| Register | Home | FAQ | Active Topics | Garage | MTF Gallery | Search | Today's Posts | Mark Forums Read | Store | Chat Room |
#1 |
MTF Member # 66942
I finally got my 1965 L8 to the assembly phase, but it's been apart so many years my memory fails me. My problem is the fan shroud, more specifically the two 1/2 inch studs where it attaches to the crankcase. What seems correct is to put the shroud on, then the accessories (governor, electric starter plate), then the rear hitch straps. My problem is that when I adjust the handles all the way up, the shroud is forced against the exhaust manifold, and I'm not at all happy about that.
![]() Is my order correct? It was OK before I took it apart obviously, maybe the handlebars weren't all of the way up? If my order is correct, should I just grind a crescent shaped relief in the shroud? Thanks.
Gravelys: 1951 L, 1952 L, 1954 L, 1956 LI, 1962 LI, 1965 L8, Mystery L, Commercial 10, 1976 Model 524, 5460. I can quit any time I want. The rest: 1969 Wheel Horse Raider 12, 1983 Wheel Horse A-111, 1985 Wheel Horse 314A, 1978 Ford 2600, 1978 Ford 4100, 1975 Ford 3550 Industrial, 1949 Case VAC, 1951 Case VAC Eagle Hitch, Troy Bilt Horse, Troy Bilt Pony. Mowers, rakes, balers, and far too much other old junk to list....
| Sponsored Links | |||
Advertisement | |||
#2 |
Old Iron Connoisseur
![]() Maybe that helps? It's of my L.
WANTED: Time to finish all my tractor projects! My name is Jimmy and I have G.A.S. Click for an explanation if you need it.... Gravely 816s, 8182-T (Going back to 8183-T soon!), 526, Lots of "L" Round Fender John Deere 110 ![]()
#3 |
MTF Member # 66942
That does help. That's what I was thinking, but the hitting on the manifold baffles me. I'll probably end up grinding in some relief. Is this perhaps a known issue?
#4 |
MTF Member # 36044
Phil, I would'nt do any grinding yet. There has to be a reason why things did'nt go back together as they should. Not that I would know why, since I have'nt touched my '66 L8 since I picked it up last year. I WILL be following along though, for my own FYI.
#5 |
Same here.
![]() Take a picture of your shroud/exhaust manifold interference and maybe one of us will have an idea.
'72 John Deere 110, '39 and '40 Allis Chalmers Bs, '41 WC, '56 WD-45, '80 Gravely 8102, '63 L8, '52 L, '63 LI, '73 CI, '68 C10A, '57 LI, '58 LI, '69 C8, 1958? Wisconsin LI, '73 816 Looking for: LS/CS, 450 |
#6 |
MTF Member # 66942
There doesn't seem to be anything to screw up. The bottom goes on the studs and the top position is determined by the handlebars.
Unless there are washers that go on the studs first, but nothing like that shows on the parts list.
#7 |
Administrator
Correct me if I'm wrong, but aren't the studs off center in the brackets that mount to the lower engine block? If so, the brackets are quite possibly mounted upside down.
![]() ![]() MyTractorForum.com House Rules Looking for a Technical Exchange Article? Here's an Index! My Equipment: 1963 Gravely Model L 1972 Gravely 816 1973 Gravely Model C8 Six other Gravely C's, L's, and LI's 1981 Troy Bilt Horse, 7HP Kohler 1982 Gravely 8123 1983 Troy Bilt Junior 1988 JD 950, 75 Loader, 8A Backhoe 2002 Craftsman GT3000 23hp 48" Cut Hydro |
#8 |
![]() ![]() Join Date: Jan 2011
MTF Member # 54276
Wow DJ,
I have noticed a slight offset side-to-side, but never measured them from the end tips to the centerline of the studs. I'll check some tomorrow. Roger, |
#9 |
MTF Member # 66942
They look centered to me but I too will check tomorrow. However, I never took the brackets off the crankcase.
#10 |
Administrator
I'm just going off of memory and could very well be wrong. I really can't think of anything else that could be the problem though.
#11 |
Gravelyyard.com
I just checked. The one I have on the parts shelf seems to be equal distance from the center of the bolt to the holes. If there is any offset, it's only about a 1/16". They are offset from side to side.
#12 |
Administrator
Well that confirms it, I'm wrong. I had to have been thinking about the side to side offset instead. Thanks for checking Ron.
I can't think of anything else that would be causing things to not line up.
#13 |
MTF Member # 54276
Phil,
Can you take a picture of the exhaust side and your fitting problem? Roger, |
#14 |
MTF Member # 66942
Yes, will do, but right now it's together wrong, with the hitch straps on first. That way there's about 1/8 inch clearance to the manifold. I realized after I'd redone it that I wouldn't be able to attach the governor or starter plate that way.
Advertisement |
#15 |
MTF Member # 66942
Well here's a pic for what it's worth. With the straps on first as in the photo (wrong) there is a gap between the shroud and manifold, with the shroud on first, it presses against the manifold.
