Home MTF Gallery Add To Favorites! Set MTF As Your Homepage FAQ
Go Back   MyTractorForum.com - The Friendliest Tractor Forum & Discussion Board and Best Place for Tractor Information on the web!!! > Many thanks to the MTF Advertisers > Our other Advertisers
Register Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 06-20-2006, 09:33 PM   #1
parts man
parts man's Avatar
MTF Member # 9
Send a message via MSN to parts man
Default Farmall MD (diesel)
Got this MD in this morning.
It's in really nice shape, but the engine is toast. It was getting anti-freeze into the cylinder and it gouged the head between valves in 2 cylinders. It also wasn't burning all it's fuel and dumped it right into the crankcase, ruining the bearings, and most likely scoring the crank so it will need turned.
VP of TSA (takin stuff apart)
Need parts? Check out
parts man is offline   Reply With Quote
Old 06-21-2006, 12:24 AM   #2
farmallmaniac
farmallmaniac's Avatar
MTF Member # 246
Default Re: Farmall MD (diesel)
NICE!! thats a sweet tractor! Can the motor be saved? Do you plan on reselling it?
Ryan
Built Ford TOUGH
1996 Blue Ford Explorer runs alright, looks like crap but I love it!
Joe Diffie - Tougher than nails
farmallmaniac is offline   Reply With Quote
Old 06-21-2006, 01:42 AM   #3
bear
bear's Avatar
MTF Member # 72
Send a message via AIM to bear Send a message via MSN to bear
tractor looks great may be worth doing a patch on the engine and adding to your collection
bear is online now   Reply With Quote
Old 06-21-2006, 06:21 AM   #4
Ingersoll444
Ingersoll444's Avatar
MTF Member # 16
Send a message via AIM to Ingersoll444 Send a message via MSN to Ingersoll444
Nice tractor. Looks clean!!!
Paul B
only TRUE MTF wackos are out taking pictures of the underside of mower decks at 5:30 on a Sunday AM.
"When the going gets tough, what do the tough do? We all know what they are supposed to do. We have all heard the old saying. But we do not entirely believe it. We think the truly tough are too smart to exhaust themselves by responding to a tiresome challenge."
Ingersoll444 is offline   Reply With Quote
Old 06-21-2006, 10:24 PM   #5
parts man
parts man's Avatar
MTF Member # 9
I would love to rebuild the engine, but the head would need some extensive welding, and good used heads for MDs are non-existant. The crank should be salvageable, but would need reground. Basically, we're talking more $$ than my financial department is willing to consider on this particular tractor. The good news is there are a lot of goodies that will go right over on our M gas.
Old 06-22-2006, 01:32 AM   #6
bear
bear's Avatar
MTF Member # 72
find a safe spot to park it i'm going to look at 2 wd6's in july one burnt and the other they say was running good when they parked it
Old 06-22-2006, 09:17 PM   #7
parts man
parts man's Avatar
MTF Member # 9
Bear, the CEO already has someone interested in the complete engine!
Old 06-23-2006, 02:50 AM   #8
bear
bear's Avatar
MTF Member # 72
can't argue with the ceo
Old 06-24-2006, 08:04 PM   #9
parts man
parts man's Avatar
MTF Member # 9
That's for sure Bear, he's the one who signs my checks!!
Old 06-25-2006, 10:20 PM   #10
parts man
parts man's Avatar
MTF Member # 9
Bera, just so you know, the engine is still availlable, or any piece there-of.
Old 11-01-2009, 10:17 AM   #11
Jon Glastra
MTF Junior Poster
MTF Member # 33191
This one looks nicer than my '51 MD looked when it first came home in May of 2007. I have a neighbor who's a very talented heavy-equipment mechanic, and I told him to use it for fill-in work last year when the economy tanked.
In Sept. of '08 he got it running, but showed really ratty combustion & awful bad noises both in stack & the air intake. Off came the head, & we found very similar issues to what you describe; pitted head, obvious coolant leak between #1 & #2 cylinders, trashed pistons & liners on #1 & #2.
So began the search for parts. Steel Wheel Ranch came up with a head, pre-combustion chambers, 2 intake valves, 2 - exhaust valves, & a full set of crank bearings. Crank was actually OK, IH built these with a massive all-forged-steel lower end.
3-7/8" bore pistons & liners are no longer available, so I had to get a full set of pistons & liners from BAtes Corp in Indiana. There is an alternate supplier for these, Restoration Parts, or some variant thereof.
Injection pump was total rebuild also, this was done by Central Fuel Injection in IA.
The end result after much massage, patience, & $$s as delivered by my neighbor is a real cutie. ( I'll post picture when I get smart enough to figure out how to do that. . .)Mine is also a factory wide-front, which is very desirable according to local IH collector gurus.
Bottom line: expect to spend about $5-6K on the engine to do it right. I think it well worth it, these engines run superbly when taken care of. I have an un-restored SWD-6 ('53) with the same engine, & it runs smooth as glass. Can't say that for the MD rebuild. It is very smooth also, but I probably should have had the rotating assembly balanced with the new, larger pistons. I recommend you do that if you opt to rebuild the engine.
I don't think I'd waste time on trying to 'patch' this engine. The result will not be satisfactory.
Good luck, go for it, & let us know how it turns out!
Jon Glastra is offline   Reply With Quote
Old 11-05-2009, 11:36 AM   #12
danbike
Bikes/Tractors what else
danbike's Avatar
MTF Member # 1530
In another life, I started a job at IHC Tractor Works in Chicago. They had a forge shop there that did parts for many of the other plants. I can remember seeing crankshafts and camshafts being forged. One impressive operation.
2005 JD X585
2006 Triumph T100
1967 Triumph TR6R-all original
19XX VESPA PX200EFL
1964 Vespa GL(oldest original owner Vespa in the US)
danbike is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
vB code is On
Powered by vBulletin® Version 3.6.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
