425 rear weight bracket - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
John Deere Forum John Deere Garden Tractor talk
Old 06-17-2009, 08:01 AM   #1
GregM
MTF Member # 25642
Default 425 rear weight bracket
Hello all, Does anyone know if a rear weight bracket from a 425 will fit a x720.
I think it will, just wanted to make sure.
Thanks,
GregM
2007 JD x720
1973 Cub 109
GregM is offline   Reply With Quote
Old 06-17-2009, 08:21 AM   #2
x595
JD RULES
x595's Avatar
MTF Member # 23848
Images: 3
Default Re: 425 rear weight bracket
ThanksGregM
Hi Greg ,
I believe it will ... I used to own a JD 445 that had the rear weight bracket ,
when I got rid of it , I kept the rear weight bracket and put it on my X595 ...
Later,x595
2005 JD X595 w/ HDAP Tires
54c MMM --- (SOLD)
62c MMM
54" Quick Hitch Front Blade
4x8 Utility Trailer - 1500# Axle
North Star 15,000 Watt Generator
Troy - Bilt Super Bronco Rear Tine Tiller
Troy - Bilt 2500 PSI Pressure Washer
22" Yard Machine Push Mower
SpeeCo SplitMaster 28 Ton - Horizontal/Vertical Log Splitter
STIHL 025 - 18" Bar
STIHL 025 - (Spare Parts Saw)
STIHL MS 290 FARM BOSS - 20" Bar
STIHL FS 45 Trimmer
x595 is offline   Reply With Quote
Old 06-17-2009, 08:21 AM   #3
Sergeant
Tech Exchange Moderator
Sergeant's Avatar
MTF Member # 24
IT may fit but. But if you have a 3point for it You will have to remove The Mounting brackets for the 3point Arms But with the click and Go and the weight Bracket that is designed for the X700 series tractors You will use the 3point arm Bracket for the Click& GO weight bracket which is removable with out Tools which you would have to unbolt the one that is designed for the 425. Cost for the Click & Go weight Braket:
Weight Bracket:BM20779 $125.00
Click & GO Brackets BM20714 $100.00
So if you plan on adding of have a 3point it not worth it to use the 425 weight Bracket.
John Deere Models:X485,140H3,112,Sabre 1542
Cub Cadet Models:0riginal,70,106,2206 & Experimental Non Production Rear engine rider
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy,7016
White Model: GT2055
"The only thing necessary for the triumph of evil is for good men to do nothing." Edmund Burke
Sergeant is offline   Reply With Quote
Old 06-17-2009, 01:20 PM   #4
GregM
MTF Member # 25642
Thanks guys,
[QUOTEIT may fit but. But if you have a 3point for it You will have to remove The Mounting brackets for the 3point Arms But with the click and Go and the weight Bracket that is designed for the X700 series tractors You will use the 3point arm Bracket for the Click& GO weight bracket which is removable with out Tools which you would have to unbolt the one that is designed for the 425.[/QUOTE]
Good point Sergeant. Do you need a 3point for the Click&Go? I have no plans or need for a 3point. Right now I'm looking for an used snowblower/thrower package. If by fall I haven't found something I want, I'll buy new. If you don't need a 3point for the Click&Go that's what I'll get.
Thanks Again
GregM
2007 JD x720
1973 Cub 109
Old 06-17-2009, 03:52 PM   #5
Sergeant
Sergeant's Avatar
MTF Member # 24
No You can just get the ClicK& Go brakets by themselfs. Which you would need anyways if you decide to get a power flow 2 or 3 bag Bagger system and they even make a Click&GO Ballest Box. The Click & Go system is a rather handly attachment from Deere over the old weight bracket Design. The click & Go Brackets can stay on the tractor they take about 5minutes to install.
White Model: GT2055
