Sleeper trailer-6 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 06-17-2011, 08:38 PM Thread Starter
Lindeman crawler fan
jdcrawler's Avatar
Sleeper trailer-6
The roof is done so it's time to finish the sides.
The wood in the upper right front corner was rotted out from where the roof leaked.
The rotted wood is stripped out.
Luckily the ends of the 2x2 cross braces are still good.
I made up a new curved upper corner piece and put in a new 2x2 in the corner.
The openings for the two windows on the right side are framed up.
Dry fitting the windows on this side to make sure everything is OK.
The overall height of the camper is about three inches taller that it was so there is a gap above the rear panel.
This is filled in with strips of wood.
A piece of 1/2 inch plywood is extended straight back from the angled part of the roof to strengthen this area.
There are sections of 2x2 that angle down from the roof to the back wall.
The inside paneling will attach to these so the roof area will angle straight down to the back wall.
This gap between the paneling and the roof will be used to run the wiring from one side to the other over the door.
The window opening on the left side is framed up.
There is a piece of 3/4 inch plywood in the framing above the window area.
This is so I can mount the interior light and have room for the wiring to run to it behind the plywood support.
Making sure the window on the left side fits the opening.
The left side of the overhang had this small window in it.
I haven't decided if I'm going to put it back in or not yet.
The angled 2x4 brace for the overhang runs right thru the area where this window use to be.
Ray
1949 Agricat crawler
( 3 ) 1948 Bolens Ridemasters type #35AA01
1939 Viking / Standard Twin
1962 Panzer model T70
"R/T" home made tractor
jdcrawler is online now
post #2 of 11 Old 06-17-2011, 09:07 PM
Imagine it. Build it.
tiretrx's Avatar
Images: 8
Re: Sleeper trailer-6
Good progress, Ray
.....just call me Ellis
I was abandoned as an infant and raised by a family of opposums........does that explain things?
tiretrx is offline
post #3 of 11 Old 06-17-2011, 11:41 PM
Banned!
Thumbs up Re: Sleeper trailer-6
Looking good, as far as window? I would try to use it if possible, can be a big difference on a hot night, or even on a so/so night
John@Reliable is offline
post #4 of 11 Old 06-17-2011, 11:41 PM
Oo-v-oO's Avatar
It would probably be nice but not absolutely necessary to have some cross ventilation in the sleeping area.
-Lee, KB1GNI
"Felix qui potuit rerum cognoscere causas"
[Happiness is understanding how things work]
Oo-v-oO is offline
post #5 of 11 Old 06-18-2011, 12:59 AM
HAMMAN
hamman's Avatar
I know that I was glad I had some cross ventilation in the bed area of our old cabover camper we had. I agreee put it in if possible. Like the progress. Thanks for the update.
hamman is offline
post #6 of 11 Old 06-18-2011, 07:35 AM
ex spelling bee champ
Ingersoll444's Avatar
Images: 14
Id bag the little window.. Ya, cross flow is nice, but in its new shortend size, you have that big one just off side there in the main part of the camper/sleeper. That angle support is a much needed structureal support piece for that front part, and wile you could replace it with more bracing, whats there now is simple, light, and sound... I would think you have enough windows allready in such a small aera.
Paul B
SUPER Of The Month 10/2011
Ingersoll444 is online now
post #7 of 11 Old 06-18-2011, 02:06 PM Thread Starter
jdcrawler's Avatar
Talked it over with my wife last night and decided to go ahead and put in the small window in the overhang.
I had taken out the original window frame with it still altogether so all I had to do was trim it off and mount it.
The window sits higher and more forward to clear the angle brace.
Ray
post #8 of 11 Old 06-18-2011, 02:16 PM
Sears Fan
dmorrill22's Avatar
Images: 26
Good compromise! Looks like it will work well there.
Doug
Doug
1966 Colt 2712 (Restoration in progress)
1969 Sears SS12 (Soon to be a dedicated grader!)
- Homemade snow plow (in progress)
- GM 3-wire alternator
- Duromax 16hp Repower
- Custom headlights
1972 Sears SS15 (Work in progress)
dmorrill22 is offline
post #9 of 11 Old 06-18-2011, 09:00 PM
Oo-v-oO's Avatar
Yup, nothing wrong with that.
-Lee, KB1GNI
Oo-v-oO is offline
post #10 of 11 Old 06-18-2011, 09:51 PM
HAMMAN
hamman's Avatar
I replaced all the old steel screws in our 1965 Fan trailer with Stainless Steel ones that I got at Mid States Bolt and Screw. Made the trailer look better and they didn't rust. JM2CW. Looks good!
hamman is offline
post #11 of 11 Old 06-18-2011, 10:59 PM
Booo
BOSOX's Avatar
Images: 14
Coming along nicely Ray!!
Mike
JD 214 w/ 39 Deck and Plow Blade (Long term project)
JD S82 RER w/ Bagger
BOSOX is offline
