Home made wasp spray - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
My Place Pics and stories about your home and property
post #1 of 30 Old 05-24-2009, 01:18 PM Thread Starter
Bikes/Tractors what else
danbike's Avatar
I had read that a solution of liquid soap in water could be used for wasps. If this is correct it would be better for all than some other sprays, but ONLY if it works. Anyone else ever try it?
2005 JD X585
2011 Triumph T100
1967 Triumph TR6R-all original and gone to a new home
19XX VESPA PX200EFL
1964 Vespa GL(oldest original owner Vespa in the US)
danbike is offline
post #2 of 30 Old 05-24-2009, 01:22 PM
JD2030's Avatar
Re: Home made wasp spray
I have never tried soap and water but I know Starting Fluid, and gas works real well!
JD2030 is offline
post #3 of 30 Old 05-24-2009, 01:38 PM
Father to Triplets + 1
Justin's Avatar
I think soapy water is only good for the traps. It makes them sticky and makes it harder to get out. I think if you spray them with it you will only make them mad. I could be wrong though.
74 Sears ST 16 with automotive ignition conversion, 10" moldboard plow, cultivator, hiller, single disk with 2 cinder blocks, 42" MMM, middlebuster, manual 3pt hitch, Ag tires with wheel weights and tri ribs on the front
Justin is offline
post #4 of 30 Old 05-24-2009, 01:41 PM
standard issue neuralyzer
LLigetfa's Avatar
I use a bit of Sunlight dish soap and water in a garden sprayer. It works very well but for obvious reasons, you have to get close enough to the buggers to douse them with it.
When we had an infestation of Forest Tent Caterpillars of biblical proportions, we put Sunlight soap into an applicator that went on the end of the garden hose and we hosed the buildings down with it. It killed them by the millions. So many that I was raking them out of the flower beds and carting them off by the wheelbarrow loads. None of the plants or pets were affected and the house was never so clean before or since.
LLigetfa is offline
post #5 of 30 Old 05-24-2009, 02:46 PM
ggsteve's Avatar
Apparently the soap forms a film over their exoskelton and suffocates them (they breathe through pores in their abdomen). I've not been brave enough to try it. When I find a yellow jacket nest I unload a whole can of wasp spray down the hole to make sure I get every last one of them.
ggsteve
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H1 80 Cart
72 JD 110 parts
78 JD 316K 49 blower
84 JD 214 39 deck 43 blade
Woods box blade
74 Concord (MTD) 990
ggsteve is online now
post #6 of 30 Old 05-24-2009, 02:53 PM
Justin's Avatar
Well what do you know!
Justin is offline
post #7 of 30 Old 05-24-2009, 03:14 PM
10,000 +posts!
I have to agree. I only feel safe approaching stingy things behind a 10' plume of roaring flame. Save the soap and water to wash their little charred bodies away with the pressure washer.
HydroHarold is offline
post #8 of 30 Old 05-24-2009, 03:20 PM
Retired Aug.31 2007
jeepersmitty's Avatar
When you spray the soap and water be sure and put some tiny wash cloths out so they can get real clean.
I always know...
jeepersmitty is offline
post #9 of 30 Old 05-24-2009, 03:23 PM Thread Starter
danbike's Avatar
I didn't know that they had BO problems. Bug Odor
2005 JD X585
2011 Triumph T100
19XX VESPA PX200EFL
danbike is offline
post #10 of 30 Old 05-24-2009, 04:42 PM
Ken in NJ's Avatar
I use the 2.99 cans of wasp sray from HD .. I go through 2 cases a year .. between home and work
Ken in NJ is offline
post #11 of 30 Old 05-24-2009, 05:02 PM
Collector of many tractors
Kbeitz's Avatar
Gas and a oil can works gor me... Squart squart...
Kbeitz is offline
post #12 of 30 Old 05-24-2009, 05:09 PM
Camaniac
Spray starch works too. It makes them stiff, they fall to the ground and you can crunch them with your foot. Look out for "escapees" though.
1956 Cub Lo-Boy
JD LA175
JD LT133
JD RX73
Sears 16/6
If you can't fix it with a hammer, it must be an electrical problem!
freebird is offline
post #13 of 30 Old 05-24-2009, 07:50 PM
I have heard the soap and water mix works, but have never tried it.
I keep a can of carb cleaner handy; it works great. Have also used pump oil can with gas.
ar2stp48 is offline
post #14 of 30 Old 05-24-2009, 08:45 PM
10,000 +posts!
Anyone up for "Silly String" and a butane lighter? Man, that sure used to liven up parties!
post #15 of 30 Old 05-24-2009, 09:06 PM
junkie's Avatar
im dealing with those carpenter bees right now , they think they own my greenhouse.
junkie is offline
