Fit for CAT C7 C9 injector nozzle retaining nut&Caterpillar C15 injector nozzle nut
Diesel Oil Pipe M12-M14 for Common Rail Pipe Oil Tube 65CM M14-12
injector nozzle 2 437 010 074 injectors nozzles lb7
injector nozzle 9 432 610 890 injector nozzle C6.6
VE Pump Drive Shaft 17MM for VE Drive Shaft 146200-0300
head pump ve 10mm for ve efi fuel pump plunger
CAT C7 C9 Slide Valve for c9.3 cat engine control valve
Troy-Bilt garden way belts
Old Murray rider repowered with a Briggs 19.5 that runs great and got for free. Various cosmetic modifications.
My Ditch/Hillside Trimmer Build
Picture of wiring. Something is missing. What is it and where can I find one ? Ignore first two pictures.
this is my John Deere 317 its a 1982 and has around 4000 hours. I repowered it with a Kohler magnum 20.
I thought I’d share pictures of my tractor collection with everyone… First here’s a picture of most of the collection Here’s makes, models, and years in order: 1949 Allis Chalmers WD, 1978 John Deere 214, 1988 John Deere 318, 1973 JI Case 220, 1976 John Deere 210, and a 1979 John Deere 214. So...
Touched up cab and added electrics
I’m trying to find out the model on this here garden tractor. All I know that it has a Briggs and Stratton 14 to 18 hp engine. It has the PTO system the engine is from 1974.
1969 Gravely 430 Commercial, 40" deck
1985 Roto-Hoe 990-5 w/ Rear Tiller and Densa-Thrower
Pretty standard LGT-120 with a few bells and whistles added on. Call 'er Hot n' Blue because, despite my best efforts, she still likes to run decently hot. Hasn't become a problem yet, could just need carbon removed from the head. Could be age.
Pictures of the the Little Buck Loader mounted on the X728 using Auxiliary hydraulics front adapter.
Made after the merger before the name change to Massey Ferguson
Getting the accessories on now that I have adapter and 3 pt.
Once in a lifetime shot of a Buck checking out my herd of Deere!
2011 John Deere X728 Ultimate Garden Tractor, bought in Ap. 2022
