Want to get grandpa's old Massey runnin again. - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Old 04-16-2012, 10:35 AM   #16
NOVAZ27
NOVAZ27's Avatar
MTF Member # 53850
Thumbs up Re: Want to get grandpa's old Massey runnin again.
A White vinegar solution works great at removing rust without being to aggressive like Muratic acid would be. There quite a few articles on the Web concerning the many uses of Vinegar. Check em' out. White vinegar is relatively cheap to buy $2.50- $3.00 a gallon at Wally World or your local grocery store. I know it cleans up coffee pots realy good. Gets the lime build up and coffee stains gone. Good for cleaning the lime out of the wife's steam iron.
HOPE THIS HELPS
NOVAZ27 is offline   Reply With Quote
Old 04-16-2012, 10:52 AM   #17
SandDawg
SandDawg's Avatar
MTF Member # 65719
Default Re: Want to get grandpa's old Massey runnin again.
Originally Posted by Doubletrouble View Post
Never heard of that but I'll give it a try.
I pulled the carb off yesterday. It will for sure need rebuilt. Being that it's a cast iron body what would be the best thing to soak it in to clean it and remove the rust? I used muratic acid on a motorcycle tank once that worked well. Would it be ok to used for this once I have it completely disassembled?
It says it's a model TR on the side, where is a reasonable place to get a rebuild kit for it?
Did a quick search, is it a TRX-36 Marvel Schebler Carburetor? May need to clean around the "TR" and see if anything else is stamped or cast into the carb housing.
May want to call Steiner's tractor parts and see if they have a Carb. kit.
Steiner Tractor Parts
1660 S. M-13
Lennon, MI 48449
Phone Number
810.621.3000
800.234.3280
Here's an instruction manual on Marvel-Scheblar, it's not on the TRX model but should give you a good idea on how to proceed.
http://l-36.com/carb.pdf
Found another link for the TRX-37 & 38 model carbs:
http://www.oldcarmanualproject.com/m...er/MS-Buda.pdf
**No tractors were harmed in the creation and delivery of this MTF post; a lot of electrons, however, were severely inconvenienced!**
1950 Ferguson / Ford (FERGUSORD)
Model- TO-20 / Ford 9N Rear End
Ser.#TO-27005
1972 Suburban 15
Model#917.25200
Ser.#?
Encore Z-Turn 60 Inch Deck
2012 TYM T-233 with FEL
SandDawg is online now   Reply With Quote
Old 04-16-2012, 12:03 PM   #18
Doubletrouble
Doubletrouble's Avatar
MTF Member # 25241
Thanks again SandDawg, very helpful. I see your in afghanistan? WoW. Thanks for all your doing over there. My son is in the Navy and he'll be headed that way in about 6 weeks. Be safe over there!
If it ain't broke you can still try to make it better!
Doubletrouble is offline   Reply With Quote
Old 04-16-2012, 12:21 PM   #19
SandDawg
SandDawg's Avatar
MTF Member # 65719
Welcome! Keeps me sane until I can get back home and gives me something to do looking up tractor info. Plus I learn alot while doing it! Thank your son for me for his service! I'm just here supporting our route clearance troops by servicing their equipment.
Almost forgot!
Carb Cleaning MTF search results:
http://www.mytractorforum.com/gtsear...%3Fp%3D2118764
I like this one, may try it next time I need to and see how it does on a junk carb first!
KHodges
AKA Moses Lawnagan
Something we radio control airplane guys use to clean our glow engines, is an old Crock-Pot that has the ceramic removable tub. Fill it with antifreeze that is compatible with aluminum, disassemble the carb and put it in the crockpot on low overnight.
You can drop an entire glow engine into this solution, and it will come out looking brand new. The ethylene glycol dissolves the varnish deposits that the burnt methanol, nitromethane and castor oil fuel leaves on the engine, and doesn't harm the metal at all. Most glow engines are aluminum castings with either brass plain bearings or steel ball bearings, it doesn't hurt any of the metals.
Have fun with your project!
SD
Ser.#TO-27005
1972 Suburban 15
Model#917.25200
Ser.#?
Old 04-16-2012, 06:35 PM   #20
Doubletrouble
MTF Member # 25241
Regaurdless of what you do over there you in a place where alot of us wouldn't want to be. Everyone's job there is important.
I think it's cool with technology that I'm talking tractors with someone on the other side of the planet!
Old 04-16-2012, 10:58 PM   #21
SandDawg
SandDawg's Avatar
MTF Member # 65719
Thanks!
Yup...technology is very COOL! I've met a bunch of great people and I can research tractors and my other interests from right here in my hooch!
Ser.#TO-27005
1972 Suburban 15
Model#917.25200
Ser.#?
Old 04-17-2012, 09:16 AM   #22
Doubletrouble
MTF Member # 25241
That's awesome man. I will definitely get some pic up once I get them out of the barn and cleaned up a bit. Gotta entertain our troops! lol
Old 04-17-2012, 09:26 AM   #23
LilysDad
Just Have a Little Faith!
MTF Member # 7161
If you know a good sheet metal shop, it might be easier to have new side shields made.
LilysDad is offline   Reply With Quote
Old 04-19-2012, 10:14 AM   #24
massey 444
MTF Junior Poster
MTF Member # 70530
My boss has sent two of his to this shop in NY and they completely redo it, paint it gray and get it set where it needs to be. Tractors run great right out of the shipping box. I can try to find the name if you want. Here is a place that I read about in the IH Red Power magazine that looks pretty legit http://www.dennyscarbshop.com/ Let me know how you make out.
massey 444 is offline   Reply With Quote
Old 04-21-2012, 06:10 PM   #25
Doubletrouble
MTF Member # 25241
I should be fine rebuilding it I just have to figure out for sure what carb I have here to get the correct kit for it.
Old 04-22-2012, 12:56 PM   #26
Doubletrouble
MTF Member # 25241
I cleaned the carb a little so I could determine what model I have. it's a trx-22. Steiner tractor carries the economy kit for these so that will help with getting her working again.
Old 04-23-2012, 11:09 AM   #27
Alleyyooper
Keeper of the bees
Alleyyooper's Avatar
MTF Member # 310
Images: 1
Talking Re: Want to get grandpa's old Massey runnin again.
The picture is a 101R, the 101 super came latter when they increased the engine size. There used to be a company that made replacement side panals for a bunch of different tractors like the massey 101's, oliver fleet line models.
My 101R has a zenith carb on it.
soak it in paint thinner then rince in hot soapy water then plain hotwater and blow the jets and channels dry.
Al
Garden View Apiaries, Where the view is as sweet as the honey.
Alleyyooper is online now   Reply With Quote
Old 04-23-2012, 07:38 PM   #28
Doubletrouble
MTF Member # 25241
If I soak it in paint thinner should I remove the needle? There are a few brass "plugs" that thread into the body, should I remove those also and will there be any tiny parts falling out if I do?
As far as it being a 101R, I looked at the serial# site that someone else linked up in this thread. From what I could tell it's a super but I'm just going off what I read. I just need her working since I just got a call from a friend that has a 6ft PTO driven field mower I can get for free to mow the pasture down.
