortunately I don't have a lot of experience with metal fab..
Yes, it is a bus style that remains square to the window frame. The fulcrum rod is the key. I have the cab put away for the summer, but when I get it out again can get some close up pics.
That would be very cool. I wasn't horrible in geometry, so I should be able to figure it out.
Looks like the fulcrum rod has to be the same length as the wiper arm is and the piece of metal connecting the wiper to the fulcrum needs to be the same distance apart as the distance of the wiper motor and fulcrum mount?
If you look at post # 4 and the pic titled "tower covers footpad" you will see the sheetmetal of the tower (upright) goes between the black cowl brace and the hood and side cover. A single bolt goes through the plastic footwell pan and holds it in place. The rest of the cab rigidity comes from all the dzus fasteners with only the two footwell bolts and six fasteners on the ROPS.
Looks a lot like the OEM cab we have on a 430 at work. The cabs nice until you hit a square edge in the concrete with the plow and it sends you head first into the windshield. I usually hit the support member in the roof first though. I've had to stop and gather my thoughts along with a little forehead flesh off that support a time or two.
Great awesome cab. I've read this post several times and always have the same question. Are the disconnects on the heater hose standard garden hose disconnects or are they special?
If they're standard garden hose disconnects, how have they held up over the years? My garden hose disconnects usually leak in a couple of years.
If they're special for coolant lines, what are they?
Really nice job on the cab. Wish I had the equipment to fab one like that. I went a little cheaper route and made mine out of birch plywood. Only five sides to remove too. My frames are made of 2" engineered plywood beams cut to shape.
Wow awesome cab! I have a 2305 and want to build a cab for it this summer, im sick of blowing snow in my face.
Quick question. Do you remember what size fittings you used for the heater lines? I keep searching forums and the internet but cant get a size!
Related Threads
My Tractor Forum
4.3M posts
216.7K members
Since 2005
