Off-season topic. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Old 04-11-2012, 03:41 PM   #1
WMass712
WMass712's Avatar
MTF Member # 71242
Default Off-season topic.
So, now that I'm well on the way to resurecting my Suburban 12 I have a question. Would a newer 2-stage sears snowthrower attachment mount onto it and be able to be powered via the mule drive on the front? The snowthrower ia model # 842 240729 serial # 457451. Suburban is model 917.99420. I know we're comin up on summer, but the way life is it'll be January and the middle of a blizzard before I know it and I'm tired of clearing a 1/4 mile driveway with a walk-behind.
WMass712 is offline   Reply With Quote
Old 04-11-2012, 03:44 PM   #2
lobsterbox
lobsterbox's Avatar
MTF Member # 32341
Images: 4
Send a message via Skype™ to lobsterbox
Default Re: Off-season topic.
I'm going to go out on a limb and say likely not, because the newer sears snow blowers mount to the underside of the frame on the 80's Craftsman II GT's. I do know that Haban made an aftermarket snowblower that was compatible with the Sears Suburbans.
Please take a moment and visit my youtube channel.
Garden Tractors:
1975 Roper RT/16
1978 Sears GT/19.9 Twin
1974 Sears SS/16 Twin
1976 Sears SS/16 V-Twin
1975 John Deere 300
Suburban Attachments: 42" & (3) 48" Mowing Decks, (3) 39" Single Stage Snowthrowers, Electric 3 point hitch, Manual 3 Point Hitch, (2) 38" Rototillers, 10" Moldboard Plow, Sears Cultivator, Sears Dump Cart, Sears Tote Box.
lobsterbox is offline   Reply With Quote
Old 04-11-2012, 06:05 PM   #3
Small Fry
5000 Strong & Climbing
Small Fry's Avatar
MTF Member # 8155
I had a newer Craftsman blower on a Suburban, I don't have the model number but it was gray and from the 80's. The blower had a long frame that went under the tractor and mounted to the deck hangers. The pulley was on that frame and was about were your mower pulley would be. I did run it off the mule drive just like a mowing deck.
I still have it in the barn but it's barried. The one I have lined right up, no mods were needed. I put a peice off round stock threw the rear deck hangers. The ears on the blower frame slipped on to that rod, then the frame mounted to the front deck hangers.
It was hard on the belt, but the blower pulleys were pitted from rust when I got it. Im not sure if it was the pitting or the angle of the belt. I gave up because 12 hp was not really enough power for the size of the blower.
Small Fry is offline   Reply With Quote
Old 04-11-2012, 06:30 PM   #4
WMass712
WMass712's Avatar
MTF Member # 71242
Good to know it CAN be done, the power was the next question, I believe this is a 40" or 42" blower which will eat alot of snow, however if I go in 1st gear Low it might just do it
Old 04-11-2012, 08:08 PM   #5
mcavvie
mcavvie's Avatar
MTF Member # 50597
I've been looking for a two stage blower to adapt also, the ones I looked at were the models that have an idler pulley on the frame, like the MTD models. A belt runs from the idler to the blower and one from it to the engine.
1985 Bolens 1900 Eliminator c/w Cat "0" 3 PT., 60" deck, 54" blade, 46" dual stage blower, 1977 Bolens G14, 2005 Bolens(MTD) 17.5 hp c/w 42" deck, 42" Bolens mower deck, 2-42" Bolens snowblowers, 33" Bolens tiller, 42" MTD 8 HP tow behind tiller, 1978 Sears Canadian 19.9, 1977 Sears 16/6 twin, 2-Sears moldboard plow, Sears Spike harrow, Sears spring tooth harrow, 2 - Sears Cultivator, Sears Tote box, 46" Sears dozer blade, Sears 42" deck. Komatsu PC18MR Mini excavator
mcavvie is offline   Reply With Quote
