Carburetor cleaning - what REALLY gets the varnish removed?? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board
Old 06-18-2009, 08:02 PM   post #1 of 14
SammyRye
MTD 990 Twactor Guy
SammyRye's Avatar
MTF Member # 25153
Images: 15
Default Carburetor cleaning - what REALLY gets the varnish removed??
Tore apart my carburetor off my MTD 990 B&S 16 hp single cylinder engine to clean and replace float, nozzle, needle valve, etc. Everything looked really nice and clean, until I removed the upper and lower carb bodies to get at the float. Yuck! White varnish cyrstals everywhere! Have you ever had this problem, and what cleaned it the best? I've tried the usual spray carb cleaners, tried acetone, and now I'm going to try some Seafoam.
Tell me your fixes and failures!
1973 MTD 990 (Silver) 16 hp B&S Single
1982 MTD 990A (Red) 16 hp B&S Single
2003 Craftsman LT2000 22 hp B&S Twin
Reduce - make do with what you have,
Reuse - give it new life by being creative,
Recycle - if you can't use it, maybe someone else can!
http://www.wunderground.com/US/WI/La...typeclick=big2
SammyRye is offline   Reply With Quote Quick reply to this message
Old 06-18-2009, 08:14 PM   post #2 of 14
bstrucker
bstrucker's Avatar
MTF Member # 18659
Default Re: Carburetor cleaning - what REALLY gets the varnish removed??
I usually spray that with WD40 first,leave it sit for 15 minutes or so then spray it with Gumout carb cleaner,followed by air.
bstrucker is online now   Reply With Quote Quick reply to this message
Old 06-18-2009, 08:21 PM   post #3 of 14
engine2quarters
5000 Strong & Climbing
MTF Member # 24003
Gumout or NAPA carb cleaner works for me. On real stubborn stuff, let it soak a few minutes. If really stubborn, spray, then scrape gently off with a really dull razor blade, then re-spray and wipe clean.
engine2quarters is offline   Reply With Quote Quick reply to this message
Old 06-18-2009, 09:54 PM   post #4 of 14
poncho62
National Mower Guy
poncho62's Avatar
MTF Member # 19374
Images: 7
Varsol....a lot cheaper than that other stuff...and it works.
That National Mower guy
National Reel Mower
Ford LGT100
Ford LGT125
M-F 10
John Deere STX38
Ontario Rodders
poncho62 is offline   Reply With Quote Quick reply to this message
Old 06-19-2009, 12:59 AM   post #5 of 14
KHodges
AKA Moses Lawnagan
KHodges's Avatar
MTF Member # 23296
Images: 6
And flammable as all heck. Don't even think about fire while you use it. A great industrial solvent, we used it to clean sheet steel and pipe in the welding shop I worked in as a teen. Cuts grease and varnishes better than most anything.
A spark from a guy welding landed in a small puddle of the stuff next to a 55 gallon drum of it, it was amazing how fast it went up. Long time ago, back before you had to keep those things in separate location from the work area to meet fire codes.
Proud owner of :
'08 JD X748SE, 54C deck
3-pt hitch, rear PTO
Power Flow and MC519 cart
LP RTR0550 rototiller
?? 60" box blade
Simplicity 10" plow adapted to 3-pt hitch
45 FEL
'02 JD GT235, 48C deck
'86 JD 214, 46" deck
I've always had a problem with kleptomania.
When it gets really bad, I take something for it.
KHodges is offline   Reply With Quote Quick reply to this message
Old 06-19-2009, 01:04 AM   post #6 of 14
pylek
pylek's Avatar
MTF Member # 13005
Images: 26
Make sure those white crystals of varnish aren't the aluminum body of the carb starting to corrode. When aluminum corrodes, it forms a white oxide, no saving it at that point.
I have had to learn that lesson the hard way.
Seth K. Pyle
Nothing is sailor-proof...
2002 Craftsman LTX1000 with 21.5hp Intek Twin
1994 Craftsman LT1000 with 15hp OHV single
1979 John Deere 317 C317H soon to have an M18
1986 Craftsman II GT18 917.255912
1987 Craftsman II GT18 917.255913
1988 Roper GTK181AR with a Kohler M18 Magnum
1993 Craftsman GT6000 with a Kohler M18 Magnum
2002 Craftsman DGT6000 with a blown Kohler 27hp Command Twin
1993 Hechinger (MTD) 16/42 with 16hp Vanguard Twin
pylek is offline   Reply With Quote Quick reply to this message
Old 06-19-2009, 12:31 PM   post #7 of 14
Wizard99
Wizard99's Avatar
MTF Member # 13982
Images: 12
xylene is what we use.
remember kids, just say no to scrappin tractors
Wizard99 is offline   Reply With Quote Quick reply to this message
Old 06-19-2009, 12:37 PM   post #8 of 14
Tractor-Holic
10,000 +posts!
Tractor-Holic's Avatar
MTF Member # 8867
I have saved some really corroded zinc carbs that were all white inside on old cars no replacememt was available for readily,by using two things..
One is battery electrolyte..you can buy it at better auto parts stotres..
You fill a plastic bucket with it,deep enough to submerge the carb completely,after removing any brass parts like the float,needle valves,jets,etc..I tie a nylon zip tie to it for a "handle" so I can remove it easier,then leave it submerged for about 15 minutes,it will fizz like soda when you put it in the acid..after 15 minutes remove it,and rinse it off in a bucket of water with baking soda dissolved in it to neutralize the battery acid..flush it good with lots of water afterwards..it should be sparkling clean now,though some pitting may remain..
Another method I tried I read about in Hot Rod Magazine worked well to--you use a plastic bucket of water with Sani-Flush or Vanish toilet bowl cleaner,believe it or not!..same way as the battery acid,only you jusyt need water to rinse it off later..they warned not to leave it submerged TOO kong,or your carb COULD indeed "vanish"!..
For varnish ,Acetone or Laquer Thinner is hard to beat, but is pretty expensive and can be hazardous due to its voltility..Denatured Alcohol eats away pretty much anything if you soak it in it long enough..
I like Chevron "Techron" for adding to gas tanks ,I haven't tried Seafoam yet,I have heard both good and not so good results from others who have used it..(nothing "bad",some just felt it did nothing,no good or harm,and considered it a waste of money)..
Tractor-Holic is offline   Reply With Quote Quick reply to this message
Old 06-19-2009, 01:10 PM   post #9 of 14
diesel_nut
diesel_nut's Avatar
MTF Member # 23678
MAny motorcycle shops have a 'dip bucket' for carbs. Might try locating a dealer with one.......if all else fails.
The stuff in it smells like creosote(sp?)
Cub 1872....sold
Cub GT2554: '07(sold) and '08
..."yyup"
diesel_nut is offline   Reply With Quote Quick reply to this message
Old 06-19-2009, 01:41 PM   post #10 of 14
rustyoldjunk
rustygold hunter
rustyoldjunk's Avatar
MTF Member # 7844
Images: 24
when im in a hurry to use the carb so there is not time to soak it i tear the carb completely apart at the work bench using lots of gumout carb cleaner and a bread wire tie to clean each small orifice,the ones that are too small for a bread wire tie to go thru,i take a strand from a piece of small gauge electric wire and very carefully use it.
"IT WASN'T BROKE UNTIL I FIXED IT"
rustyoldjunk is online now   Reply With Quote Quick reply to this message
Old 06-19-2009, 04:17 PM   post #11 of 14
Tractor-Holic
10,000 +posts!
MTF Member # 8867
I do much the same too--I pluck a bristle out of a wire brush ,and use copper wire too,which is unlikely to hog out the holes in the jets..sometimes I use torch tip cleaners if I have them handy too,but those can enlarge holes easy if your careless or use one too big!..stiffer wire is a lot easier to use than soft stuff like a bread tie..(but pokes your fingers easier too!)..
I find blowing carbs out with air is OK,the higher the pressure the beter--but on Tecumseh carbs I've blown that seat for the needlve valve into iblivion a few times,its best to apply air from the needle valve side only on those!...
Old 06-19-2009, 08:18 PM   post #12 of 14
saleen49
Super Duper Member
saleen49's Avatar
MTF Member # 21045
Images: 2
I do the same exact thing when cleaning out old carbs. I could not clean the original carb off of my 318 to save my life. I tried wires, tip cleaners, had a local shop soak it for days. The tractor kept on surging, no matter how many times I cleaned it, and blew air through it. Also, the carb on a 318 has a little freeze plug looking cap that will blow out if you use to much air pressure on it.
1983 318.
2009 X729 with 54" deck & 54" blade, oh and 45 loader
__________________________________________________ __
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
saleen49 is offline   Reply With Quote Quick reply to this message
Old 06-19-2009, 09:43 PM   post #13 of 14
S DIAMOND
S DIAMOND's Avatar
MTF Member # 18630
Hands down, an ultrasonic cleaner is the best “tool” on the market for cleaning carburetors safely, and without damage to the carburetor.
I have saved several carburetors, both two and four cycle, from the scrap pile with my unit. A good quality unit along with the right combination of temperature and cleaning solution is the key.
Oh, and most important step most people ignore. COMPLETE DISASSEMBLY OF THE CARBURETOR!
No ridiculous soaks and or loud chemical odor, well almost.
Down side is the initial cost, however, mine has paid for itself.
Yes, the white death, once the manufactures coating has been breached, it really doesn’t matter what you do, it will simply progress. If in fact that is what it is. Good luck.
S DIAMOND is offline   Reply With Quote Quick reply to this message
Old 06-20-2009, 12:48 AM   post #14 of 14
KHodges
AKA Moses Lawnagan
KHodges's Avatar
MTF Member # 23296
Images: 6
Something we radio control airplane guys use to clean our glow engines, is an old Crock-Pot that has the ceramic removable tub. Fill it with antifreeze that is compatible with aluminum, disassemble the carb and put it in the crockpot on low overnight.
You can drop an entire glow engine into this solution, and it will come out looking brand new. The ethylene glycol dissolves the varnish deposits that the burnt methanol, nitromethane and castor oil fuel leaves on the engine, and doesn't harm the metal at all. Most glow engines are aluminum castings with either brass plain bearings or steel ball bearings, it doesn't hurt any of the metals.
Proud owner of :
?? 60" box blade
45 FEL
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
