Grease warning questions.... - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 03-29-2012, 02:10 PM Thread Starter
The Admin from... Nowhere
littletractorguy's Avatar
Images: 6
Okay, so, my $5.00 mini grease gun bit the dust, so I went out and bought a "real" one, and its raised some questions for me....
First of all, the tube of grease I bought has this warning on it:
"Do not mix greases of different soap types. Thoroughly remove old grease before applying".
Okay, so, I understand the part about what they WANT you to do, start with new grease on whatever you're greasing. But what the heck is a soap type? And, how do I tell what soap type my OLD grease was, since I don't think I have the tube any more... More importantly, how the heck am I going to remove all the grease that are in the bearing keepers on my trailer!?!?
Okay, now onto some other questions!
What the heck is THIS button for? Pressure release? Bleed valve?
And this fitting? Would this be for filling the little gun if I had a big pressure tank filled with grease?
post #2 of 10 Old 03-29-2012, 02:27 PM
SonnyT's Avatar
Images: 26
Re: Grease warning questions....
Chances are your old grease was a Lithium based soap grease. Meaning it has some soap in it. I would make sure your new grease is Lithium based. Should say on the label.
1st button is to bleed air as you tighten gun/tube together after putting in a new cartridge so it doesn't get air locked.
2nd is for filling from a air powered grease pot. Never used it so I don't know if it actually works well or not.
RIP Sonny T.
1954-2015
SonnyT is offline
post #3 of 10 Old 03-29-2012, 02:37 PM
SonnyT's Avatar
Images: 26
Here is a pdf with a compatability chart. Although the chances are your grease is probably a Lithium based grease, which is most common for off-the-shelf grease.
http://www.mobilindustrial.com/IND/E...patibility.pdf
RIP Sonny T.
1954-2015
SonnyT is offline
post #4 of 10 Old 03-29-2012, 11:13 PM
that second fitting is for refilling the gun without a cartridge. usually from a five gallon container with a hand pump on top. you slip the fitting into the pump female and as you pump the lever on your gun will extend out. the first fitting is a valve for air bound problems. i used a grease gun[s] for over ten years 40 hrs a week.
flhusa1 is offline
post #5 of 10 Old 03-30-2012, 10:29 PM
Canawler's Avatar
And they're not kidding about the grease incompatibility. Mix the wrong types and it will almost literally turn to a watery mess.
---Jim
It's only money, you make more every day.
'74 Agway/MTD 990
'93 Troy-bilt GTX18
'74 Allis Chalmers Homesteader 8 (X2)
?? Simplicity Broadmoor 717
?? Pennsylvania Meteor 1010
Canawler is offline
post #6 of 10 Old 04-16-2012, 10:56 AM
外人Geezer MTF Member
MacLawn's Avatar
Wow, Little, great questions!! I never knew that about soap in grease, and it turning to a watery mess if mixed. Makes me wonder how much stuff I have messed up over the years. Of course, all the grease I bought was just from local stores, Walmart, etc., so I guess it was the lithium type... I have got to get a good grease gun!
That old man - he don't think like an old man...
Now I wouldn't want to be within 400 - 500 yards of one of them nuclear bombs when it goes off, I tell ye! WW1 Vet Old Man
"He's pinned under an outcropping of rock. Lucky for him, the rock kept the dirt from burying him alive".
Dirt, it's nothing but dirt, I tell ye...
"I thought I was wrong one time, but I was mistaken." Command Sergeant Major Jim
http://www.mytractorforum.com/attachment.php?attachmentid=780993&stc=1&d=1398926  159
MacLawn is offline
post #7 of 10 Old 04-16-2012, 02:52 PM Thread Starter
Images: 6
You know, I got so nervous about mixing the greases, I never re-lubed the bearing buddies on my little trailer.... BUT I've made a 500 km round trip AND a 1000 km round trip with it now, and the hubs never even got warm.... So I'm gonna assume they were still well-lubed.... NOW I'll check it out, now that I have time...
post #8 of 10 Old 08-26-2012, 08:47 AM
RustyPiston's Avatar
And just to further muddy things up.... not all online grease compatibility charts are in 100% agreement.
Also be aware that there are 3 types of lithium-based grease, Lithium, Lithium 12 Hydroxy, and Lithium Complex. While those 3 seem to be compatible with each other, ( according to the compatibilty charts I've seen), the Lithium Complex is compatible with the greatest number of other based type greases.
Bottom line--- If you find a grease that works well, stick with it. If you change the type or brand your using, keep a close watch on it for awhile. The internet is loaded with horror stories of people changing the brand of grease they use, grease runs out and bearing failure soon follows. It's rarely the fault of the grease if used for the applications it was designed for. It's a compatibility issue.
RustyPiston is offline
post #9 of 10 Old 08-26-2012, 05:16 PM
ShelbyGT550's Avatar
Guess you learn something everyday, Never knew grease had compatability issues. hmmm
1996 John Deere 425 Main Summer Machine - 20HP Liquid Cooled Kawasaki - Hydrostatic Twin Pedals - 48" Deck
197? John Deere 400 H3 Main Winter Machine Down - Fixing odds & ends - 19.9HP Kohler 532- Hydrostatic - 3PT Hitch - Back Blade - Snow Blower - Cab - Weights - Chains
1974 Massey 12G - Backup Machine - Tecumseh 12HP - 4 Speed Variator - 42" Mower Deck - Snow Blower - Tiller - Cab
1996 Sears GT6000 - Backup Machine - Kohler Command 22HP Twin - 6 Speed Hi/Low - 42" Mower Deck - 42" Dual Stage Blower - Brush Guard - ATV Tires - Chains & Weights
1974 John Deere 112
(Parts)
197? John Deere 112 Electric Lift - Storage - 12HP Kohler K301- 4 Speed Manual - Turf Tires
Past Machines & To-do's - 1974 Snapper LT16 - 1989 Murray GT18/46 - 1970 Massey Ferguson 10 - 2004 John Deere LA100- WIP
ShelbyGT550 is offline
post #10 of 10 Old 08-26-2012, 08:57 PM
Old Stonebreaker
And if you want to change to bulk fill you have to remove the piston and flip the rubber over so the cup side is toward the grease. You also need to lock the follower rod in the piston and fill 'til the notch in the rod shows, NO FURTHER or you will get grease forced past the piston. I used grease guns most every day at work for 32 yrs.
Mike
mla2ofus is offline
