Mitsubishi Diesel Engine Block Heater - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Old 01-10-2012, 09:39 AM   post #1 of 5
Waterbug
Waterbug's Avatar
MTF Member # 46362
Default Mitsubishi Diesel Engine Block Heater
I recently purchased an '09 TYM 293 HST tractor. It has a Mitsubishi S3L2 3 cylinder diesel engine. I'd like to install an engine block heater on it. Anyone here had experience doing a simular install. Any advice on finding a source for the heater ? I'm looking for an on-line source.
Waterbug is offline   Reply With Quote Quick reply to this message
Old 01-10-2012, 01:55 PM   post #2 of 5
TooManyGT
TooManyGT's Avatar
MTF Member # 38585
Default Re: Mitsubishi Diesel Engine Block Heater
I don't know of any specific ones, might try TYM, other options are universal ones you can buy at auto parts stores where you match them up to the size "freeze" plugs in the block. The other option is a magnetic one that you stick on the oil pan or side of the block, seems alot of people on here have gone that route.
I don't have one as mine is kept inside and it usually doesn't get that cold around here( and it still starts fine when it does).
Brad
Kubota '10 B2620 w/LA364, Homemade bucket QA, Homemade Hyd. grapple bucket
Wheel Horse '93 520H 60" deck, 48" blade
Simplicity '64 Landlord, Mid-grader blade, 46" front blade, sickle bar, Hyd-lift, deck.
Case 444, 48" deck, 54" front blade, 41" tiller, 3pt
Simplicity GTH20 & Deutz 1920 Diesel (under construction)
TooManyGT is online now   Reply With Quote Quick reply to this message
Old 01-10-2012, 05:20 PM   post #3 of 5
buba
MTF MEMBER
buba's Avatar
MTF Member # 35637
Images: 2
you could also get a inline one that you would put in your bottom radiator hose they are available at tsc and auto part stores simply drain the coolant cut the hose instal the heater and tighten the hose clamps replace the coolant and your good to go
you can never have too many antiques but finding the time and money to restore them that is a problem
buba is offline   Reply With Quote Quick reply to this message
Old 01-10-2012, 09:00 PM   post #4 of 5
Waterbug
Waterbug's Avatar
MTF Member # 46362
I did an on-line search and found that 1 1/2" lower radiator hose inline heater at TSC. A 600 watt heater for $24.95 looks like the way to go. I'll have to take a look at the tractor and see how much work it will be or if it will even fit. Thanks for the reply.
I also read some reviews on magnetic heaters and a lot of people are unhappy with the heat transfer efficiency.
Old 01-11-2012, 11:08 AM   post #5 of 5
Nouveau Redneck
3K Poster!!!!
Nouveau Redneck's Avatar
MTF Member # 19566
Images: 1
If you have an unheated barn or shed to store it in, you can throw a tarp over it and put a 100 watt light bulb under the oil pan for an hour or two before you go to start it. You'd be amazed at how much heat a light bulb can put out. There's so much energy wasted as heat with a conventional incandescent bulb that the government is outlawing them in favor of compact fluorescent and LED bulbs.
Nouveau Redneck
Sean in PA
1973 Ford 4000 3-cyl gas w/S-O-S & 60 inch Woods rotary mower
2008 John Deere X500
2010 John Deere X304
2014 Kubota BX25D w/50" snow blower
You know you might be a Nouveau Redneck if...
1. You use the cup holder on your tractor to hold your cosmopolitan instead of a beer
2. Your "Santa on a tractor" Christmas yard decoration is actually a high tech digital hologram.
3. Your deer camp cuisine is better than most 3 star restaurants.
Nouveau Redneck is offline   Reply With Quote Quick reply to this message
