1/2" shank trailer hitch ball? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 10-01-2007, 12:51 PM Thread Starter
Archy's Avatar
Images: 14
The hole in the rear plate of my mower is too small for a 5/8" shank 1-7/8" trailer ball. I haven't measured, but assume it would accept a 1/2" shank trailer ball. I want to be able to pull around a small landscape trailer in the yard.
Anyone know where I could find a 1/2" shank ball? I've looked all over the net and local stores with no luck. Maybe nobody makes them, though a couple of people did tell me they thought that some motorcycle trailer hitches use a 1/2" shank ball.
I don't want to just drill out my rear plate since the existing hole has rounded edges giving it some strength.
Thanks.
My Tractors:
1994 Deere 445 w/ 60" Deck
2008 Deere X749 w/ 62" Deck
2005 Deere X585 w/ 62" Deck
2006 New Holland TC31DA
Archy is offline
post #2 of 16 Old 10-01-2007, 01:14 PM
chrpmaster's Avatar
Re: 1/2" shank trailer hitch ball?
I ran into the same problem on an older Simplicity I had. I made a short extension bar about 4" long with a 1/2" hole on one end and a larger(I think 3/4") hole on the other. I just bolted it on tight and never had a problem.
Andy
Stupidity is exasperating. Willful ignorance is bulletproof.
I totally take back all those times I didn't want to nap when I was
younger
I think part of a best friend's job should be to immediately clear your
computer history when you die
chrpmaster is offline
post #3 of 16 Old 10-01-2007, 01:19 PM
munderhill's Avatar
Images: 7
Never seen a ball with that small of a stud.
I would get the one you need and turn it down and re/thread to the size you want.
If you can find one that accepts a bolt (female ball) you could get a heli-coil to reduce to 1/2-13 or 20 thread.
MU
munderhill is online now
post #4 of 16 Old 10-01-2007, 03:53 PM
Sirwin's Avatar
Images: 3
http://cgi.ebay.com/ebaymotors/ATV-A...spagenameZWDVW
http://cgi.ebay.com/Lawn-Garden-Trac...QQcmdZViewItem
Here are three items that may be better for your needs than make the hole bigger for a ball. I would go with the 2 inch Receiver hitch With insert.
Sirwin is offline
post #5 of 16 Old 10-01-2007, 08:41 PM
Blacksmith
blacksmithman's Avatar
Here is a picture of what I made for my tractor. I needed a lower hitch. I can pull my trailer or lawn sweeper.
blacksmithman is offline
post #6 of 16 Old 10-02-2007, 10:52 AM
I would leary of bolting on one of those from ebay. The additional reach would create extra leverage on the exsiting tractor hitch. It might bend it if you have too much tongue weight.
kwwolfe is offline
post #7 of 16 Old 10-02-2007, 01:22 PM Thread Starter
Archy's Avatar
Images: 14
Thanks for the replies.
I may just have a friend make a short extension like chrpmaster did - sort of like the 2nd ebay option posted by Sirwin.
My Tractors:
Archy is offline
post #8 of 16 Old 10-09-2007, 08:39 AM
If you could find the type that take a carrage bolt. You could use a 1/2 inch bolt instead of the 5/8. If you wanted you could put a bushing in but I don't think it would be necessary for a garden tractor with a yard trailer.
cfhartman is offline
post #9 of 16 Old 10-09-2007, 09:28 AM
Sign up Today!!!
Mayor's Avatar
Images: 34
It does. I had to weld a plate on my LX and make the area thicker to work. I never had a lot of weight on it.
JD 2305, 200CX, MMM, iMATCH, Weight Box, 826D Snowblower, Frontier Box Blade, Markham Welding Toothbar, Star Sprayer 3 point, Herd M96 Spreader 3 point, Trac Vac 3 point.
Projects: 12 Volt Sprayer, Weight Box, Toolbox
Mayor is offline
post #10 of 16 Old 10-09-2007, 12:21 PM
Dan Lovell's Avatar
I have one, but I can't for the life of me remember where I got it. I thought Northern Tool but I don't see it in there current catalog. It will come to me out of the blue.
Dan
On second thought I must have a 5/8 shank on mine. I see Tractor Supply has one in their catalog for $11.55. I would drill it out, another 1/8 in. isn't going to make that much difference.
Dan Lovell is offline
post #11 of 16 Old 10-09-2007, 10:32 PM
BobK's Avatar
Images: 9
mounted a 2" ball onto a piece of 1/4" plate and made two brackets that hang off part of the rear bagger frame on my LT180.
BobK is offline
post #12 of 16 Old 10-10-2007, 11:29 AM
Dan Lovell's Avatar
That will work, nice job. There is a solution for every problem.
Dan
post #13 of 16 Old 10-10-2007, 11:30 AM
SCCC's Avatar
I have a very old one that came off a 60's Cub Cadet- maybe they sold 'em back then.
I hope my ship comes in before the dock rots!
SCCC is offline
post #14 of 16 Old 10-10-2007, 02:36 PM
Rest in Peace Mr Jimi
Mr Jimi's Avatar
All yard mowers are designed with a 1/2 inch hole so we won't put a real trailer ball in them to overload our mowing machines that are designed to mow grass..
Mr Jimi is offline
post #15 of 16 Old 10-18-2007, 02:11 PM
Dan Lovell's Avatar
Mr Jimi If you have a GT it's designed to do a lot more than mow grass.
Dan
