Berco Snow Cab Installed on a Husqvarna - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 26 Old 12-23-2008, 10:47 AM Thread Starter
pfrenet's Avatar
I finally received the snow cab I ordered 6 weeks ago, just in time as we were going to have a major snow storm.
I won't go into too many details as there was already a post on a similar installation, however there were some differences.
Since I had already had the snow blower attachment, the support bracket kit came with the front cab supports.
When I went to install the back supports, I found that my weight brackets were in the way, when I was trying to figure a way, I happen to notice on the weight brackets that there were two round sleeves on the inside of the supports.. I fitted the rods supports into the sleeves and they fitted, even the openings for the hex screws were there..Guess Berco had some thought when the made the weight brackets..
I went to position the cab on the supports..pefect fit
Installed the enclosure
Then placed the rod to the snowblower thru the opening in the cab..To open you just open up the velcro to slide rod thru, no need to cut open a hole.
These are the parts I didn'e need to use. Saved some time in the installation
Anyways, we had the major storm come thru yesterday so got a chance to see how this was going to hold up. We had very strong winds, blowing snow, etc.. I had a small ceramic heater to keep warm (plugged into the 12V adaptor on the tractor).
Quite happy on how it stood up in the wind..very easy to see out of, even though I felt like I was sitting in a bubble It was a lot better than last week with snow flying in my face.
pfrenet is offline
post #2 of 26 Old 12-23-2008, 01:28 PM Thread Starter
pfrenet's Avatar
Re: Berco Snow Cab Installed on a Husqvarna
Here's a picture from inside the cab.
pfrenet is offline
post #3 of 26 Old 12-23-2008, 01:52 PM
oldtimer's Avatar
Nice looking setup !
oldtimer is online now
post #4 of 26 Old 12-23-2008, 01:55 PM
Chuck_050382's Avatar
nice looking cab, thanks for the pictures.
Chuck_050382 is offline
post #5 of 26 Old 12-23-2008, 02:46 PM
TundraBoy's Avatar
Nice setup! I see you have the electric lift on your model. How do you like it?
Cheers
TundraBoy is offline
post #6 of 26 Old 12-24-2008, 08:14 AM
markwb's Avatar
That's an awesome enclosure, nice machine too. Have fun with it.
Mark
IBEW Local 261 Groton, CT
2008 Cub Cadet ZTT i1042
1997 Lawn Boy Silver Series Model 10227
PreciseFit 42" Lawn Sweeper
Echo SRM-2100 Trimmer/Brush Cutter
"My Other Vehicle Is a Nuclear Submarine"
markwb is offline
post #7 of 26 Old 01-05-2009, 02:21 AM
I am curious, does the snow stick to the plastic winshield? It did on mine and I would have to get out periodically and wipe it off.
smfcpacfp is offline
post #8 of 26 Old 01-05-2009, 10:26 AM Thread Starter
pfrenet's Avatar
I havn't had any problems yet with snow sticking to the plastic. I was out 3 times so far. I recall in the instructions that the plastic was coated with something and it advised not to clean off with any cleaners only dry wipe. I'm sure it will eventually wear off.
pfrenet is offline
post #9 of 26 Old 01-05-2009, 11:50 AM
tiny tractor big interest
The little that little that has stuck to mine falls off after a simple tap from me on the inside.
Adam
lx176mainer is offline
post #10 of 26 Old 01-05-2009, 01:01 PM
gt275's Avatar
How does that ceramic heater work for you? Does the battery charging light come on when you are using that. I was thinking of getting one for myself. Just wondering, it seems like a heater like that would draw too much.
Thanks
2004 X485 (4/15) 25hp Kawasaki, 62" deck, 45 Loader, Front-mount de-thatcher.
2005 GX345 (11/09 w/124hrs) 20hp V-twin liquid cooled Kawasaki, 54" deck, Differential lock, Femco Cab Weather Enclosure, 42" snowblower, Electric Spout Rotation Kit.
Deere 10P poly Cart
-SOLD-
2001 345 20hp V-twin liquid cooled Kawasaki, 54" deck
1998 GT275 17hp Kawasaki, 48" deck, Cab Enclosure, 38" Snowthrower, Manual Spout Kit
1997 LX188 17hp Kawasaki, 48" deck
gt275 is online now
post #11 of 26 Old 01-05-2009, 03:40 PM
With my old Yamaha/Kimpex blower I would get enogh heat from the engine to keep me modestly warm, but your engine is foward, mine was between my legs:
post #12 of 26 Old 01-05-2009, 06:20 PM
ggsteve's Avatar
Nice rig! I see you have the Berco blade too. How long does it take to swap back and forth?
ggsteve
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H1 80 Cart
72 JD 110 parts
78 JD 316K 49 blower
84 JD 214 39 deck 43 blade
74 Concord (MTD) 990
ggsteve is online now
post #13 of 26 Old 01-05-2009, 06:50 PM Thread Starter
pfrenet's Avatar
Heater doesn't draw that much power, when I plug it in, the lights don't even dim.
pfrenet is offline
post #14 of 26 Old 01-05-2009, 06:53 PM Thread Starter
pfrenet's Avatar
Takes less than 4 minutes to swap back and forth..very easy.
pfrenet is offline
post #15 of 26 Old 01-05-2009, 07:07 PM
USMC
slkpk's Avatar
Images: 21
Very nice setup. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
