What to do with standing corn stalks? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Home Garden Herbs and Veggies grown at home
post #1 of 20 Old 08-25-2007, 10:00 AM Thread Starter
me
queen of spades's Avatar
Images: 12
Our summer garden appears to be a wash. Yellow and brown bush & stalks are mostly all that's left now (except for a few eggplant and watermelon vines).
Do most of you mow down your corn stalks & plow them under, or pull them up for compost?
queen of spades is offline
post #2 of 20 Old 08-25-2007, 10:14 AM
Artpb's Avatar
Re: What to do with standing corn stalks?
Haven't had a garden in 10 years but it is best to completly remove the corn stalks, and any other dead plant life, as bugs and other pests can over winter in the root sytem. I know big commercial farms leave the roots but they also use pecticides, which I didn't.
Artpb is offline
post #3 of 20 Old 08-25-2007, 10:37 AM
YANMAR 324 OWNER
emt812's Avatar
Images: 8
Usually cut down the corn stalks & feed them to the animals & plow the stubs under before winter.
PROUD GRANDPA!!
05 CC GT 2544 20 HP Kohler with sleeve hitch
03 CC GT 3184 18 HP Kohler with 3 pt hitch
14 324 YANMAR 24 HP with FEL
5 ft 3 pt hitch TILLER
5 ft Bush Hog
emt812 is offline
post #4 of 20 Old 08-25-2007, 11:08 AM
Carl's Avatar
Images: 3
If you are trying to build up the soil you could run over the stalks with a mower and till them in. That is if you have a mower that will handle them. Or if you have a chipper/shredder could cut them down, shred them and then till into the ground.
Believe
Carl is offline
post #5 of 20 Old 08-25-2007, 12:41 PM
Deceased Oct.-2014
Mickey's Avatar
Images: 9
What I've done has changed over the yrs. Used to have livestock so I cut the stocks and fed to them. Have also done the same thing for neighbors who had livestock.
Presently, last few yrs, I've cut the stocks and turned them under (see garden 07 thread for a pic of my tractor/tiller). Fortunately don't have to contend with bugs. If I get everthing turned under in the fall it's all broken down come spring. I turn under all the follage from garden crops.
For those with only smaller tillers, turning some vegetation under may not be feasable.
Cub Cadet 3204 48" mower
1257 Bolens
Yanmar Fx24D
5' rotary mower
52" Yanmar RSB1300 tiller
Koyker 155 loader
Mickey is offline
post #6 of 20 Old 08-25-2007, 01:56 PM
Merk's Avatar
I will plow corn stalks under.
My plow has a knotch coulter that cuts through the stalks.
Land side tire will flatten stalks. I went to a 2 inch narrower tire(was a 10.50 wide tire now 8.50 wide tire) and have a dual wheel on the land side. Ride is better and I have less drive line breakage.
Plow plug one time when plowing stalks under. I think my problem was the pin connecting sleeve hitch and plow together extended past plow hitch more than 2 inches. I didn't have plugging problems after I cut 1 1/2 inch inch off the pin.
Dead plant life is cheap fertilizer.
Just trying to help
Merk is offline
post #7 of 20 Old 08-25-2007, 04:13 PM
Images: 3
Did a good job on the stalks and now you will be ready for spring! thanks; sonny
sonny is offline
post #8 of 20 Old 08-25-2007, 06:53 PM
Anything With Wheels
Argee's Avatar
I run my brush hog over them and either disc it in or plant next seasons crop between them.
Randy G
Argee is offline
post #9 of 20 Old 08-25-2007, 10:38 PM
Carl's Avatar
Images: 3
I never would have guessed that a garden tractor plow would do such a good job of covering corn stalks.
Good job merk!
Believe
Carl is offline
post #10 of 20 Old 08-25-2007, 11:45 PM
shimp's Avatar
you might wanna cut em with a machete, and then use em , instead of toilet paper, to perform personal hygiene
shimp is offline
post #11 of 20 Old 08-26-2007, 07:43 AM
stanleyjohn's Avatar
I bunch some up for fall decoration with a pumpkin or two and the rest get sent to my mulch pile.
My First deere LA100 with twin bagger!Current inventory! JD LA100 Lawn Tractor,Toro 22" self propelled mower,craftsmen garden tiller(not an attachment),Agri-Fab Trailer
stanleyjohn is offline
post #12 of 20 Old 08-26-2007, 11:09 AM
Martian Wx Moderator
Mark / Ohio's Avatar
Images: 7
Many of mine were infected with fungus so they were shredded and removed from the garden never to return.
Mark -2002 John Deere LT150H
Mark / Ohio is offline
post #13 of 20 Old 08-26-2007, 12:08 PM
Nicky&Sterling RIP 03-08
saskman49's Avatar
We cut them down and use them to cover the strawberry plants for the winter, then burn them in the spring. I till the stubble under in the fall.
John
JD2320 with 62D, 200 CX with 53" bucket
Speeco QH & Hydraulic top link
JD 647 tiller
JD 413 Rotary Cutter
Frontier SP1060 Soil Pulverizer
Frontier BB2060 Box Blade
Land Pride 1572 Rear Blade
Allied 50" blower
Frontier pallet forks
55 Gal 3pt sprayer
Frontier middle buster
3 section diamond drag harrows.
Homemade garden Bedder and cultivator with 2" receiver as well
JD X485 with 62C deck
JD Gator TH 6x4
JD 216H 46 mower and 33 tiller
JD JS35 Mower
Stihl BG86, 017, MS250, FS90R, KM130R
saskman49 is offline
post #14 of 20 Old 08-26-2007, 01:41 PM Thread Starter
me
Images: 12
I decided to pull them up and put them on our compost pile...
Our okra & eggplant still look great!
post #15 of 20 Old 08-26-2007, 06:38 PM
Camaniac
As mentioned above, check for fungus, you don't want that around.
1956 Cub Lo-Boy
JD LA175
JD LT133
JD RX73
Sears 16/6
If you can't fix it with a hammer, it must be an electrical problem!
freebird is offline
