Operation of a Wheel Horse pull behind tiller - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 07-07-2008, 09:59 PM Thread Starter
I recently purchased this Wheel Horse tiller. I am looking for a manual or someone who has one that can advise me on how to operate it. Here are my problems.
1. The tines do not move unless the tiller is running and the clutch is engaged. How am I supposed to pull the tiller to the location that I want to till if it doesn't roll?
2. When I engage the clutch the tiller functions normally, moving in a forward motion tilling the ground in its path. When I am done, I have to stop the tractor in order to turn around and disengage the the clutch. During this time the tiller continues moving forward. I do not have time to disengage the clutch without it trying to climb up the back of the tractor. What is the proper method of disengaging the clutch?
The issue I am having is that it doesn't appear to have a way to lift the tines off the ground. Is it possible that I am missing a part?
Your advice is appreciated.
Thanks,
Rich
2004 Cub Cadet GT3100
2007 Johnny Bucket Jr.
Wheel Horse Raider 12
http://www.wheelhorseshirts.com
IH8UM = I hate university of meatchicken
I H8 UM is offline
post #2 of 11 Old 07-08-2008, 12:00 AM
xPosTech's Avatar
Re: Operation of a Wheel Horse pull behind tiller
I can't tell with the tongue on the ground but I'm gonna guess and say that you would raise the attachment lift to put the tiller onto the wheels to transport. Maybe the hitch has been changed?
As far as clutch engagement I have no idea. I think if nothing else I would kill the tiller to stop the tines when done or raise it onto the wheels as above.
I would also think it's kinda hard to find a manual without a model number. I see a couple of tags or labels of some kind.
You might have better luck with this question in the WH forum.
Ted
I wasn't born in Texas but I got
back here as soon as I could.
xPosTech is offline
post #3 of 11 Old 07-08-2008, 12:20 AM Thread Starter
I found a manual. Here is what it says.
OPERATION
The tiller is raised and lowered by using the tractor lift lever or hydraulic control. Depth is controlled by forward speed of the tractor, a slow speed results in deep tilling and faster speeds result in shallower tilling.
I don't know what the tractor lift is.
I H8 UM is offline
post #4 of 11 Old 07-08-2008, 07:22 AM
10,000 +posts!
glenn27's Avatar
Looking at the tongue on your tiller--you would use the older "sleeve hitch' on the tractor--which lifts w/ a cable-controlled from operator's seat...
If you go to Toro website--type in your model number off that--you sdhould be able to download a manual..--
Maybe Bill P. will come on here w/ more knowledge--I've seen one @ his house like that--or someone else here..
Jimmy Buffett
glenn27 is offline
post #5 of 11 Old 07-08-2008, 09:57 AM
xPosTech's Avatar
Didn't WH have a "slot hitch"? It just doesn't look like a sleeve to me. But I've never had a real WH - just Toro XL type.
I H8 UM here is what a sleeve hitch on a GT looks like in the down position.
And in the up position.
They can lift quite a bit of weight but not as much as a 3 point hitch.
Ted
xPosTech is offline
post #6 of 11 Old 07-08-2008, 10:05 AM
james66's Avatar
Images: 12
he. pulling it with a cub cadet not a wheelhorse, there is no rear lift on the cub, but you should get one like xpostech i think you can mod it to if pretty easy good luck james
james66 is offline
post #7 of 11 Old 07-08-2008, 11:27 PM Thread Starter
I think I will buy an inexpensive old used Wheel Horse tractor with the sleeve hitch on it. That should do it.
R
I H8 UM is offline
post #8 of 11 Old 07-09-2008, 10:13 PM
xPosTech's Avatar
That 3100 can handle it. FastAttach (Agri-Fab) makes a universal sleeve hitch that will fit. Johnny (Buckets) also makes one to fit yours with electric actuator but he's proud of 'em.
What deck lift do you have on the Cub?
Ted
xPosTech is offline
post #9 of 11 Old 07-09-2008, 11:08 PM Thread Starter
I haven't been able to find a sleeve hitch that fits my GT3100. Agri-Fab doesn't show any on their website. A post on another website says it doesn't fit any Cub Cadet with the transmission fill on the back of the tractor. My GT3100 has that. If anyone knows what I need, please let me know.
I have the 60" deck on it with hydraulic lift.
Thanks,
Rich
I H8 UM is offline
post #10 of 11 Old 07-10-2008, 10:18 AM
xPosTech's Avatar
Hmm . . . The Cub web site leaves a little to be desired.
But . . . In the attachments for the 3100 I found:
190-207
Cat. "O" Hydraulic 3-Point Hitch
190-288
Hydraulic Angling Kit
190-171
Manual Angle Kit
The 3 Point with a sleeve adapter will get you there but that's a convoluted way to do it. Another convolution would be a 3 point on the tiller.
I couldn't get any other info or images on the kits above. The angling kits may be for a plow or they may some marketing genius's idea of a sleeve hitch.
Somewhere on Johnny's site I saw (or thought I saw) a hitch being adapted for the 3000 series.
Since you have hydraulics that would be the way to go. Lots of tractors used the same lift mechanism for the deck and sleeve hitch with a cable, arm, rod or other linkage from one to the other. The huge lift arm on the hitch pic I posted isn't that necessary. That isn't my tractor, BTW.
Since most sleeve hitches detach with one bolt, I don't understand the restriction you cited about the rear fill for the transaxle (cast iron).
:goodl
Ted
xPosTech is offline
post #11 of 11 Old 07-10-2008, 10:24 AM
xPosTech's Avatar
Tractor Supply Co.
SKU Number: 4440252
Manual Sleeve; Fast-Attach Type; Black Color; Steel Material; For Lawn & Garden Tractors
Ted
xPosTech is offline
