Building a high tensilve 8 strand fence - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
My Place Pics and stories about your home and property
post #1 of 14 Old 04-14-2012, 07:03 PM Thread Starter
c5rulz's Avatar
I have an apple orchard in the back yard that currently has 28 trees. I am adding to it and have 27 more coming in about 2 weeks. The last honeycrisp I planted were totally wiped out by the bucks rubbing their antlers and breaking them off at the ground. Thus I have to build a fence to protect the new trees. I am new to high tensile fencing and had some from one of my golfing buddies who also brought his New Holland tractor w/12" post hole digger.
This made planting the 10' posts a ton easier.
The key to building this type of fence is the heavy re-inforcement of the corner posts.
SS1023B PTO driven spreader
John Deer GT235 48" with powerflow bagger
Husqvarna 353, OE Tree Monkeyed 346XP, 346XP ported, 550XPG, 357XP, 562XPG, 372XPG ported, 288XP Lite ported,
Dolmar 7900
Jonsered 2159 ported
Echo CS303T
Echo PPT 266
Echo PPT-266 pole saw
Speeco 28 ton splitter
Silvey 510
Oregon 511AX
Nielsen 100B for rakers
Stihl straight shaft trimmer W/ cutting blades
c5rulz is offline
post #2 of 14 Old 04-14-2012, 07:13 PM Thread Starter
c5rulz's Avatar
Re: Building a high tensilve 8 strand fence
Are these straight enough?
Since we had the post hole digger we pre dug the holes for the trees too.
Dolmar 7900
Echo CS303T
Echo PPT 266
Silvey 510
Oregon 511AX
c5rulz is offline
post #3 of 14 Old 04-14-2012, 07:21 PM Thread Starter
c5rulz's Avatar
The finished product and 21 year old apple trees.
My 84 year old Dad came out to inspect.
Dolmar 7900
Echo CS303T
Echo PPT 266
Silvey 510
Oregon 511AX
c5rulz is offline
post #4 of 14 Old 04-14-2012, 07:42 PM
MTF New Poster
ben2go's Avatar
That's beautiful property you got there.Good work on the fence.Looks great.
ben2go is offline
post #5 of 14 Old 04-15-2012, 10:07 AM Thread Starter
c5rulz's Avatar
Thanks
The wire used in this is amazing. Only 12.5 gauge but has a tensile strength of 200,000 PSI. It is possible to cut with a large dike pliars but you will only have enought strength to do it once.
Dolmar 7900
Echo CS303T
Echo PPT 266
Silvey 510
Oregon 511AX
c5rulz is offline
post #6 of 14 Old 04-15-2012, 10:16 AM
10,000 +posts!
We need details.. Spacing of wire??? Looks like a fence i need to keep deer out and dogs in.. I'm thinking you have 12 inch spacing... Sure is a nice set up. I'm curious. What will you do for a gate? That is a fantastic property you have there...
Team_Green is offline
post #7 of 14 Old 04-15-2012, 11:57 AM
Let's Get It On
Nice job, what are you pollinating the Honey Crisp with?
2014 Husqvarna GT54LS, Reinforced deck, Briggs Motor
Bucky Badger is offline
post #8 of 14 Old 04-15-2012, 07:31 PM Thread Starter
c5rulz's Avatar
The bottom wire is aprox. 10" but varies due to the contour of the land. The rest then reference every 9" up so it is 6' 10".
I put the gate up after taking the pictures. It is a 10' footer.
These are all the parts used to make this. Then tensioners are a rachet design.
http://www.farmandfleet.com/farm_liv...en/hi_tensile/
Here's the gate, it's the low spot on the fence, so it is about 14" off the ground.
http://www.farmandfleet.com/products...farm_gate.html
Dolmar 7900
Echo CS303T
Echo PPT 266
Silvey 510
Oregon 511AX
c5rulz is offline
post #9 of 14 Old 04-15-2012, 07:49 PM Thread Starter
c5rulz's Avatar
I considered putting a couple crabs in for pollinating but they do just fine right now. Off the top of my head I have,
Red Regent
Macintosh
Honeycrisp
Fireside
Haralred
Haralson
and will be adding:
Linda Mac
Zestar
Buckeye Gala
Cortland
Honeycrisp
Dolmar 7900
Echo CS303T
Echo PPT 266
Silvey 510
Oregon 511AX
c5rulz is offline
post #10 of 14 Old 04-15-2012, 08:24 PM
Let's Get It On
Red Regent
Macintosh
Honeycrisp
Fireside
Haralred
Haralson
and will be adding:
Linda Mac
Zestar
Buckeye Gala
Cortland
Honeycrisp
Thanks...I have about 15 Apple trees, 1 peach, and 2 pears right now..plan to do more next week or so also....
I have the same gate from F and F but (2) 16 footers nice and cheap. I put a cable and turn buckle on it ensure it doesn't sag... Where in WI are you? I have 6 acres between Mauston and Lavalle.
post #11 of 14 Old 04-16-2012, 08:38 AM Thread Starter
c5rulz's Avatar
I am on the outskirts of Onalaska which is 7 miles North of Lacrosse.
Have you started an IPM? (integrated pest management system) I can bore you aud nausem regarding spraying campaigns and got a chemical applicator's licensce for restricted use chemicals.
Dolmar 7900
Echo CS303T
Echo PPT 266
Silvey 510
Oregon 511AX
c5rulz is offline
post #12 of 14 Old 04-16-2012, 08:54 AM
Let's Get It On
not yet, I was just going to try the fruit spray from F and F for now
post #13 of 14 Old 04-20-2012, 09:49 AM Thread Starter
c5rulz's Avatar
I have glanced at it and the active ingredients are OK, the only downside is it's so diluted with amount you use, it gets very expensive. When it starts getting hot, spray for scab is every 7-10 days.
Dolmar 7900
Echo CS303T
Echo PPT 266
Silvey 510
Oregon 511AX
c5rulz is offline
post #14 of 14 Old 04-20-2012, 11:41 AM
Let's Get It On
k, thanks
