Any experience with a Percise Fit Dump Cart from Lowes? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 05-18-2008, 10:38 AM Thread Starter
I am in the market for a dump cart and have been shopping around. I cam across this unit at Lowes and it looks intersting given the price point.
http://www.lowes.com/lowes/lkn?actio...02D&lpage=none
It is steel and has sides that can be folded down. I went to lowes to see it they had one on display and they were only in boxes. Box is heavy as ****, so it must not be too flimsy. It is probably a bit bigger than I need but I would rather error on the side of too big than too small. I am hoping for some feedback because it is either this or the 12.5 cuft poly cart from Sears which is about $60 cheaper.
Thanks in advance.
Spanks79 is offline
post #2 of 6 Old 05-18-2008, 10:55 AM
Guru on the Mountain
jdkubotamurray's Avatar
Re: Any experience with a Percise Fit Dump Cart from Lowes?
Thanks in advance.
I have a similar unit from TSC. High deck height 4 wheels difficult to back up, holds alot, I put plywood in bottom of mine.
jdkubotamurray is offline
post #3 of 6 Old 05-18-2008, 11:31 AM
tec2484's Avatar
I have one of the poly carts from sears. They work ok for light things but don't load it down with dirt. I over loaded my and the poly started flexing and never returned to shape.
I make sounds only other Tractor Freaks can hear.
tec2484 is offline
post #4 of 6 Old 05-18-2008, 09:56 PM
I don't have that particular cart, but I bought two other Precise Fit items and they were both of good quality.
Also, they have a very good method of packing the hardware that makes assembly easy.
I overloaded their smaller cart with dirt with no problems.
cooltimbers is offline
post #5 of 6 Old 05-19-2008, 07:51 AM
CCinCT's Avatar
Images: 13
I bought that exact cart 2 years ago, and so far I've been very happy with it. I've mostly used it to move wood, bags of sand and cement, and brush. It's handled very heavy loads with no problems, and no deformation. I've had it stacked to the top of the side rails with wood many times with no problems. The tires have held up very well: I've never had to put air in them despite all the debris I've run over.
There are two "features" I haven't used though: I don't dump the cart (I have a poly cart for lose materials), and I don't lower the sides. My cart is outside all the time, so the slide latches have rusted. Removing them is possible, but difficult. Do yourself a favor and coat them periodically with WD-40 or something like that.
2013 X530 with:
  • 48" deck
  • 48" plow
  • 47" snow blower
  • Power sleeve hitch
  • Tractor shovel
  • Tractor lift
  • 18 steel cart
  • AC-G8010S-E generator
Previously:
2006 Cub Cadet 2544 - Loved it
CCinCT is offline
post #6 of 6 Old 05-19-2008, 08:12 AM
grnspot110's Avatar
Images: 21
I bought that cart from Lowe's about 2yrs. ago, only problem I see, it could stand a paint job already (dulled). As CCinCT said, the hardware rusted, but what do you expect from China? Overall, a good cart for the $$$. If you use the rail on top, I put hairpin keepers in the two holes where the side rails meet the front rail to make it easier to fold down. ~~ grnspot110
John Deere: 1953-40S, 1970-70 I, 1980-314, 1993-755 w/60" deck, 2000-F725, 2004-790 w/300 Loader, 1980-Power King 2418 & 2007-"TS" Gator. & 1980-4' x 8' Snowco Trailer
grnspot110 is online now
