Stilh 038 chainsaw carb adjustment - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Old 11-26-2009, 08:01 PM   post #1 of 7
Bearcamp
MTF Member # 22959
Default Stilh 038 chainsaw carb adjustment
What should the hi and lo speed adjusting screws be adjusted at on an 038 Stihl saw?
Bearcamp is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 02:11 PM   post #2 of 7
Ironmower
Ironmower's Avatar
MTF Member # 25539
Default Re: Stilh 038 chainsaw carb adjustment
Should be close to 1 full turn out. This is only "ball park". Is the saw running now? Every saw "tunes" alittle different.
Ironmower is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 03:53 PM   post #3 of 7
Bearcamp
MTF Member # 22959
It's running now but the screws are about 2-3 turns out. Won't idle and hesitates. I tried them ay 1 1/2 turn on both and no good.
Old 11-28-2009, 06:29 AM   post #4 of 7
Ironmower
Ironmower's Avatar
MTF Member # 25539
Sounds like it may have a vacuum leak. Can you explain more about it; like is the saw new to you? did it run before? Ect.
Old 11-28-2009, 07:49 AM   post #5 of 7
DSL DOC
MTF Junior Poster
DSL DOC's Avatar
MTF Member # 35413
Free Re: Stilh 038 chainsaw carb adjustment
as a factory trained stihl tech as we have the tools as most individuals dont we would test for like he said vacumn leaks first most of the time we are seeing the crank seals wont hold psi and will hold vacumn and vice vers or the boot to the cyl or the plastic plate between carb and cyl is cracked now as an individual in my driveway i would pull the carb and get a kit from a stihl dealer or most any farm supply place that services small engines it should have a zama or walbro most likely a walbro ull need your numbers off it one more trick people dont do because of no tools is u need to remove the sealed little buttons and clean those passages and reinstall a small chisel gently should remove and a small punch hit once or hit to seat new ones any more than that and you will distort the button and no seal then we use nail polish on the outside of the buttons
just a note they were 026 038 etc now the are 260 361 etc i will always look for a 0 series and built like an OLD GRAVELY WITH CAHONEYS
the 0 series saws have bigger needle bearings and roller bearings on the wrist pins and cranks as well as metal bar retainers etc as apposed to the newer stihl stuff going smaller and lighter esp the plastics my fav stihl of all times is my 026 pro i rebuilt the whole thing at work and run a full chisel chain it is an eating mother i would start out at 1 1 1/4 each turn and go from there after a rebuild if you are 2-3 turns out now 90 percent chance youre getting in the carb trust me we prob rebuild hundreds a year if you have a rpm gauge you can get 13000-15000 out of my 026 pro but if you go to lean will lose your power under load so no load rpm is not what you want to achieve its loaded rpm with out hitting the governor causing a miss and back your screws out till it starts to miss then turn back in till smooths out go from there also remmber clean you exhaust screen and you can look at cyl and piston when pull exhaust off
hope i could help
like i said before gents if anyone needs help with something im not all that but very capable ive been wrenching pro for 15-20 years stihl kohler briggs toyota and even spent 5 yrs runnin the racks on detroits
hence the name
DSL DOC
DSL DOC is offline   Reply With Quote Quick reply to this message
Old 12-09-2009, 03:27 PM   post #6 of 7
Bearcamp
MTF Member # 22959
Wow, now that's some info. Just found out that I have a weak spark. This is the electronic ign, no points. I can grap the plug wire, pull the cord and barely feel it.
Old 12-09-2009, 06:41 PM   post #7 of 7
rscurtis
5000 Strong & Climbing
MTF Member # 25367
To verify that, reduce the plug gap to about .010 and see if the saw runs any better. If it does, that may be the problem.
rscurtis is offline   Reply With Quote Quick reply to this message
