How much hp for a tow behind mower? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 12 Old 05-01-2013, 03:27 PM Thread Starter
How much hp would I need for a tow behind mower? I have a extra lawnmower engine at about 5 hp. Would it be possible to hook it up to a extra lawndeck 38-40 inch wide? Would it cut tall grass well?
I know many small 38-40 inch mowers have 10-15hp engines. But they have a extra load to pull(person, and the rest of the tractor). So would a small engine be a bare minimum?
I was looking at something like this.
Finally got off the couch
or this
Seperate Engine for Mowing Deck
Thanks for the feedback!
7
7sleeper is offline
post #2 of 12 Old 05-01-2013, 04:04 PM
Loremaster72's Avatar
Re: How much hp for a tow behind mower?
I'd say you'll be a bit short of horsepower for cutting tall (field) grass at speed. An 8hp Gravely walk behind (all gear drive, minimal loss) can easily bog out on high grass with a 40" deck in high gear. In low gear with a 30" deck, they are pretty good. Remember that small mowers are typically used for mowing LAWNS, not high grass. Deck throughput clearing the grass end up sucking up a good bit of horsepower. I think that what you are proposing would probably work OK for lawn mowing, but will bog down in high grass.
Loremaster72
Mechanical Engineer, Book Collector, and Tractor Nut
Current Machines:
1979 Gravely 5265 Commercial
1990 Gravely 16G Professional
1973 Sears SS16 Twin
Loremaster72 is offline
post #3 of 12 Old 05-01-2013, 06:48 PM
I have rebuilt my friends Haban 42 inch tow behind twice now. First time replaced the 8 HP Briggs (lost a valve seat) with an 11 HP Briggs engine that also last a valve seat. The second time went to a 13.5 HP Briggs OHV. More HP is better. 5 HP is for a 18 to 22 inch deck. Most tow behinds are much wider. Roger
rhenning is offline
post #4 of 12 Old 05-02-2013, 12:55 AM
15,000+ Posts & Climbing
Minimum of 2 hp per foot of width for a manicured lawn. More for mulching or bagging.
Minimum of 4 hp per foot of width for tall grass.
As has been stated, more horses eat more grass!
You're a wee bit light in the horsepower department for that mower.
TUDOR is online now
post #5 of 12 Old 05-02-2013, 06:49 AM Thread Starter
Thanks for the feedback!!! Really good info here. Now I just have to find out how many inches are a foot....
Too bad, I was hoping for a nice project next winter. Well maybe I can hunt down another lawnmower engine => one engine per spindle!
7
7sleeper is offline
post #6 of 12 Old 05-02-2013, 07:06 AM
Collector of many tractors
Kbeitz's Avatar
This tractor is only 4 hp. I've mowed grass over the hood with no problem. I've pulled full size pickups with no problems.
Kbeitz is offline
post #7 of 12 Old 05-02-2013, 09:31 AM
Yes you can use a 3 1/2 HP 20" or 22" push mower. I have mowed more then enough acres that way 60 years ago. It's how fast you want to mow. My guess is with a pull behind you want to cover a lot of area fast. I would say 10 to 12 HP minimum and more is better. As I remember it you went very slow in heavy grass and real heavy grass there was stop and back up to keep from killing the engine.
DonF is offline
post #8 of 12 Old 05-02-2013, 09:35 AM
CADplans's Avatar
I do not believe that mowing deck is OSHA approved!!
The new decks are so "safe", they require more HP.
CADplans is offline
post #9 of 12 Old 05-02-2013, 12:33 PM
As long as speed is not part of the equation, 1 hp could probably run that mower.
Any riding mower should have no problem pulling a full size pickup. after all, it only takes a pair of 10 year old kids to push one. Not a whole lot of horsepower involved there!
TUDOR is online now
post #10 of 12 Old 05-07-2013, 08:03 PM
What happened?
timflury's Avatar
The 5hp tractor to your left runs a 28" deck, and a 27" snowblower.
Simplicity had a 6hp RER that ran a 32" deck.
The Simplicity 700 ran either a 36", OR the 42" deck with a 7hp 19D Briggs engine.
I would say that you might be working the 5hp engine a little hard if you end up cutting thick grass. You might find yourself with very slow ground speed if the engine is working too hard.
timflury is offline
post #11 of 12 Old 05-07-2013, 08:30 PM
john9001's Avatar
60 inch three blade tow mower, 14.5 HP
john9001 is offline
post #12 of 12 Old 05-08-2013, 07:51 PM
biker's Avatar
The onew behind the Ford looks nice. I don't why you cant do what you want to do. All you can do is try it.
John Deere 750
Kubota B6200
Craftman GT5000
Building A Hydraulic Drive Homemade Tractor
Happy Wife Happy Life Sad Wife OOH No
Nothing But The Truth
biker is offline
