Make your own Lawn mower Snow plow? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 08-03-2009, 06:45 PM Thread Starter
guinelle1's Avatar
im thinking about getting a plow for my mower. but i had an idea. what if i cut a 55 gallon oil drum in half and welded some angle iron to it to make my own plow? anyone ever done this before?
guinelle1 is offline
post #2 of 16 Old 08-04-2009, 12:29 AM
Re: Make your own Lawn mower Snow plow?
id double the 2 halfs up oil barrels are pritty thin
simplicityguy92 is offline
post #3 of 16 Old 08-04-2009, 01:20 PM
Better off using an old hot water heater tank,air compressor tank,or a propane tank (but be careful cutting it,do NOT use a torch!--drill a starter hole and use a sawsall or sabre saw)..
The 35-55 gallon drums will work, but ARE very thin & flimsy and will need a beefy frame to surround it completely,its only good to "skin" the blade with--while the other tanks I mentioned are 1/8" to 3/16" thick and only need angle iron on the top,bottom and sides,the 55 gallon will need "ribs" in between too...you CAN make ribs from cut up car rims,but why go through all that work if you dont have too??..a section of a 275 gallon home heating oil tank is a good choice too,they are 3/16" thick..I have seen some nice plows made from large diameter pipe cut in half too..thick and heavy enough to need no reinforcing at all,just a push frame..
Tractor-Holic is offline
post #4 of 16 Old 12-19-2009, 03:47 AM
Using a saw or drill is putting you in danger as they have arcing at the brushes
To cut a tank first fill it with water and drain it then it is safe to cut
I did gulp the first time that I cut into a 500 gal tank with a cutting torch
Saratoga is offline
post #5 of 16 Old 12-19-2009, 07:02 AM
jayvee43's Avatar
guinell1, you can make a blade out of a 60 gallons hot water tank, just like the one I made...
see attached picture.
jayvee43 is offline
post #6 of 16 Old 01-05-2010, 07:25 PM
any links to a step by step?
orangekubota is offline
post #7 of 16 Old 01-05-2010, 07:32 PM
Run ahead of the pack
stladrill's Avatar
Images: 6
Check that.
My first rear snow blade built form scratch
stladrill is offline
post #8 of 16 Old 01-05-2010, 08:12 PM
xxxxxxxxxxxxxxxxxxxx
david doyle is offline
post #9 of 16 Old 01-06-2010, 12:21 AM
zack d's Avatar
buy a blower..
16g
165 massey
10 commercial
zack d is offline
post #10 of 16 Old 01-06-2010, 10:43 AM
well being a noob to tractor implement construction I figured some pictures would help. I'm no stranger to fabrication but I was hoping for a little more. possibly angles, bracing, means of raising, lowering, etc.
post #11 of 16 Old 01-06-2010, 10:51 AM
stladrill's Avatar
Images: 6
Did you go see post #7? you have a link to an other thread with picture
post #12 of 16 Old 01-06-2010, 11:12 AM
no I missed that. thank you.
post #13 of 16 Old 01-08-2010, 02:21 PM
Cranky Motorsports
GT_80's Avatar
Images: 32
too bad you don't live in mass-I have an old 60 gallon air compressor tank i would give you !
MTF Addict #35886
Hugh-SS/16 fan #0001
I love Onans, Tecumsehs, and diesels!
1967 Suburban 12 "The 679"-Yanmar L70 Diesel swap
1967 Suburban 10 - soon to be Super 12 Special clone
1967 Super 12 - nice original
1968 Super12 "Miss Emma Lee"
1968 Super 12 "C&B Special"
1970 Suburban 12
1971 SS14- diesel / trike?
1973 SS16/ 18/6 Diesel hybrid "D10S"
1974 SS16 - rescued
1976 SS18 "Trusty"
1978 GT18 with Hard cab
Attachments: lots
My YouTube
My Ebay
Sears Manuals
GT_80 is offline
post #14 of 16 Old 01-08-2010, 03:06 PM
just push it and it'll roll downhill it should get here by next week
B6100 Kubota
post #15 of 16 Old 01-30-2010, 01:42 PM
Getting past the shovel method- any ideas for a dirt/snow mover my 19.5 Craftman can handle ? Saw a movable blade with hand adjustments but lost the picture
Tonto is offline
