Trailer to pull behind your ATV - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
ATV's, RTV's, UTV's, and Snow Mobiles For fun or work or play
post #1 of 12 Old 02-13-2010, 01:31 AM Thread Starter
Workaholic
tettruck's Avatar
Looking for a decent trailer to pull behind my ATV. Need a trailer around the property (rolling 70 acres) for brush, timber, fencing, etc. My ATV (new to me) is Outlander 800 that says it will tow 1300 lbs.
I've been looking at a little Big-Tex 15LT, 50" x 96" utility trailer, that weighs 460 lbs unladen. Gross capacity is 1500 lbs. It would also qualify as a transport trailer FOR the ATV, too.
I would like something bigger than the "Garden Cart" variety of atv trailer, stock, without going custom and getting too spendy.
What do you think? Other ideas?
TT
2005 John Deere 4310 E-Reverser
300 CX FEL
5' Frontier Box Blade
5' LX5 Rotary Cutter
BX62 Wallenstein Wood Chipper
Husqy chain saws 350 and 365
Craftsman GT5000 6-sp manual 48" deck
Quad Boss (Swisher) 44" trail mower
2006 Chevy Silverado Duramax 6-speed manual Crew Cab
tettruck is offline
post #2 of 12 Old 02-15-2010, 01:19 AM
Re: Trailer to pull behind your ATV
I use my Prairie 360 more as a tractor than a recreational rig anymore. I've got half a dozen trailers for various purposes but the handiest is a little single axle with a 4' X 6' bed. It came with expanded metal for the deck but I put a piece of 3/4" plywood over it to keep nails and stuff from leaking out. The trailer has sides about a foot high and is made very simply. Wheels are 12" and I wish now I had gotten one with the 14" wheels as they would have been better for when I tow the trailer on the road with the pickup.
The tilt bed feature is seldom used and I took the big loading gate off the back as for my use it was more of a nuisance than a help. If I need to load something with a hand truck I use ramps. The quad will self load with out ramps the deck is so low. Probably if I had the 14" wheels I'd have to put down some 4 X 4 inch blocks to start the quad up on to load it.
I've found the shorter, low deck trailer is really handy for fence building and hauling stuff around. The longer trailers tend to become a bit of a problem in more restricted areas and rougher ground. When I'm working new fence I usually have a little Honda generator, air compressor, air nailers and all the wire, buckets and such that goes along with the job. Wood and steel post as well as post hole diggers and such all fit on the little trailer. Hand tools are carried in the front and rear open top cargo boxes on the quad.
Biggest problem I have with this little trailer is keeping the wife from stealing it for garden use behind her little quad.
Mike
Tencubed is offline
post #3 of 12 Old 02-15-2010, 01:31 AM
Just passing through
Upper5Percent's Avatar
TT
So what kind of Hitch tongue weight will your unit handle?
Because that will help you define your trailer options...
We use these for smaller jobs...
EZ-Haul Utility Trailer w/ Hitch & Deck
This economical utility wagon/trailer with deck can be used for numerous applications.
103446
Adjustable-length steel frame can haul up to 2,200 lbs. on 6.5" x 16" pneumatic tires.
Connect two or more together with 46" steel handle in front and trailer hitch in back.
Size: 48"W frame adjusts from 62" to 90" long.
Heavy-duty Expanded Metal Deck measures 48" x 72".
103865
All the advanced features of #103446, and more!
Hauls up to 4,000 lbs. on 9" x 18" pneumatic flotation tires.
Hitch two or more trailers together and pull with truck, tractor, or ATV.
Size: 72"W frame adjusts from 96" to 120" long.
Heavy-duty Expanded MetaDeck measures 73.6"W x 118"L.
http://www.farmtek.com/farm/supplies...roductId=20295
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #4 of 12 Old 02-16-2010, 01:52 AM Thread Starter
Workaholic
tettruck's Avatar
Tencubed - you're setup sounds similar to what I was considering. I canned that idea, at least for now, because the tongue weight capacity is 50 lbs. The Big-Tex trailer I looked at felt like the tongue weight was maybe 40-50 lbs, without loading the trailer.
Paul - that 2-axle setup looks perfect. Haven't seen that in California at my normal sources. I'll look harder. 2 axles means very little tongue weight. My unit specs capacities as 50 lbs tongue weight and 1300 lbs tow weight.
300 CX FEL
tettruck is offline
post #5 of 12 Old 02-17-2010, 09:12 AM
10,000 +posts!
i use this for hauling everything and any thing behind my honda rincon. I wired it with tail and brake lights for those night rides when hauling moose or deer outta the bush..
Team_Green is offline
post #6 of 12 Old 02-18-2010, 09:15 PM
Recycler
shenninger's Avatar
Images: 6
I built this one to haul firewood from behind my house. it's 4' wide X 6' long. It works well and was relatively inexpensive. I used to linear actuators to make it dump.
Link to my ATV Trailer build pics
Link to Dumping Video
Scott
Ingersoll 4016
mower deck
rototiller
snow blade
snow caster
Homemade: Log splitter, Front end loader,
3 Point Hitch
Dump trailer,
Redneck BBQ
MTF Thread during build of Artic-IngerCase
4WD Artic-IngerCase Loader Tractor
shenninger is offline
post #7 of 12 Old 02-18-2010, 09:22 PM
You can order them from here...
post #8 of 12 Old 03-09-2010, 11:40 PM
Btackett's Avatar
I got lucky and found this one on Craigslist for $40.
It is a 5 x 5 and both ends have a tailgate to haul long items and it also tilts. I use it for hauling wood, rocks, dirt, sand, brush etc. I also have a 5 x 8 tilt trailer for the larger jobs but I use this one about 90% of the time around the property.
Check with Harbor freight and you can get a 4 x 8 trailer with everything but a floor/sides for about $300 and customize the rest yourself.
Btackett is offline
post #9 of 12 Old 03-10-2010, 09:12 AM
grnspot110's Avatar
Images: 21
What funeral home did you steal that box from?
John Deere: 1953-40S, 1970-70 I, 1980-314, 1993-755 w/60" deck, 2000-F725, 2004-790 w/300 Loader, 1980-Power King 2418 & 2007-"TS" Gator. & 1980-4' x 8' Snowco Trailer
grnspot110 is offline
post #10 of 12 Old 09-03-2010, 11:14 AM
Images: 3
Here's an article on one you might be interested in...a pretty neat unit that can be handy for a lot of different applications...
http://www.bigskybusiness.com
The website is http://spikawelding.com/ATV_trailers.htm
Chickenman is offline
post #11 of 12 Old 09-03-2010, 11:39 AM
Images: 3
Here's a pic of it...
post #12 of 12 Old 09-03-2010, 03:35 PM
Mac102004's Avatar
These are all the rage up here...
http://www.atvwagon.com/
I just use the box on my Rhino, or my small old cart made in the stone age.
1966 Massey 10
1968 Massey 12H
1975 Massey 14
1979 Massey 1650
1976 Case 444 Demo
1979 Sears SS16
Like tractors and farming? Check out my YouTube Channel www.youtube.com/mac102004
Mac102004 is online now
