Tandem Lawn sweepers - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 34 Old 04-13-2009, 03:28 PM Thread Starter
Chuck_050382's Avatar
I am going to pick a 2nd lawn sweeper tomorrow. I would like to pull 2 at once. Both are 38" sweepers.
Has any one else on here done that?
Any suggestion on tow bars?
thanks
Chuck
Ford LGT 145, 2003 Craftsman GT 5000, 1977 MTD 990, 1983 Ford LGT 165, 1988 Cub Cadet 1210
Chuck_050382 is offline
post #2 of 34 Old 04-13-2009, 03:34 PM
ex spelling bee champ
Ingersoll444's Avatar
Images: 14
Re: Tandem Lawn sweepers
I have thought of that also. The one is just not wide enough!!!
Paul B
SUPER Of The Month 10/2011
Ingersoll444 is online now
post #3 of 34 Old 04-13-2009, 03:36 PM Thread Starter
The only down side is 1 sweeper is hard enough to back up, 2 will be impossible.
Guess that's a good reason to make a rubber edge for my blade so I can push the piles into 1 big pile to load into the compost.
post #4 of 34 Old 04-13-2009, 03:37 PM
Images: 14
Dumping would be a HUGE problem. Also you would want to stagger them, so they overlap. That would also make dumpping harder
Paul B
post #5 of 34 Old 04-13-2009, 03:47 PM Thread Starter
I could either stagger them or space them to leave a 30" strip between them, and then I would still be able to cover twice the area, the next pas would pick up the area between the sweepers, and 1 section over.
post #6 of 34 Old 04-13-2009, 04:09 PM Thread Starter
this is the solution I mention above.
post #7 of 34 Old 04-13-2009, 06:53 PM
standard issue neuralyzer
LLigetfa's Avatar
If you also tied them together near the inside wheels, they would be easier to back up.
LLigetfa is offline
post #8 of 34 Old 04-13-2009, 07:06 PM
professor's Avatar
Images: 11
I tied a couple of push mowers to my tractor last year and it did work well in a straight path- turning was the issue. Sharp turn would leave an uncut strip. The only way around that was link them closer together, which of course, defeats the idea.
Every day is a victory.
'64 Simplicity Broadmoor
'66 Simplicity Broadmoor 707
'68 Sears Xl 10
? Dynamark 11/42
'71 Wheel Horse Special
'71 Wheel Horse Gt14
'72 Cub 127
? Bolens 10H
professor is offline
post #9 of 34 Old 04-13-2009, 11:16 PM
wouldnt you want them rite be side each other so u dont leave a strip
simplicityguy92 is offline
post #10 of 34 Old 04-13-2009, 11:51 PM
Tech Nerd Tractor Convert
Toolin's Avatar
Considering the trouble you're going through to create a custom hitch, might it be just as easy to part out the two sweepers and build a single "stretch" sweeper that's twice the width?
Paul.
i1050|Maint|Gov|Tach:ind,laser|Deck|Blade|JBJr|SBlow:Fit,Winch,Act|Chain|Cyclone|Sweep|Gators|Aerator|Cart|Knob|Hoist|Cab|Trailer|PC|Bits
"Grass is the cheapest plant to install and the most expensive to maintain." ~Pat Howell
Toolin is offline
post #11 of 34 Old 04-14-2009, 08:42 AM Thread Starter
I was thinking about spacing them apart so that the strip it would leave would be worth going back over. For example a 34" strip not a 4" strip.
Toolin:
the hitch for the sweeper I was thinking of building was going to be pipe and/or angle iron scrap I have on hand. But the idea of 1 super sweeper sounds interesting as well. I will looking that also.
post #12 of 34 Old 04-14-2009, 10:24 AM
Fla Dave's Avatar
Images: 6
Here's another thought....
Get a second tractor and a helper, if possible. When my Granma's place (about 2 acres with oak trees) needs the leaves picked up I use my tractor and sweeper and my wife uses my Grandma's tractor and sweeper.
Just a word of advice, If women don't find you handsome then try to be handy.
Fla Dave is offline
post #13 of 34 Old 04-14-2009, 10:38 AM
Lindeman crawler fan
jdcrawler's Avatar
I like the idea of the 34 inch strip.
If you fastened both sweepers solid to the "T" bar hitch so they don't turn independently, wouldn't they then back up like a regular trailer?
You would need to make the tow bar longer so the "T" bar would clear the tires on turns.
Ray
1949 Agricat crawler
( 3 ) 1948 Bolens Ridemasters type #35AA01
1939 Viking / Standard Twin
1962 Panzer model T70
"R/T" home made tractor
jdcrawler is offline
post #14 of 34 Old 04-14-2009, 06:55 PM
Tech Exchange Moderator
Sergeant's Avatar
Perkins use to make a 3 across sweeper pull behined for IH Cub Cadet in the 1960's& 70's It just like the design above except you had a sweeper behined the two and it was in the middle
John Deere Models:X748,GX335,140H3,112,Sabre 1542,TX Gator
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
Sergeant is offline
post #15 of 34 Old 04-15-2009, 04:42 AM
Just passing through
Upper5Percent's Avatar
You could fabricate something like our tandem hay rakes...
DWIGHT D. EISENHOWER
Upper5Percent is offline
